Home » Archived » BIRT » OutOfMemory exceptions in birt engine
OutOfMemory exceptions in birt engine [message #729551] Mon, 26 September 2011 09:31 Go to next message
Hello All
We are doing load testing for our reporting engine. Here is our stack
OS - Linux
CPU's - 2 - 2GHz processors
RAM - 3GB
Weblogic - 10.0.2
Java - jrockit_150_17
BIRT - 3.7
We are running simultaneously 5 huge reports (30,000 records each. rptDocument, pdf, excel). Failing with DIFFERENT out of memory errors.
java.lang.OutOfMemoryError: allocLargeObjectOrArray - Object size: 353040, Num elements: 88256
at java.util.ArrayList.ensureCapacity(ArrayList.java:169)
Caused by: java.lang.OutOfMemoryError: nativeGetNewTLA
at org.apache.batik.css.parser.Scanner.getStringValue(Unknown Source)
at org.apache.batik.css.parser.Parser.number(Unknown Source)
We need to run at-least 16 reports in parallel in production. Any pointers on how to tune the code / configuration
[Updated on: Mon, 26 September 2011 10:00] by Moderator
Re: OutOfMemory in birt engine [message #729620 is a reply to message #729551] Mon, 26 September 2011 12:02 Go to previous messageGo to next message
What are your JVM settings? Do you have -XX:MaxPermSize=256M set?
Jason
On 9/26/2011 9:31 AM, sam wrote:
> Hello All
> OS - Linux CPU's - 2 - 2GHz processors
> RAM - 3GB
> Weblogic - 10.0.2
> BIRT - 3.7
> We are running simultaneously 5 huge reports. Failing with DIFFERENT out
> of memory errors.
> Thanks
Re: OutOfMemory in birt engine [message #729816 is a reply to message #729620] Mon, 26 September 2011 23:01 Go to previous messageGo to next message
I have the following in JVM args
-XxcompressedRefs=0 -XXlargeObjectLimit:64k -XXtlaSize:min=64k,preferred=128k -XX:PermSize=128m -XX:MaxPermSize=512m
Re: OutOfMemory in birt engine [message #730006 is a reply to message #729816] Tue, 27 September 2011 09:19 Go to previous messageGo to next message
More Info
Mem Info
MemTotal: 3735296 kB
MemFree: 311840 kB
Buffers: 119728 kB
Cached: 1340652 kB
SwapCached: 0 kB
Active: 2730400 kB
Inactive: 462120 kB
HighTotal: 0 kB
HighFree: 0 kB
LowTotal: 3735296 kB
LowFree: 311840 kB
SwapTotal: 4194296 kB
SwapFree: 4194288 kB
CPU Info
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 29
model name : Intel(R) Xeon(R) CPU X7460 @ 2.66GHz
stepping : 8
cpu MHz : 2659.877
processor : 1
cpu family : 6
model : 29
stepping : 8
cpu MHz : 2659.877
Software
Weblogic - 10.0.2
BIRT - 3.7
[Updated on: Tue, 27 September 2011 09:20] by Moderator
Re: OutOfMemory in birt engine [message #730078 is a reply to message #730006] Tue, 27 September 2011 11:24 Go to previous messageGo to next message
I am not certain this a bug, but we need to track this in bugzilla. Can
you post this info to a bugzilla entry and then post the bug id back here?
Jason
On 9/27/2011 9:19 AM, sam wrote:
> More Info
> Mem Info
> MemFree: 311840 kB
> Buffers: 119728 kB
> Cached: 1340652 kB
> SwapCached: 0 kB
> Active: 2730400 kB
> Inactive: 462120 kB
> HighTotal: 0 kB
> HighFree: 0 kB
> LowFree: 311840 kB
> CPU Info
> processor : 0
> cpu family : 6
> model : 29
> stepping : 8
> cpu MHz : 2659.877
> processor : 1
> cpu family : 6
> model : 29
> stepping : 8
> cpu MHz : 2659.877
> Software
> Weblogic - 10.0.2
> BIRT - 3.7
Re: OutOfMemory in birt engine [message #730252 is a reply to message #730078] Tue, 27 September 2011 21:59 Go to previous messageGo to next message
Logged buzilla entry
359162
Re: OutOfMemory exceptions in birt engine [message #730563 is a reply to message #729551] Wed, 28 September 2011 12:02 Go to previous messageGo to next message
Any pointers if someone worked on similar stuff would be very helpful
Re: OutOfMemory in birt engine [message #730610 is a reply to message #730252] Wed, 28 September 2011 13:16 Go to previous messageGo to next message
If you are using the API, have a look at slide 20 in the BirtMetal ppt
in this dev share entry:
http://www.birt-exchange.org/org/devshare/deploying-birt-reports/1187-eclipsecon-2010-birt-metal-ppt/
Jason
> 359162
> Thanks
Re: OutOfMemory exceptions in birt engine [message #731884 is a reply to message #729551] Mon, 03 October 2011 07:49 Go to previous messageGo to next message
we tried all the options in the BIRTMetal.ppt
Ran out of all the options but still getting OutOfMemory for various reasons
Is BIRT scalable?
