Home » Archived » Riena » submodule and foreach
submodule and foreach [message #731929] Mon, 03 October 2011 09:57 Go to next message
I'm trying to use loops as described on
http://wiki.eclipse.org/Riena_Navigation#Loops
But I'm quite lost:
- only "subModule" elements are taken in account;
"submodule" and "foreach" are ignored.
- the "subModule" element doesn't have "typeId" and "instanceId" attributes
but only "nodeId" one: how can I specify its "instanceId" part?
Is there any full exemple using loops?
Pierre
Re: submodule and foreach [message #733441 is a reply to message #731929] Tue, 04 October 2011 14:09 Go to previous messageGo to next message
Am 03.10.11 15:57, schrieb atao:
> But I'm quite lost: - only "subModule" elements are taken in account; "submodule" and "foreach" are ignored.
> Pierre
We discussed that today and believe that the foreach loop used to be in the documentation of the assembly schema (the
first version). Now that we use assembly2 with a different schema, that xml part was removed from the schema because we
just it was first not helpful and because we werenot sure that it ever worked......
Its an oversight that it is still on the wiki page. If you want a for each loop you have to write an assemble (java
code) and iterate in there.....
hope that helps
christian
Re: submodule and foreach [message #743633 is a reply to message #733441] Fri, 21 October 2011 12:19 Go to previous message
Christian,
Thank you for your answer.
Pierre
Previous Topic:The horizontal scrollbar is not visible! Why?
Next Topic:to change language after starting an application
Current Time: Sat Jul 26 18:50:42 EDT 2025
Powered by FUDForum. Page generated in 0.05927 seconds
