Home » Eclipse Projects » Remote Application Platform (RAP) » Re: Understanding the RWT SettingStore
Re: Understanding the RWT SettingStore [message #731277] Fri, 30 September 2011 09:14 Go to next message
Vlad,
you can override the default working directoy of the FileSettingStore.
If you specify the FileSettingStore#FILE_SETTING_STORE_DIR init
parameter in your web.xml, it should use the directory given there.
HTH
Rüdiger
On 30.09.2011 15:00, vlad crc wrote:
> I'm experiencing an issue when using ISettingStore.
> I have a RAP application which at some point stores some data with the
> default ISettingStore. I package the application in an EAR and deploy it
> to a JBoss. I use the application and on the server side I can see the
> file created by ISettingStore here:
> d:\projects\jboss-server\1\server\dorun\work\jboss.web\localhost\pisgui-2.0.0\eclipse\workspace\.metadata\.plugins\org.eclipse.rap.ui\org.eclipse.rwt.service.FileSettingStore\1307519451218_0
> But if I stop JBoss the whole folder
> "d:\projects\jboss-server\1\server\dorun\work\jboss.web\localhost\pisgui-2.0.0\eclipse\workspace"
> is deleted, which is bad because the setting store file is deleted so
> the aim of persisting settings is vanished.
> Perhaps there's something I'm missing ? Or it's a bug ?
> Best regards,
> Vlad Crc
Rüdiger Herrmann
Twitter: @EclipseRAP
Re: Understanding the RWT SettingStore [message #731903 is a reply to message #731277] Mon, 03 October 2011 08:49 Go to previous messageGo to next message
Thanks Rüdiger, this is helpful.
However I am still wondering, is this behavior normal ? Who deletes that folder, RAP or JBoss ?
Re: Understanding the RWT SettingStore [message #731950 is a reply to message #731903] Mon, 03 October 2011 10:40 Go to previous messageGo to next message
vlad crc wrote on Mon, 03 October 2011 08:49
Most likely JBoss. We use Tomcat, but it similarly deletes it's working directory when redeploying apps.
Re: Understanding the RWT SettingStore [message #732003 is a reply to message #731903] Mon, 03 October 2011 12:07 Go to previous message
Vlad,
in short, it is JBoss who deletes the files. The default location for
the setting store is derived from the javax.servlet.context.tempdir
attribute of the servlet context.
This directory is controlled by the servlet engine (in your case the one
that comes with JBoss). We choose this as the default because we can be
sure to have write access to it.
See also the JavaDoc for RWTFileSettingStoreFactory.
Rüdiger
Rüdiger Herrmann
Previous Topic:CSS 3 Themes
Next Topic:[ANN] RAP 1.5 M2, New Protocol
Current Time: Fri Jul 18 22:14:35 EDT 2025
Powered by FUDForum. Page generated in 0.04990 seconds
