Home » Archived » BIRT » BIRT 3.7(Images on the runtime version)
BIRT 3.7 [message #723918] Fri, 09 September 2011 17:05 Go to next message
Hi All
I have a small problem with a report that has an image on the header
When I run the report on my development environment using the viewer I can see the image, actually I see the image on all the different outputs.
Then I transferred it to my run time environment (tomcat)
I don't see the image using the viewer , I see the image when the output is PDF or Word
I don't see the image when the output is html or excel.
Any ideas why this is happening ?
Thanks in advance
Re: BIRT 3.7 image [message #733846 is a reply to message #723918] Wed, 05 October 2011 15:00 Go to previous messageGo to next message
Hi all
I just update my run time version to 3.71, but still is happening.
On my preview designer environment I can see the image, even when I run it with the viewer.
I transfer my report to my tomcat server, then I see the image only when the output is PDF
The image is on the master page on the header .
Thanks for any tip.
Re: BIRT 3.7 image [message #733861 is a reply to message #733846] Wed, 05 October 2011 15:48 Go to previous messageGo to next message
What type of expression do you use for the image item?
Can you post the design?
Jason
On 10/5/2011 3:00 PM, JulioC wrote:
> Hi all
> it with the viewer.
> the output is PDF
> Thanks for any tip.
Re: BIRT 3.7 image [message #733866 is a reply to message #733846] Wed, 05 October 2011 16:06 Go to previous message
Never mind
I found what the problem was.
Just in case some one come across with the same problem
1. I had the image referenced as URI with this javascript
this.URI = "file:///etc/cbn/birt/config/images/myimage.png";
That generates this in the xml file
<property name="source">url</property>
<expression name="uri" type="javascript">this.URI = "file:///etc/cbn/birt/config/images/myimage.png";</expression>
</image>
to fix the problem I referenced the image as a "imge file in shared resources" instead
<property name="source">file</property>
</image>
With the last approach I see the image in any output format
Previous Topic:View reports in xls
Next Topic:Cannot create a data set
Current Time: Sun Jul 27 16:24:40 EDT 2025
Powered by FUDForum. Page generated in 0.03050 seconds
