Home » Eclipse Projects » JFace » Listen to selection changes in properties view
Listen to selection changes in properties view [message #507948] Fri, 15 January 2010 04:48 Go to next message
How can I add a listener (and which one) to listen to selection changes in the default properties view. There will no modification, just a selection change.
I tried the IPropertyChangeListener, but this does't seems to work.
mnhg
Re: Listen to selection changes in properties view [message #509006 is a reply to message #507948] Thu, 21 January 2010 00:37 Go to previous messageGo to next message
This problem ist still open. I even tried to get the tree inside the view and listen to its selection change. This works so far, but there ist nur way to get back from a tree item to its property source or the original object in the view.
I really need some suggestions, otherwises I have to implement my own property view and this ist not my prefered solution, because i need no other additional feature which would justify to build a new view.
Martin
Re: Listen to selection changes in properties view [message #509389 is a reply to message #507948] Fri, 22 January 2010 05:52 Go to previous messageGo to next message
I found a solution, which seems to work.
First i created my own SelectionProvider to get the selection from my treeviewer and from the propertyview in one provider.
TreeViewer treeViewer=....
MergedSelectionProvider selectionProvider = new MergedSelectionProvider();
treeViewer.addSelectionChangedListener(new ViewerSelectionForwarder(selectionProvider, treeViewer));
getSite().getPage().addSelectionListener(new PropertySelectionForwarder(selectionProvider, treeViewer));
getSite().setSelectionProvider(selectionProvider);
public class MergedSelectionProvider implements ISelectionProvider {
	Set<ISelectionChangedListener> listeners = new HashSet<ISelectionChangedListener>();
	IStructuredSelection selection = new StructuredSelection();
	public void addSelectionChangedListener(ISelectionChangedListener listener) {
		listeners.add(listener);
	public void removeSelectionChangedListener(
		// listeners.remove(listener);
		// Not allowed do remove any listener, otherwise nobody listen to the property view
	public ISelection getSelection() {
		return selection;
	public void setSelection(ISelection selection) {
		setSelection(this, selection);
	public void setSelection(ISelectionProvider provider, ISelection selection) {
		if (selection != this.selection) {
			this.selection = (IStructuredSelection) selection;
			fireSelectionChanged(new SelectionChangedEvent(provider,
					this.selection));
	private void fireSelectionChanged(final SelectionChangedEvent event) {
		for (final ISelectionChangedListener listener : listeners) {
			SafeRunnable.run(new SafeRunnable() {
				public void run() {
					listener.selectionChanged(event);
The following class only forwards the selection changes of the viewer.
public class ViewerSelectionForwarder implements ISelectionChangedListener {
	MergedSelectionProvider provider;
	Viewer viewer;
	public ViewerSelectionForwarder(MergedSelectionProvider provider,
			Viewer viewer) {
		this.provider = provider;
		this.viewer = viewer;
	public void selectionChanged(SelectionChangedEvent event) {
		provider.setSelection(viewer, event.getSelection());
This class get the selection in the property view directly from the tree control. In my conrete scenario i could get by the name of the tree item and the selected parent element in the viewer to the selected attribute. It's not the nices solution but it's seem to work for my case.
public class PropertySelectionForwarder implements ISelectionListener,
		SelectionListener {
	Set<PropertySheet> properties = new HashSet<PropertySheet>();
	Viewer viewer;
	public PropertySelectionForwarder(MergedSelectionProvider provider,
			Viewer viewer) {
	// Register property view
	public void selectionChanged(IWorkbenchPart part, ISelection selection) {
		if (part instanceof PropertySheet && !properties.contains(part)) {
			PropertySheetPage p = (PropertySheetPage) ((PropertySheet) part)
					.getCurrentPage();
			Tree t = (Tree) p.getControl();
			t.addSelectionListener(this);
			properties.add((PropertySheet) part);
	// selection change in property view
	public void widgetDefaultSelected(SelectionEvent e) { // ignore
	public void widgetSelected(SelectionEvent e) {
		if (!(e.item instanceof TreeItem)
				|| !(viewer.getSelection() instanceof IStructuredSelection)) {
			fireSelection(new StructuredSelection());
			return;
		IStructuredSelection sel = (IStructuredSelection) viewer.getSelection();
		if (sel.size() != 1
				|| !(sel.getFirstElement() instanceof XMLEditorElement)) {
			return;
		TreeItem t = (TreeItem) e.item;
		if (!(t.getData() instanceof PropertySheetEntry)) {
			return;
		XMLEditorElement parent = (XMLEditorElement) sel.getFirstElement();
		PropertySheetEntry pse = (PropertySheetEntry) t.getData();
		XMLEditorAttribute attribute = parent.getAttributeByName(pse
				.getDisplayName());
		fireSelection(new StructuredSelection(attribute));
	private void fireSelection(IStructuredSelection selection) {
		provider.setSelection(selection);
Any opinions, suggestions or error?
Re: Listen to selection changes in properties view [message #731291 is a reply to message #509389] Fri, 30 September 2011 10:27 Go to previous message
This is by design: http://stackoverflow.com/questions/6073869/rcp-selectionservice-question/7611738#7611738
Previous Topic:how to add a status line to org.eclipse.jface.wizard
Next Topic:Wizards + IRunnableWithProgress + Avoiding disabling controls
Current Time: Sat Jul 19 02:40:33 EDT 2025
Powered by FUDForum. Page generated in 0.04580 seconds
