Home » Eclipse Projects » Standard Widget Toolkit (SWT) » maximize shell
maximize shell [message #731704] Sun, 02 October 2011 11:38 Go to next message
Originally posted by: Prasanth Ravi
hi i want to know how to control the maximum size of a shell(the main
one in my case).
I currently use this method -->
private Shell sh;
public void controlResized(ControlEvent e) {
Rectangle rt=((Shell) e.widget).getBounds();
if(rt.height>500)
sh.setBounds(rt.x,rt.y, rt.width, 500);
However this results in flickering ,
the shell has the setMinimumsize() , but how do i do it to restrict a
window's height on resizing?
Re: maximize shell [message #731785 is a reply to message #731704] Mon, 03 October 2011 00:17 Go to previous messageGo to next message
Did u try shell.setFullScreen(true)?
[Updated on: Mon, 03 October 2011 00:24] by Moderator
Re: maximize shell [message #731807 is a reply to message #731785] Mon, 03 October 2011 02:53 Go to previous messageGo to next message
On 10/3/2011 9:47 AM, vijay wrote:
> Did u try shell.setFullScren(true)?
i want to limit the size of the shell when the user tries to resize( ie
the shell should have a maximum size).
Re: maximize shell [message #731830 is a reply to message #731807] Mon, 03 October 2011 05:02 Go to previous messageGo to next message
ohh sorry
there is a bug entry for this
https://bugs.eclipse.org/bugs/show_bug.cgi?id=74001
its an old one, re opened again,this seems to be a genuine request and i don't know why it took so long..the fix also seems to be simple,which can be done in
LRESULT WM_GETMINMAXINFO (int /*long*/ wParam, int /*long*/ lParam) {
    LRESULT result = super.WM_GETMINMAXINFO (wParam, lParam);
    if (result != null) return result;
    if (minWidth != SWT.DEFAULT || minHeight != SWT.DEFAULT) {
        MINMAXINFO info = new MINMAXINFO ();
        OS.MoveMemory (info, lParam, MINMAXINFO.sizeof);
        if (minWidth != SWT.DEFAULT) info.ptMinTrackSize_x = minWidth;
        //CHANGE ADD if (minWidth != SWT.DEFAULT) info.ptMaxTrackSize_x = maxWidth;
        if (minHeight != SWT.DEFAULT) info.ptMinTrackSize_y = minHeight;
        //CHANGE ADD if (minWidth != SWT.DEFAULT) info.ptMaxTrackSize_y = maxHeight;
        OS.MoveMemory (lParam, info, MINMAXINFO.sizeof);
        return LRESULT.ZERO;
    return result;
if the fix is urgent you can download the development release of the SWT and merge the related changes to rebuild SWT(may lead to more problems)
[Updated on: Mon, 03 October 2011 05:04] by Moderator
Re: maximize shell [message #731858 is a reply to message #731830] Mon, 03 October 2011 06:40 Go to previous message
thnx for the code Smile
merging the changes however seems like an extreme step and since im new to SWT.. i don't want to break anything i can't fix considering it's SWT internals.
Re: maximize shell [message #731861 is a reply to message #731830] Mon, 03 October 2011 06:23 Go to previous message
On 10/3/2011 2:32 PM, vijay wrote:
> ohh sorry
> don't know why its taking so long..the fix also seems to be simple,which
> can be done in
> maxHeight;
> return result;
thnx for the code .. i'll try it though i'm new to SWT. Meanwhile i
think i'll try to change so that i don't require that functionality and
i really don't want to go into the internals of SWT yet.
Re: maximize shell [message #731862 is a reply to message #731830] Mon, 03 October 2011 06:24 Go to previous message
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731863 is a reply to message #731830] Mon, 03 October 2011 06:25 Go to previous message
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731864 is a reply to message #731830] Mon, 03 October 2011 06:23 Go to previous message
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731865 is a reply to message #731830] Mon, 03 October 2011 06:24 Go to previous message
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731866 is a reply to message #731830] Mon, 03 October 2011 06:25 Go to previous message
> ohh sorry
> can be done in
> maxHeight;
> return result;
Re: maximize shell [message #731867 is a reply to message #731830] Mon, 03 October 2011 06:40 Go to previous message
thnx for the code :)
Previous Topic:is it possible to calculate a list index from a mouse point
Next Topic:Change SWT List selection color
Current Time: Sun Jul 27 03:46:30 EDT 2025
Powered by FUDForum. Page generated in 0.05243 seconds
