parallel opened diagrams - delete not working [message #732205] |
Tue, 04 October 2011 04:36  |
Originally posted by: Lilija Klassen
I've a problem with the delete action when two diagrams are opened at
the same time. The problem occurrs when I add a new element and then try
to delete elements. While debugging I found out that the shape node of
the second openend diagram will not be deleted. This causes then a
recreation of edit parts and a nullpointer exception.
Any idea how to fix this?
Re: parallel opened diagrams - delete not working [message #734230 is a reply to message #734177] |
Fri, 07 October 2011 03:38  |
Am 07.10.2011 01:37, schrieb Michael Golubev:
> Hello,
> Please post the stack trace and more details about how to reproduce the
> NPE here or into the new bugzilla.
> Regards, Michael "Borlander" Golubev
> Eclipse Committer (GMF, UML2Tools)
> at Montages Think Tank, Prague, Czech Republic
> Montages AG, Zürich, Switzerland
here the stack trace. Note, that I did lots of customization. When I add
a new element into one of the two parallel opened diagrams I also create
connections. When I then delete the new added element or any other the
following stack trace occures.
!ENTRY org.eclipse.gmf.runtime.diagram.ui 4 4 2011-10-07 09:30:54.817
!MESSAGE execute
!STACK 0
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
at
org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:521)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:194)
at
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack.execute(DiagramCommandStack.java:169)
at
org.eclipse.gmf.runtime.diagram.ui.actions.DiagramAction.execute(DiagramAction.java:141)
at
de.wagner.tooling.incident.modeller.diagram.edit.commands.DeleteAction.doRun(DeleteAction.java:60)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.run(AbstractActionHandler.java:359)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run(ActionManager.java:225)
at
org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(ActionManager.java:223)
at
org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandler.run(AbstractActionHandler.java:348)
at org.eclipse.gef.KeyHandler.performStroke(KeyHandler.java:83)
at org.eclipse.gef.KeyHandler.keyPressed(KeyHandler.java:55)
at
org.eclipse.gef.tools.SelectionTool.handleKeyDown(SelectionTool.java:331)
at org.eclipse.gef.tools.AbstractTool.keyDown(AbstractTool.java:1016)
at org.eclipse.gef.tools.SelectionTool.keyDown(SelectionTool.java:491)
at org.eclipse.gef.EditDomain.keyDown(EditDomain.java:169)
at
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchKeyPressed(DomainEventDispatcher.java:252)
at
org.eclipse.draw2d.LightweightSystem$EventHandler.keyPressed(LightweightSystem.java:497)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:167)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1104)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1100)
at org.eclipse.swt.widgets.Widget.wmKeyDown(Widget.java:1809)
at org.eclipse.swt.widgets.Control.WM_KEYDOWN(Control.java:4892)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4560)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4972)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2531)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3752)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at de.wagner.tooling.incident.Application.start(Application.java:45)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSettingDelegate(BasicEObjectImpl.java:1571)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1037)
at
de.wagner.tooling.incident.modeller.metamodel.impl.SwimlaneImpl.eGet(SwimlaneImpl.java:336)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1021)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1013)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjectImpl.java:1008)
at
de.wagner.tooling.incident.modeller.diagram.parsers.AbstractParser.getValue(AbstractParser.java:189)
at
de.wagner.tooling.incident.modeller.diagram.parsers.AbstractParser.getValues(AbstractParser.java:169)
at
de.wagner.tooling.incident.modeller.diagram.parsers.MessageFormatParser.getValues(MessageFormatParser.java:238)
at
de.wagner.tooling.incident.modeller.diagram.parsers.MessageFormatParser.getPrintString(MessageFormatParser.java:203)
at
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.getLabelText(SceneStatusEditPart.java:194)
at
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.refreshLabel(SceneStatusEditPart.java:385)
at
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.refreshVisuals(SceneStatusEditPart.java:374)
at
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneStatusEditPart.setLabel(SceneStatusEditPart.java:155)
at
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneEditPart.addFixedChild(SceneEditPart.java:132)
at
de.wagner.tooling.incident.modeller.diagram.edit.parts.SceneEditPart.addChildVisual(SceneEditPart.java:165)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:211)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.addChild(GraphicalEditPart.java:1319)
at
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.access$3(GraphicalEditPart.java:1)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart$3.run(GraphicalEditPart.java:861)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.runExclusive(TransactionalEditingDomainImpl.java:328)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.refresh(GraphicalEditPart.java:851)
at
org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at
org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at
at
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.refreshChild(GraphicalEditPart.java:1232)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.handleMajorSemanticChange(GraphicalEditPart.java:1258)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeEditPart.handleNotificationEvent(ShapeEditPart.java:165)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPart.handleNotificationEvent(ShapeNodeEditPart.java:236)
at
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPart.notifyChanged(GraphicalEditPart.java:1438)
at
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBroker.fireNotification(DiagramEventBroker.java:500)
at
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBroker.resourceSetChanged(DiagramEventBroker.java:395)
at
org.eclipse.gmf.runtime.diagram.ui.DiagramEventBrokerThreadSafe.resourceSetChanged(DiagramEventBrokerThreadSafe.java:73)
at
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFactory$DiagramEditingDomain.postcommit(DiagramEditingDomainFactory.java:214)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.deactivate(TransactionalEditingDomainImpl.java:543)
at
org.eclipse.emf.transaction.impl.TransactionImpl.close(TransactionImpl.java:712)
at
org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:474)
at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:155)
at
org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
... 53 more
FUDForum. Page generated in 0.04953 seconds