Re: OutOfMemory exceptions in birt engine [message #731945 is a reply to message #731884] Mon, 03 October 2011 10:29 Go to previous messageGo to next message
There are a lot of people using BIRT in large scale apps. I will check
with the dev team on this bug.
Jason
> reasons
> Is BIRT scalable?
> Thanks
Re: OutOfMemory exceptions in birt engine [message #732005 is a reply to message #731945] Mon, 03 October 2011 12:38 Go to previous messageGo to next message
I will try to put more info on the errors we are getting by t'rrow.
Re: OutOfMemory exceptions in birt engine [message #733620 is a reply to message #732005] Wed, 05 October 2011 04:39 Go to previous messageGo to next message
I get the following error
at org.eclipse.birt.data.engine.executor.cache.ResultObjectUtil.readData(ResultObjectUtil.java:175)
at org.eclipse.birt.data.engine.executor.cache.disk.DataFileReader.read(DataFileReader.java:104)
at org.eclipse.birt.data.engine.executor.cache.disk.RowFile.readRowFromFile(RowFile.java:248)
at org.eclipse.birt.data.engine.executor.cache.disk.RowFile.fetch(RowFile.java:209)
at org.eclipse.birt.data.engine.executor.cache.disk.DiskCacheResultSet.nextRow(DiskCacheResultSet.java:102)
at org.eclipse.birt.data.engine.executor.cache.disk.DiskCache.next(DiskCache.java:174)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.next(SmartCache.java:155)
at org.eclipse.birt.data.engine.executor.transform.CachedResultSet.next(CachedResultSet.java:436)
at org.eclipse.birt.data.engine.impl.ResultIterator.hasNextRow(ResultIterator.java:569)
at org.eclipse.birt.data.engine.impl.ResultIterator.nextRow(ResultIterator.java:510)
at org.eclipse.birt.data.engine.impl.ResultIterator.next(ResultIterator.java:460)
at org.eclipse.birt.data.engine.impl.ResultIterator.close(ResultIterator.java:969)
at org.eclipse.birt.data.engine.impl.ResultIterator$1.dataEngineShutdown(ResultIterator.java:200)
at org.eclipse.birt.data.engine.impl.DataEngineImpl.shutdown(DataEngineImpl.java:565)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.shutdown(DataRequestSessionImpl.java:509)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.shutdown(AbstractDataEngine.java:348)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.shutdown(DataGenerationEngine.java:151)
at org.eclipse.birt.report.engine.executor.ExecutionContext.close(ExecutionContext.java:480)
at org.eclipse.birt.report.engine.api.impl.EngineTask.close(EngineTask.java:1540)
at org.eclipse.birt.report.engine.api.impl.RunTask.close(RunTask.java:309)
And I have set the following code to the task (as mentioned in the BirtMetal.ppt)
task.getAppContext().put(DataEngine.MEMORY_USAGE, DataEngine.MEMORY_USAGE_CONSERVATIVE);
task.getAppContext().put(DataEngine.DATA_SET_CACHE_ROW_LIMIT, "0");
task.getAppContext().put(DataEngine.MEMORY_BUFFER_SIZE, "2");
Similarly, I set the options for EngineConfig also...
Starting the test with 2 reports in parallel. And will slowly run more reports if everything goes fine.
One report is running fine without any issues. But takes 1hr. FYI, we generate the report and PDF/Excel along with it.
[Updated on: Wed, 05 October 2011 07:40] by Moderator
Re: OutOfMemory exceptions in birt engine [message #733700 is a reply to message #733620] Wed, 05 October 2011 09:09 Go to previous messageGo to next message
2 reports completed successfully. But took 1hr 45m. For 25000 records (report generation/pdf/excel).
will run 3 reports in parallel and see.
Re: OutOfMemory exceptions in birt engine [message #733745 is a reply to message #733700] Wed, 05 October 2011 10:36 Go to previous messageGo to next message
Can you add this data to the bugzilla entry?
Jason
> Thanks
Re: OutOfMemory exceptions in birt engine [message #753514 is a reply to message #729551] Thu, 27 October 2011 10:38 Go to previous message
I think we have got a handle on to this.
We tried a sample report with 60K records and the rptDocument took around 20MB. The actual report with which we load tested was taking around 500MB. Looks clearly that the report was not generated efficiently. One issue could be developing the report in 2.6.2 and running in 3.7. Although I am not sure if this is the reason, I found this as a data point. So we re-developed the report on 3.7 and the rptdocument is not crossing 80MB for 60K rows.
And now we successfully generated 15 reports in parallel. and still going. this is in lower env. Would like to reach the limit and will update all. Just as an FYI, our current reporting env is running max 16 reports in production.
Thanks Jason and the DEV team in helping me out
BIRT ROKCS!!!
Thanks again
Previous Topic:BIRT Report Engine Installation Problem
Next Topic:BIRT not working with IE8 with tomcat, Object expected error
Current Time: Sat Jul 26 09:42:10 EDT 2025
Powered by FUDForum. Page generated in 0.11727 seconds
