Home » Archived » BIRT » skip ODA lib script in design time (skip ODA lib script in design time )
skip ODA lib script in design time [message #731826] Mon, 03 October 2011 04:52 Go to next message
Hello i Have this script in my Library on (before open) ODA
importPackage( Packages.java.lang );
importPackage( Packages.java.util );
importPackage( Packages.javax.servlet.http);
httpServletReq = reportContext.getHttpServletRequest();
session = httpServletReq.getSession();
if ( reportContext.getHttpServletRequest().getParameter("urlB") != null &&
reportContext.getHttpServletRequest().getParameter("usrB") != null &&
reportContext.getHttpServletRequest().getParameter("pasB") != null
this.setExtensionProperty("odaURL", reportContext.getHttpServletRequest().getParameter("DatabaseUrl"));
this.setExtensionProperty("odaUser", reportContext.getHttpServletRequest().getParameter("DatabaseUserName"));
this.setExtensionProperty("odaPassword",reportContext.getHttpServletRequest().getParameter("DatabasePassword"));
if ( reportContext.getHttpServletRequest().getParameter("DatabaseJndi") != null)
// set the birt variable jndi to the jndi url parameter
this.setExtensionProperty("odaJndiName", reportContext.getHttpServletRequest().getParameter("DatabaseJndi"));
if ( session.getAttribute("sessionJndi") != null &&
session.getAttribute("sessionJndiPrivilege") != null )
// if all of this fail the birt report will try to execute with the development variables set on the report it self.
true;
it works fine on the web container getting the jndi connection from the session, but in design (Eclipe ou BIRT RCP DESIGNER ) time when on the data set - query the output columns it crash.
Of course because of the reportContext.getHttpServletRequest not available in design time on the eclipse.
Can some one please help me find a way of knowing when i'm in design time (ECLIPSE BIRT RCP DESIGNER) and skip this javascipt block , and not in the web container ?
Thanks in advance
Paulo Costa
Re: skip ODA lib script in design time [message #731953 is a reply to message #731826] Mon, 03 October 2011 10:42 Go to previous messageGo to next message
Paulo,
Try wrapping in an if with this statement:
if(
!reportContext.getHttpServletRequest().getAttribute("attributeBean").isDesigner()){
Jason
> session = httpServletReq.getSession(); if (
> != null)
> true;
> Thanks in advance
> Paulo Costa
Re: skip ODA lib script in design time [message #731994 is a reply to message #731953] Mon, 03 October 2011 11:54 Go to previous messageGo to next message
index.php/fa/4128/0/Hello Jason.
It does work you can see error message on atach file.
I have found on this url a similar if not the same problem, please take a look at
http://www.birt-exchange.org/org/forum/index.php/topic/21126-connection-profile-url/ on the post started at 21 December 2010 - 01:20 PM
thank you very much
Paulo
  • Attachment: eclipse.tiff
    (Size: 184.82KB, Downloaded 1128 times)
Re: skip ODA lib script in design time [message #733879 is a reply to message #731994] Wed, 05 October 2011 16:42 Go to previous messageGo to next message
Paulo,
Did you managed to solve this issue?
Taras
Re: skip ODA lib script in design time [message #733979 is a reply to message #733879] Thu, 06 October 2011 03:51 Go to previous messageGo to next message
Good Morning Taras.
No I did not find a solution yet.
I'm waiting for help.
Do you have any idea about it ?
Regard
Paulo Costa
Re: skip ODA lib script in design time [message #734034 is a reply to message #733979] Thu, 06 October 2011 08:51 Go to previous messageGo to next message
Yesterday I found your post, which is very similar to one I had before and you already mentioned it (link to birt-exchange).
I devoted some time yesterday investigating this issue and found out the solution which works.
I found out that when error happens the
reportContext.getClass().getName()
is different.
When reportContext class is
org.eclipse.birt.report.data.adapter.api.script.ReportContextObject
then I get the exception,
and when reportContext class is
org.eclipse.birt.report.engine.script.internal.ReportContextImpl
then everything is fine and we can safely use reportContext methods.
Maybe there is other elegant way to fix this, until then
adding some more checks leads to working code without errors.
// Packages.java.lang.System.out.println("---- reportContext class name ----");
// Packages.java.lang.System.out.println(reportContext.getClass().getName());
// Packages.java.lang.System.out.println("-------------- END ---------------");
// OK - "org.eclipse.birt.report.engine.script.internal.ReportContextImpl"
// FAIL - "org.eclipse.birt.report.data.adapter.api.script.ReportContextObject"
if(reportContext.getClass().getName() != "org.eclipse.birt.report.data.adapter.api.script.ReportContextObject")
    // check if reportContext contains HttpServletRequest
    if (reportContext.getAppContext().containsKey('BIRT_VIEWER_HTTPSERVET_REQUEST')) {
        var request = reportContext.getHttpServletRequest();
        // check if request is valid
        if (request != null) {
            if (!request.getAttribute("attributeBean").isDesigner()) {
                var myresourcefolder = reportContext.getDesignHandle().getResourceFolder();
                this.setExtensionProperty("OdaConnProfileStorePath", myresourcefolder+"/profilestore.xml");
                this.setExtensionProperty("OdaConnProfileName", params["rpStrConnProfile"].value);
I hope you can easily modify my example to resolve your issue.
Let me know if this helps.
Taras
Re: skip ODA lib script in design time [message #734093 is a reply to message #734034] Thu, 06 October 2011 12:11 Go to previous messageGo to next message
When are you getting this type:
Specifically what script and how are you running it?
Jason
> reportContext.getClass().getName() is different.
> org.eclipse.birt.report.data.adapter.api.script.ReportContextObject then
> org.eclipse.birt.report.engine.script.internal.ReportContextImpl then
> // FAIL -
> "org.eclipse.birt.report.data.adapter.api.script.ReportContextObject") {
> // check if reportContext contains HttpServletRequest if
> Regards,
> Taras
Re: skip ODA lib script in design time [message #734112 is a reply to message #734093] Thu, 06 October 2011 13:51 Go to previous messageGo to next message
Hi Jason,
This error happens when I edit dataSET in library.
The script is used in "beforeOpen" of dataSOURCE in the same library.
Edit dataset means: Open dataset, press "preview results" then "OK".
When you press OK, you will get
possibly several times in a row.
Re: skip ODA lib script in design time [message #734118 is a reply to message #734112] Thu, 06 October 2011 14:09 Go to previous messageGo to next message
Understood. I do not see an easy way around this.
On 10/6/2011 1:51 PM, Taras Kopets wrote:
> Hi Jason,
Re: skip ODA lib script in design time [message #734353 is a reply to message #734112] Fri, 07 October 2011 10:18 Go to previous message
Hi Taras, good afternoon.
I Want yo say that your suggestion worked like a charm !!!
Could be not the a beautiful code but IT WORKED thank you very much.
Also that you Jason as well.
Paulo Costa
CLOSED
Previous Topic:BIRT Bug 202330 - [Crosstab improvements] Ability to put headers for dimensions on crosstabs
Next Topic:Decimal to Hours:Minute conversion
Current Time: Sat Jul 26 02:40:49 EDT 2025
Powered by FUDForum. Page generated in 0.24887 seconds
