Home » Eclipse Projects » EclipseLink » eclipselink generates table on the wrong schema
eclipselink generates table on the wrong schema [message #730638] Wed, 28 September 2011 14:43 Go to next message
hi all.
i have a relation like this
@Entity
@Table(schema="ecf")
public class ImpressoraFiscal implements Serializable{
private static final long serialVersionUID = 6246259319048104042L;
@OneToMany(cascade={CascadeType.ALL}, orphanRemoval=true)
private List<Aliquota> aliquotas = new ArrayList<Aliquota>();
and
@Entity
public class Aliquota implements Serializable {
private static final long serialVersionUID = -1473589350884030504L;
@Id @GeneratedValue(strategy=GenerationType.IDENTITY)
private Long id;
and as you can see, both table are in 'ecf' schema. this kind of relationship generates a table like 'ImpressoraFiscal_Aliquota'. so far, everything is ok
but this is weird: this table 'ImpressoraFiscal_Aliquota' is generated on 'public' schema (i'm using postgre)
is this the expected behavior?
thanks in advanced
Re: eclipselink generates table on the wrong schema [message #730863 is a reply to message #730638] Thu, 29 September 2011 08:09 Go to previous messageGo to next message
The behavior is correct since you are allowing the join table to default on the OneToMany. You'll need to add @JoinTable(schema="ecf") to have it in the same schema.
Alternatively, you can specify a schema default in XML under the <persistence-unit-defaults> to apply to all your tables.
Guy
Re: eclipselink generates table on the wrong schema [message #731049 is a reply to message #730863] Thu, 29 September 2011 14:43 Go to previous message
thank you!
the @JoinTable did the trick!
Previous Topic:eclipselink generates table on the wrong schema
Next Topic:@Embeddable Inheritance
Current Time: Sat Jul 26 08:59:10 EDT 2025
Powered by FUDForum. Page generated in 0.04418 seconds
