Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Change SWT List selection color
Change SWT List selection color [message #731155] Fri, 30 September 2011 03:01 Go to next message
Hi all,
I wanted to ask whether it's possible to programmatically change the
selection color of an SWT List? Neither the SWT.EraseItem events nor the
JFace IColorProvider interfaces seem to work for Lists. I've seen a very
old post from 2008 stating that changing the selection color of Lists is
indeed not possible but I was hoping that this might have changed in the
meantime :).
Thanks in advance for any help!
Ovidio
Re: Change SWT List selection color [message #731889 is a reply to message #731155] Mon, 03 October 2011 08:07 Go to previous message
This is not possible for List, but can be done for Tree and Table.
SWT.EraseItem event doesn't work for List, works only for Table & Tree.
If you like, you can replace the List with a Table and have a similar UI. The selection color for the Table can be modified using Custom Drawing (see SWT.EraseItem listener in this example snippet 234)
Previous Topic:maximize shell
Next Topic:Can DateTime widget display hours in 24-hour format?
Current Time: Sun Jul 27 03:48:52 EDT 2025
Powered by FUDForum. Page generated in 0.04456 seconds
