Home » Eclipse Projects » Eclipse 4 » When Processor method is called ?
When Processor method is called ? [message #731078] Thu, 29 September 2011 17:24 Go to next message
I would like to know Who is responsible by call a Processor and When it is supposed to be called ?
It is possible to invoke a processor by my own code ?
thanks
Cristiano
Re: When Processor method is called ? [message #731082 is a reply to message #731078] Thu, 29 September 2011 17:41 Go to previous message
You are talking about model processors, right? They are invoked by the
ModelAssembler when the model is made up.
The process currently is like this:
* Load the root model (the one you defined in your plugin.xml)
* Launch the processors
* Apply the recorded diff from the last run
If you want to track and modify the model I'd suggest you'll contribute
an Addon.
Tom
Am 29.09.11 23:24, schrieb Cristiano avi:
> thanks
> Cristiano
Previous Topic:Integration of XWT in an e4 application
Next Topic:@Optional doesn't work as I expect
Current Time: Sat Jul 26 06:14:57 EDT 2025
Powered by FUDForum. Page generated in 0.03978 seconds
