Virgo 3.0.1 startu failed error [message #730768] |
Thu, 29 September 2011 02:30  |
Hello friends,
I have currently using virgo web server 2.0.1 in my application it's working fine, but I am move to higher version of virgo 3.0.1 release to using same project it's did not working, following error blow that.
.0' with context path '/samplemiddletier-web'.
[2011-09-29 11:55:12.990] start-signalling-2 <WE0005E> Failed to start web bundle 'samplemiddletier-web' version '0.0.0': consult serviceability/logs/log.log for further details.
[2011-09-29 11:55:12.994] start-signalling-2 <DE0006E> Start failed for bundle 'samplemiddletier-web' version '0.0.0'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:132)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:247)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:294)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:291)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:229)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:143)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedException: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/samplemiddletier-web' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:108)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
... 8 common frames omitted
Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/samplemiddletier-web' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:125)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:91)
... 9 common frames omitted
Please help................thanks
FUDForum. Page generated in 0.08177 seconds
