Event for newly created Projects [message #733505] |
Tue, 04 October 2011 17:53  |
Hello all,
I would like my tool to perform a task each time a new project having a
particular nature is *created*. This needs to include at least the
following scenarios:
* Project created using a "New Project" wizard
* Project imported into workspace for first time using "Import Existing
Project" wizard
* Project imported from CVS, Git or other source control.
To this end, I have written an IResourceListener and registered it with
the workspace. I expected to receive a ResourceEvent containing a delta
for the IProject with kind=ADDED and flags=OPEN. Furthermore I expected
that subsequent changes to files in the project would give me deltas of
kind=CHANGED against the project... i.e. I would never see the
ADDED/OPEN delta again for the same project.
However what actually happens is I get ADDED/OPEN events *many* times
against the project. I receive at least 5 such events in quick
succession during an "Import Existing Project" operation, and then I
keep getting them on subsequent changes inside the project. Eclipse even
gives me ADDED/OPEN events during startup, on all the projects in the
workspace!
Could somebody give me a hint what is going on here? Is there a better
way to be notified exactly once when a project is created?
Many thanks,
Neil
Re: Event for newly created Projects [message #734968 is a reply to message #733505] |
Mon, 10 October 2011 10:19  |
On 04.10.2011 23:53, Neil Bartlett wrote:
> Hello all,
> a particular nature is *created*. This needs to include at least the
> Existing Project" wizard
> with the workspace. I expected to receive a ResourceEvent containing a
> delta for the IProject with kind=ADDED and flags=OPEN. Furthermore I
> expected that subsequent changes to files in the project would give me
> deltas of kind=CHANGED against the project... i.e. I would never see
> the ADDED/OPEN delta again for the same project.
> even gives me ADDED/OPEN events during startup, on all the projects in
> the workspace!
The add event is also sent when folders and files are added you need to
check whether the delta's resource is a project and whether the delta's
kind is IResourceDelta.ADDED.
Dani
> Many thanks,
> Neil
FUDForum. Page generated in 0.28488 seconds
