Home » Archived » BIRT » change image pressing a button
change image pressing a button [message #727301] Tue, 20 September 2011 16:27 Go to next message
Hi all
in my report I would change an image (enhanced image loaded by a local directory) pressing a button. Do I have to use a javascript? If so could you drop me some core parts?
Thanks a lot
portos
Re: change image pressing a button [message #727649 is a reply to message #727301] Wed, 21 September 2011 14:34 Go to previous messageGo to next message
Are the images on the server or the client. You could always include
two images in a birt report and hide one and display the other using
JavaScript in a text element.
Jason
On 9/20/2011 4:27 PM, rosario portoghese wrote:
> Hi all
> Thanks a lot
> portos
Re: change image pressing a button [message #729043 is a reply to message #727649] Sat, 24 September 2011 17:04 Go to previous messageGo to next message
thanks; Actually I can change the image with a simple javascript.
There is unfortunally another issue: when I run the report under Tomcat with WebViewer I can not run the javascript.
I run http://localhost:8080/WebViewerExample/run?__report=report.rptdesign& I see the report but when I push the button to change imnage I can not get nothing. The script doesnt' start as an allert inserted into javascript doesnt' start as well.
Ideas??
thanks again
portos
Re: change image pressing a button [message #729603 is a reply to message #729043] Mon, 26 September 2011 11:39 Go to previous messageGo to next message
Can you post the report?
Jason
On 9/24/2011 5:04 PM, rosario portoghese wrote:
> Hi thanks; Actually I can change the image with a simple javascript.
> with WebViewer I can not run the javascript. I run
> Ideas??
> thanks again
> portos
Re: change image pressing a button [message #730138 is a reply to message #729603] Tue, 27 September 2011 13:15 Go to previous messageGo to next message
Hi Jason
I tried to load my report but upload file does not work: probabily it is my connection...I don't know.
Anyway I found that only Firefox has problems with webviewer while Chrome and IE run correctly the javascripts in my report.
Probabily it is due some settings in my firefox.
Have you already faced this problem?
portos
Re: change image pressing a button [message #730161 is a reply to message #730138] Tue, 27 September 2011 14:20 Go to previous messageGo to next message
I have not seen the error. Can you email me the report at
jasonweathersby at windstream dot net?
Jason
On 9/27/2011 1:15 PM, rosario portoghese wrote:
> Hi Jason
> Thanks
> portos
Re: change image pressing a button [message #731411 is a reply to message #730161] Fri, 30 September 2011 17:40 Go to previous messageGo to next message
Hi Jason
I wrote this code
<script type="text/javascript">
function Img_modify(){
alert("cc1")
window.document.image[1].src="HZ2.jpg";
</script>
I recall this script from a button, but the script seems do not work:
the alert window appears correctly but the image 1 disappears and the image HZ2 doesn't appear.
The image HZ2.jpg is in the same folder of rptdesign file.
Do you see some mistake or some not right behavior?
Portos
Re: change image pressing a button [message #731923 is a reply to message #731411] Mon, 03 October 2011 09:47 Go to previous messageGo to next message
This is because this is client side script and it does not know where
the image file is located. Try using:
alert("cc1")
window.document.image[1].src=<value-of>reportContext.getResource("HZ2.jpg");</value-of>;
</script>
The value-of tag will be resolved at generation time, before sending to
the client.
Jason
On 9/30/2011 5:40 PM, rosario portoghese wrote:
> Hi Jason
> I wrote this code
> alert("cc1")
> </script>
> The image HZ2.jpg is in the same folder of rptdesign file. Do you see
> Thanks
> Portos
Re: change image pressing a button [message #731926 is a reply to message #731411] Mon, 03 October 2011 09:47 Go to previous messageGo to next message
alert("cc1")
</script>
the client.
Jason
> Hi Jason
> I wrote this code
> alert("cc1")
> </script>
> Thanks
> Portos
Re: change image pressing a button [message #732110 is a reply to message #731923] Mon, 03 October 2011 18:55 Go to previous messageGo to next message
Hi Jason
thanks for your help.
I tried your suggestion but the result doesn't change; my script now is:
alert("cc1")
alert("<value-of>reportContext.getResource("HZ2.jpg")</value-of>")
window.document.image[1].src="<value-of>reportContext.getResource("HZ2.jpg")</value-of>"
</script>
<input type="button" onclick="Img_modify()" value = "Day1">
I get correctly the path for the file HZ2.jpg (in the alert I read: file:/C:/user/portos/report/image/HZ2.jpg) but the image doesn't change.
