Home » Newcomers » Newcomers » Universal tree-based code editor with custom tree node sub menus(tree-based editor, outliner, model tree, code browser, emf, rcp, gmf, dsl, xtext, JFace text, JFace tree, model tree, partitioning, tree node context menu, eclipse, stand alone, user defined language)
Universal tree-based code editor with custom tree node sub menus [message #730819] Thu, 29 September 2011 05:01 Go to next message
Hi together,
I am new to eclipse and would like to have a universal tree-based text editor. Could you please give me hints if something like this already exists or which components I could use / tutorials I can start with. Eclispe seems to offer a lot of possibilities to realize such a thing. I am somehow lost in these possibilies and it would be very nice if you could give me some orientation.
Here is my vision:
- Code editor with two views: a tree-outline and a script window.
- If I change the code (e.g. add a new function), the outline is automatically updated.
- If I change the tree (add new child nodes ect.), the code is updated.
- Each tree node has a context menu (shown with right mouse click) that depends on the type of the node.
- There are external files that define:
+ The grammar of the programming language / the tree node types
+ The context menus of the tree nodes
+ The actions of the tree node menu items
- The tree context menus would make it very easy to learn the user defined programming language
- It should be a stand allone application (maybe rcp that can be extended with new plugins for custom languages, plugins for graphical views (VTK) ect.)
An application example would be the modelling of geometries. The text view would show following code:
Geometry 1
Name = "BaseGeometry"
Rectangle 1
Name = "Base Rectangle"
Coordinates = [0,0, 100, 100]
End
Rectangle 2
Name = "Extra Rectangle"
Coordinates = [100,100, 10, 10]
End
End
The tree-outline would show a tree representation of this code.
The tree node "Geometry1" would have a sub menu with following options:
+ Add rectangle
+ Add circle
+ Add triangle
+ Copy
+ Delete
+ Paste
+ Help
The tree node "Base Rectangle" would have a sub menu with
+ Edit
+ Copy
+ Delete
+ Help
The "Edit" action of the "Base Rectange" tree-node context menu would show a dialog where the coordinates of the rectangle can be entered.
(The root node would have entries like "Add Geoemtry" ect.)
The "univeral" tree-based editor could also be used as XML editor, Java editor, editor for finite elment simulation scripts, ... if the external grammar-, action- ect. files are set accordingly.
Sunny regards,
Stefan
[Updated on: Mon, 03 October 2011 07:29] by Moderator
Re: Universal tree-based code editor with custom tree node sub menus [message #730922 is a reply to message #730819] Thu, 29 September 2011 10:34 Go to previous messageGo to next message
Have a look at the XText project. It allows you to define your own grammar and then have the editors generated for you automatically.
Re: Universal tree-based code editor with custom tree node sub menus [message #730937 is a reply to message #730922] Thu, 29 September 2011 11:09 Go to previous messageGo to next message
The XText project allows to display the code as tree. Does it also support context menus for the tree that depend on the node type and changes of the code with tree actions? I could not find an example for that.
[Updated on: Thu, 29 September 2011 11:12] by Moderator
Re: Universal tree-based code editor with custom tree node sub menus [message #731546 is a reply to message #730937] Sat, 01 October 2011 13:01 Go to previous messageGo to next message
Any more suggestions?
Re: Universal tree-based code editor with custom tree node sub menus [message #731554 is a reply to message #731546] Sat, 01 October 2011 13:30 Go to previous messageGo to next message
I don't think there's anything else that even comes close to what you're
asking about.
Re: Universal tree-based code editor with custom tree node sub menus [message #731648 is a reply to message #731554] Sun, 02 October 2011 04:52 Go to previous messageGo to next message
Ok, thank you. So I know I have to try xtext as starting point.
Re: Universal tree-based code editor with custom tree node sub menus [message #734711 is a reply to message #731648] Sun, 09 October 2011 08:47 Go to previous messageGo to next message
Here is finally a "proof of principle" example based on xtext:
- The outline includes a dynamic menu.
- It also has custom icons that depend on the type of the node.
- The actions of the menu modify the source code.
- The zipped example workspace includes a rcp product to produce a stand allone text editor.
http://matameko.wikispaces.com/file/view/mydsl.png/271471374/mydsl.png
http://www.file-upload.net/download-3853661/workspace.zip.html
Thanks a lot to the xtext developers and all folks here answering my annoying questions! Smile
[Updated on: Thu, 03 November 2011 09:51] by Moderator
Re: Universal tree-based code editor with custom tree node sub menus [message #832019 is a reply to message #734711] Thu, 29 March 2012 12:54 Go to previous messageGo to next message
Could you upload it again, that would be _really_ helpful. Thanks!
Re: Universal tree-based code editor with custom tree node sub menus [message #833624 is a reply to message #832019] Sat, 31 March 2012 16:05 Go to previous messageGo to next message
You can find it here:
www.eclipse.org/forums/index.php/m/754563/#msg_754563
Re: Universal tree-based code editor with custom tree node sub menus [message #837538 is a reply to message #833624] Thu, 05 April 2012 16:07 Go to previous message
Thanks. Looks good.
Previous Topic:Error launching Eclipse
Next Topic:Need Help for Total Dummies
Current Time: Wed Jul 23 19:58:34 EDT 2025
Powered by FUDForum. Page generated in 0.10193 seconds
