Using GMF without code generation [message #731823] |
Mon, 03 October 2011 04:26  |
Hi everyone.
I have tried using GMF a number of times but never managed to do so. The
most problematic aspect I found was that the model transformation are in
only one direction, so when I had my model wrong things just could not
evolve... And also the code generated by GMF was simply unreadable.
But still, GMF has very nice graphic properties that are missing from GEF
and I was wondering if there is ANY way to work with GMF like it is done
in GEF (only programming with no models/transformations/etc - except
obviously for the EMF model which is a must).
Vainolo
Re: Using GMF without code generation [message #733636 is a reply to message #733485] |
Wed, 05 October 2011 05:06  |
On 04/10/2011 23:16, Vainolo wrote:
>> On 03/10/2011 10:26, Vainolo wrote:
>>> Hi everyone.
>> Please open bug reports and, if you can, provide contributions to
>> GMF-Tooling to make it better.
>> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMP
> Before I start reporting bugs I would like to learn more about the
> framework but sadly have found little documentation. Can you give me any
> pointers?
http://wiki.eclipse.org/Graphical_Modeling_Framework
>> GMF = GEF + EMF. GMF requires an EMF model, and is efficient to deal
>> with EMF model. It is a mature API that you can obviously use to write
>> your own editor code.
>> Then, just do it ;)
> It is not only GEF+EMF. There seems to be a lot of extra complexity doing
> the connections that has been really hard for me to understand. Again,
> any pointers? The tutorials in the web are a bit outdated...
Without details, I can't help you, but there is probably something
helpful in the wiki.
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
FUDForum. Page generated in 0.11269 seconds
