Home » Language IDEs » C / C++ IDE (CDT) » CDT Debugging / MySQL Setup ?
CDT Debugging / MySQL Setup ? [message #732169] Tue, 04 October 2011 02:34
So far, this is the only guide I've found detailing debugging MySQL under Eclipse.
forge.mysql.com/wiki/Eclipse/CDT_on_Linux_and_Mac_OS_X
This is outdated by a long time. The GUI of Europa has changed since Indigo ( my version) and the sources in the guide are no longer available to download. I've been trying to build the MySQL Cluster sources following this guide, thinking the same process should apply. Eclipse seems unable to build any binaries. Not sure why. If anyone follows the guide, I'm stuck at the step "Create debug profile". There should be binaries to debug, but I don't have any. Could someone help me get this compiled on Eclipse so I can debug?
The guide is meant to explain debugging using the CDT, with MySQL's code as an example. However, I'd like to debug the MySQL code as well.
Previous Topic:Problem with headers
Next Topic:Terminated Error Messege
Current Time: Wed Jul 30 14:19:28 EDT 2025
Powered by FUDForum. Page generated in 0.03414 seconds
