Home » Modeling » M2T (model-to-text transformation) » [acceleo 3] OclInvalid_Class while trying to read an attribute in the model
[acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #730915] Thu, 29 September 2011 10:21 Go to next message
Hi all,
I'm writing my first acceleo generator.
I want to read the values of an attribute which is a List:
[module generate('http://www.eclipse.org/Papyrus/Table/0.8.0/papyrustableinstance','http://www.eclipse.org/EmfFacet/infra/browser/custom/0.8')]
[template public getTableLocalCustomizations(aPapyrusTableInstance : PapyrusTableInstance)]
[file ('stdout', false)][table+'\n'/][/file]
[file ('stdout', false)][table.localCustomizations+'\n'/][/file]
[/template]
It seems that Acceleo does not load the localcustomizations attribute contents (localCustomizations : MetamodelView [1..*]).
The result of the print in the console is as follows:
org.eclipse.emf.facet.widgets.nattable.instance.tableinstance2.impl.TableInstance2Impl@14e6393 (parameter: null, hideEmptyColumns: false, onlyShowCommonColumns: false, description: Table Description)
org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1b4a6c2 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@130129c (name: OclInvalid_Class) (instanceClassName: null) (abstract: false, interface: false))
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #730934 is a reply to message #730915] Thu, 29 September 2011 10:58 Go to previous messageGo to next message
When I do a loop (the collection to iterate is table.localCustomizations)
[for (it : MetamodelView | table.localCustomizations)]
['Customization'+aPapyrusTableInstance.table.localCustomizations->indexOf(it)+'.uiCustom'/]"/>
[/for]
I have this acceleo error:
java.lang.IllegalArgumentException
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.navigateProperty(EcoreEvaluationEnvironment.java:258)
at org.eclipse.ocl.ecore.EcoreEvaluationEnvironment.navigateProperty(EcoreEvaluationEnvironment.java:1)
at org.eclipse.ocl.EvaluationVisitorImpl.visitPropertyCallExp(EvaluationVisitorImpl.java:2088)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitPropertyCallExp(AcceleoEvaluationVisitor.java:1111)
at org.eclipse.ocl.ecore.impl.PropertyCallExpImpl.accept(PropertyCallExpImpl.java:238)
at org.eclipse.ocl.AbstractEvaluationVisitor.visitExpression(AbstractEvaluationVisitor.java:248)
at org.eclipse.ocl.EvaluationVisitorDecorator.visitExpression(EvaluationVisitorDecorator.java:156)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1693)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitExpression(AcceleoEvaluationVisitor.java:999)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoForBlock(AcceleoEvaluationVisitor.java:413)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1656)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoFileBlock(AcceleoEvaluationVisitor.java:396)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1663)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.visitAcceleoTemplate(AcceleoEvaluationVisitor.java:867)
at org.eclipse.acceleo.engine.internal.evaluation.AcceleoEvaluationVisitor.switchExpression(AcceleoEvaluationVisitor.java:1643)
at org.eclipse.ocl.internal.evaluation.QueryImpl.evaluate(QueryImpl.java:152)
at org.eclipse.ocl.ecore.QueryImpl.evaluate(QueryImpl.java:62)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvaluate(AcceleoEngine.java:265)
at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate(AcceleoEngine.java:130)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerateTemplate(AcceleoService.java:860)
at org.eclipse.acceleo.engine.service.AcceleoService.doGenerate(AcceleoService.java:523)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.generate(AbstractAcceleoGenerator.java:175)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.doGenerate(AbstractAcceleoGenerator.java:154)
at org.eclipse.papyrus.table.generation.acceleo.main.Generate.doGenerate(Generate.java:220)
at org.eclipse.papyrus.table.generation.handlers.TableJavaCodeGenerator.runAcceleoTransformation(TableJavaCodeGenerator.java:87)
at org.eclipse.papyrus.table.generation.handlers.GenerateTableHandler$1.doExecuteWithResult(GenerateTableHandler.java:141)
at org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTransactionalCommand.doExecute(AbstractTransactionalCommand.java:247)
at org.eclipse.emf.workspace.AbstractEMFOperation.execute(AbstractEMFOperation.java:150)
at org.eclipse.papyrus.core.utils.GMFtoEMFCommandWrapper.execute(GMFtoEMFCommandWrapper.java:87)
at org.eclipse.emf.common.command.CompoundCommand.execute(CompoundCommand.java:267)
at org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFCommandOperation.java:119)
at org.eclipse.core.commands.operations.DefaultOperationHistory.execute(DefaultOperationHistory.java:513)
at org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.doExecute(WorkspaceCommandStackImpl.java:208)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.papyrus.modelexplorer.handler.AbstractCommandHandler.execute(AbstractCommandHandler.java:150)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
!ENTRY org.eclipse.acceleo.engine 2 2 2011-09-29 16:25:05.382
!MESSAGE Invalid loop iteration at line 221 in Module generate for block for (self.table.localCustomizations). Last recorded value of self was org.eclipse.papyrus.table.instance.papyrustableinstance.impl.PapyrusTableInstanceImpl@1805296 (name: DefaultTable, type: PapyrusDefaultTable, isSynchronized: false).