Probabily the object window.document.image[1] is not the right object to modify the image.
Is the image modified oncreate or onrendering phase?
Have you seen some report changing some image by some command (like a button)?
Thanks again for your precious help.
Re: change image pressing a button [message #732352 is a reply to message #732110] Tue, 04 October 2011 10:50 Go to previous messageGo to next message
One thing to try is to use the bookmark property on the image element.
Add a bookmark with the expression "myimage"; This will give your image
in the emitted html an id="myimage" . You can then use
document.getElementById to get a client side handle on the image.
alert("cc1")
alert(document.getElementById('myimage').src)
document.getElementById('myimage').src="/WebViewer/myresources/green.png"
</script>
The issue with using the get resource is that it returns a file path not
a url. So if your resource folder is deployed under the viewer in
myresources you use the example above to locate client side the url for
the image.
Note that this will not work in the designer but should work when the
report is deployed.
Jason
> alert("cc1")
> </script>
Re: change image pressing a button [message #733870 is a reply to message #732352] Wed, 05 October 2011 16:12 Go to previous messageGo to next message
Hi Jason
last update of my script based on your sugestions is:
alert("cc1")
alert(document.getElementById("myimg").src)
document.getElementById("myimg").src="<value-of>reportContext.getResource("HZ2.jpg")</value-of>"
</script>
<input type="button" onclick="Img_modify()" value = "Summary information">
This script works when I run the report in HTML view (Run->view report->HTML), but when I run in chrome the url:
http://localhost:8080/WebViewerExample/frameset?__report=new_report_5.rptdesign
I get correctly the alert windows but the image (an embedded image) does not change in HZ2.jpg, and the report remain with the same page.
Maybe I am wrong using embedded images?
Maybe I have to use a images database.
portos
Re: change image pressing a button [message #733886 is a reply to message #733870] Wed, 05 October 2011 16:54 Go to previous messageGo to next message
The reportContext.getResource call is going to return a file url which
may not work. Try the approach I put in the last post.
Jason
On 10/5/2011 4:12 PM, rosario portoghese wrote:
> Hi Jason
> alert("cc1")
> </script>
> Maybe I am wrong using embedded images? Maybe I have to use a images
> database.
> Thanks
> portos
Re: change image pressing a button [message #733888 is a reply to message #733886] Wed, 05 October 2011 16:58 Go to previous messageGo to next message
BTW when you say embedded image do you mean it is embedded in the report
or is it getting the image from the resource folder?
Jason
> Jason
>> Hi Jason
>> alert("cc1")
>> </script>
>> information">
>> database.
>> Thanks
>> portos
Re: change image pressing a button [message #733896 is a reply to message #733888] Wed, 05 October 2011 17:58 Go to previous messageGo to next message
Hi Jason
for embeded image I mean just that when a have to select the image I use embedded image option.
BTW I trie also this script:
document.getElementById('myimg').src="C:/Users/portos/sviluppo/report/images/Tulips.jpg"
</script>
and as usual it works when I run it as Run->Report View-> HTML while in birt viewer (http://localhost:8080/WebViewerExample/frameset?__report=new_report_5.rptdesign) it does not work (the image does not change).
portos
Re: change image pressing a button [message #734090 is a reply to message #733896] Thu, 06 October 2011 11:47 Go to previous messageGo to next message
Can you try to copy the Tulips.jpg to the WebViewerExample folder under
a directory like images and then change the source to
document.getElementById('myimg').src="images/Tulips.jpg"
Note this will not work in the designer only deployed.
Jason
On 10/5/2011 5:58 PM, rosario portoghese wrote:
> Hi Jason
> </script>
> birt viewer
> portos
Re: change image pressing a button [message #734569 is a reply to message #734090] Sat, 08 October 2011 13:07 Go to previous messageGo to next message
Your last tip does not work.
I have no more idea.
May I send it to you by email? I can not attach the rptdesign file because it is larger than 2Mb.
It is very simple example just to change the image (window standard images) pressing a button.
Thank
portos
Re: change image pressing a button [message #734973 is a reply to message #734569] Mon, 10 October 2011 10:35 Go to previous message
Sure my email is jasonweathersby at windstream dot net.
Jason
On 10/8/2011 1:07 PM, rosario portoghese wrote:
> Hi
> Your last tip does not work. I have no more idea.
> Thank
> portos
Previous Topic:dynamic height & width for birt:viewer in jsp
Next Topic:new chart type : rectangle chart
Current Time: Sun Nov 09 07:09:36 EST 2025
Powered by FUDForum. Page generated in 0.18160 seconds