!STACK 0
org.eclipse.acceleo.engine.AcceleoEvaluationException: Invalid loop iteration at line 221 in Module generate for block for (self.table.localCustomizations). Last recorded value of self was org.eclipse.papyrus.table.instance.papyrustableinstance.impl.PapyrusTableInstanceImpl@1805296 (name: DefaultTable, type: PapyrusDefaultTable, isSynchronized: false).
at generate.generatePlugin(PapyrusTableInstance)(generate.mtl:221)
at generate.generatePlugin(PapyrusTableInstance)(generate.mtl:146)
at generate.generatePlugin(PapyrusTableInstance)(generate.mtl:143)
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #730935 is a reply to message #730915] Thu, 29 September 2011 10:56 Go to previous messageGo to next message
In [file ('stdout', false)][table+'\n'/][/file]
you invoke the 'OCL' operation to compute the string concatenation of
Acceleo's default toString for table and a new lin.
It would be simpler to write
[file ('stdout', false)]table/]
[/file]
In [file ('stdout', false)][table.localCustomizations+'\n'/][/file]
you similarly perform an OCL evaluation of the concatenation of
Acceleo's toString for what is presumably a Collection. I have no idea
what this does, but if at any point something fails you will get
invalid, and probably will get invalid if the Collection is empty too.
The OclInvalid_Class mumbo jumbo is OCL's very klunky way of printing
'invalid'. The new Eclipse OCL pivot implementation has the natural
spelling.
I suggest you use a [for loop to iterate your localCustomizations.
It is very very unlikely that Acceleo has failed to load them, since
that would be a failure in massively widely used EMF code.
Ed Willink
On 29/09/2011 15:21, saadia dhouib wrote:
> Hi all,
> [module
> [/template]
> mailto:org.eclipse.emf.facet.widgets.nattable.instance.tableinstance2.impl.TableInstance2Impl@14e6393
> mailto:org.eclipse.emf.ecore.impl.DynamicEObjectImpl@1b4a6c2 (eClass:
> mailto:org.eclipse.emf.ecore.impl.EClassImpl@130129c (name:
> interface: false))
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #730958 is a reply to message #730934] Thu, 29 September 2011 11:39 Go to previous messageGo to next message
It says you are doing a rubbish navigation.
Your loop is wierd. Why not just
['Customization'+it+'.uiCustom'/]"/>
[/for]
I suspect that aPapyrusTableInstance is bad but without the line numbers
is unhelpful.
Ed Willink
> [/for]
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> self was
> mailto:org.eclipse.papyrus.table.instance.papyrustableinstance.impl.PapyrusTableInstanceImpl@1805296
> !STACK 0
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #731161 is a reply to message #730958] Fri, 30 September 2011 03:27 Go to previous messageGo to next message
Hi Edward,
I have changed my loop to print the contents of the localcustomizations list in the console:
line 143 [template public generatePlugin(aPapyrusTableInstance : PapyrusTableInstance)]
[comment @main/]
line 146 [file ('../plugin.xml', false, 'UTF-8')]
line 211 [file ('stdout', false)][table/][/file]
line 212 [for (it : MetamodelView | table.localCustomizations)]
line 213 [file ('stdout', false)][it/]
line 214 [/file]
[/for]
The table is printed in the console, but I have still errors in the loop:
org.eclipse.emf.facet.widgets.nattable.instance.tableinstance2.impl.TableInstance2Impl@12c70d2 (parameter: null, hideEmptyColumns: false, onlyShowCommonColumns: false, description: Table Description)
!ENTRY org.eclipse.ocl 4 10 2011-09-30 09:18:21.025
!MESSAGE Evaluation failed with an exception: (no message)
!STACK 0
!ENTRY org.eclipse.acceleo.engine 2 2 2011-09-30 09:18:21.181
!MESSAGE Invalid loop iteration at line 212 in Module generate for block for (self.table.localCustomizations). Last recorded value of self was org.eclipse.papyrus.table.instance.papyrustableinstance.impl.PapyrusTableInstanceImpl@a934ec (name: DefaultTable, type: PapyrusDefaultTable, isSynchronized: false).
!STACK 0
org.eclipse.acceleo.engine.AcceleoEvaluationException: Invalid loop iteration at line 212 in Module generate for block for (self.table.localCustomizations). Last recorded value of self was org.eclipse.papyrus.table.instance.papyrustableinstance.impl.PapyrusTableInstanceImpl@a934ec (name: DefaultTable, type: PapyrusDefaultTable, isSynchronized: false).
at generate.generatePlugin(PapyrusTableInstance)(generate.mtl:212)
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #731163 is a reply to message #730958] Fri, 30 September 2011 03:30 Go to previous messageGo to next message
and that is supported, though indeed not the most readable way of doing it.
[Sequence{'a', 'b'} + 'c'/]
does output "abc". Moreover,
[null + 'c'/]
properly outputs "c"...
However, that is with the latest versions of Acceleo. I suspect that you are using one of the versions where we did not (or _could_ not) override OCL's "plus" operation. Which version of Acceleo are you using, under which version of Eclipse?
Laurent Goubet
Obeo
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #731188 is a reply to message #731163] Fri, 30 September 2011 04:17 Go to previous messageGo to next message
Okay, so what fails here is that "localCustomizations" cannot be found. Acceleo (and, transitively, OCL) managed to compile your module properly; which means that at compile time, that eStructuralFeature was found. Yet at runtime, OCL does not manage to find it. This issue is most likely due to OCL not interacting well with EMF Facet.
Ed, the code of EcoreEvaluationEnvironment fails because of the line (or at least I think that this line is the culprit) :
if (etarget.eClass().getEAllStructuralFeatures().contains(property)) {
Why would the compilation work and not the evaluation?
Laurent Goubet
Obeo
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #731210 is a reply to message #731188] Fri, 30 September 2011 05:27 Go to previous messageGo to next message
Hi Laurent,
I'm using:
Eclipse Indigo 3.7.0
Acceleo SDK 3.1.0.v20110607-0602 org.eclipse.acceleo.sdk.feature.group Eclipse Modeling Project
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #731218 is a reply to message #731188] Fri, 30 September 2011 05:55 Go to previous messageGo to next message
It could either be that
line 244: if (target instanceof EObject) fails, i.e target is not an
EObject. Maybe the model does not extend EObject. Maybe a bad navigation
has traversed a Collection or a Tuple or unresolved proxy.
line 247: if
(etarget.eClass().getEAllStructuralFeatures().contains(property)) fails,
i.e. eTarget does not have the required feature; - out of date generated
Java compared to the *.ecore used by the editor/compiler. Or property is
a 'different' property because of our old friend meta-model schizophrenia.
Since navigation to table has succeeded, out of data Java is most
likely, but unwise cross-resource containment with unresolved proxies
might cause any amount of confusing chaos.
Difficult to conclude more than that table.localCustomizations is bad
without single stepping to examine the navigation as it fails.
However regenerating the Java has to be worth a try.
Ed Willink
> Laurent Goubet
> Obeo
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #731254 is a reply to message #731218] Fri, 30 September 2011 07:54 Go to previous messageGo to next message
Does the problem come from acceleo or from the used metamodel ?
I can read the contents of the localcustomizations List using java:
if(customizations != null && !customizations.isEmpty()) {
customFiles = new ArrayList<String>();
for(Iterator<MetamodelView> it = customizations.iterator(); it.hasNext()Wink {
MetamodelView custom = it.next();
System.err.println(custom);
addCustomizationFile(pluginID, uiCustomRelativePath, custom);
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #733610 is a reply to message #731254] Wed, 05 October 2011 04:17 Go to previous messageGo to next message
I can't say for sure where the problem is stemming from. It could be Acceleo, it could be the metamodel ... my guess though is that the issue here is a little more complex, and that we (Acceleo or OCL) are missing something when using EMF Facet-enhanced metamodels. Could you raise a bug against M2T/Acceleo in order to track this issue? We'll have to test the integration between Acceleo and EMF Facet in depth in order to verify this.
Laurent Goubet
Obeo
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #733645 is a reply to message #733610] Wed, 05 October 2011 05:27 Go to previous messageGo to next message
Have you done this?
> raise a
> https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2T&component=Acceleo
Where does EMF Facet come in to this problem? I missed it in the problem
report.
If EMF Facet is modifying meta-models in memory:
I wonder whether EMF is correctly refreshing all cached content.
I doubt that OCL (and consequently Acceleo) is seeing a consistent
meta-model description.
I doubt that Acceleo is seeing the same meta-model in each of its
edit/build/execute phases.
I doubt that the user has provided the facetted meta-model to the tools
correctly.
If augmented meta-models are required in an evaluation context, it is
probably necessary for the augment to be presented as a Complete OCL
document and you probably need the evolving capabilities of the pivot
model to support it. The OMG OCL specification does not indicate how an
OCL AST can evaluate with referredProperty or referredOperation elements
whose targets are not part of any meta-model. The current
Ecore/UML-based OCL implementation uses non-modelled
additionalAttributes and additionalOperations that work while the model
is in memory. Since Acceleo uses OCL to persist these references in its
EMTL, file they cannot possibly work once reloaded for execution. The
new pivot model OCL implementation prototypes a possible OCL 2.4
resolution of the problem in which the complements are modelled and so
can be referenced. EMF facets augments could therefore be represented
either in Concrete Syntax form as a Complete OCL document, or in
Abstract Syntax form as a pivot Package or EPackage with contents to be
merged into any other same-nsURI Package/EPackage.
Ed Willink
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #733967 is a reply to message #733645] Thu, 06 October 2011 03:18 Go to previous messageGo to next message
Ed,
Where does EMF Facet come in to this problem? I missed it in the problem report.
Quite often I see you jumping on "metamodel schizophrenia". It is indeed a cause for concerns ... but not all. The poster here uses a model enhanced with EMF Facet, which can be seen plainly by reading his example module and stack trace. He uses metamodels :
and the "table" object on which he tries to retrieve a property value is an instance of org.eclipse.emf.facet.widgets.nattable.instance.tableinstance2.impl.TableInstance2Impl@14e6393. I am pretty sure the "localCustomizations" property which value he tries to retrieve through Acceleo is one defined through a facet augment; and that would explain why he raises an issue we have never faced. Before trying to give a convoluted answer, the one thing we have to do is to test on our side whether this is a use case we can handle, and if so, how. Only then will we be able to properly answer the question.
Laurent Goubet
Obeo
Re: [acceleo 3] OclInvalid_Class while trying to read an attribute in the model [message #733999 is a reply to message #733967] Thu, 06 October 2011 05:28 Go to previous message
And yet ... I apologize Ed, there is a good possibility that you are right and that this _is_ a case of metamodel schizophrenia... Looking at how papyrus metamodels and customizations through facets are defined, I fear that the URIs are not right.
Saadia, could you provide us with the models you are using for this generation? I did not manage to create a useable sample of my own through papyrus.
Laurent Goubet
Obeo
Previous Topic:[acceleo] @main & invoking generated Java class
Next Topic:[Acceleo 3.1] Template overrides
Current Time: Wed Jul 23 20:29:57 EDT 2025
Powered by FUDForum. Page generated in 0.05173 seconds
