Home » Eclipse Projects » EclipseLink » @Embeddable with Entity relations(Mapping behaves strange when used in a Set )
@Embeddable with Entity relations [message #729953] |
Tue, 27 September 2011 06:56  |
i struggle with a strange issue when i use @Embeddable objects that holds a reference to an Entity.
Example:
I have a parent object, that holds a collection of Embeddables (in a Set)
@Entity
public class Parent implements Serializable {
@Id
@GeneratedValue( strategy = GenerationType.AUTO )
private Long id;
@ElementCollection
@CollectionTable( joinColumns = @JoinColumn( name = "parent_id", nullable = false ) )
private Set<Child> children = new HashSet<Child>();
The Embeddable holds a reference to an Entity.
@Embeddable
public class Child implements Serializable {
@ManyToOne( optional = false )
private EntityRelation entityRelation;
The reference Entity
@Entity
public class EntityRelation implements Serializable {
@Id
private Long id;
Under some circumstances[1] EclipseLink tries to insert already existent (in the database) EntityRelation objects what ends up in duplicate key exceptions.
After a bit of research i found this in the JPA 2 spec (Section 2.5):
An embeddable class may contain a relationship to an entity or collection of entities.
Since instances of embeddable classes themselves have no persistent identity, the relationship from the referenced entity is to the entity that contains the embeddable instance(s) and not to the embeddable itself.[17]
An embeddable class that is used as an embedded id or as a map key must not contain such a relationship.
Iam not sure, but this also implies that such a mapping can't be used in sets like in the example above?
Greetings Luca
[1] For readability i will describe the use case more detailed in a new posting.
[Updated on: Tue, 27 September 2011 09:05] by Moderator
Re: @Embeddable with Entity relations [message #729955 is a reply to message #729953] |
Tue, 27 September 2011 06:58   |
Environment:
Linux
Glassfish 3.1 (Eclipse Persistence Services - 2.2.0.v20110202-r8913)
Use case (pseudo code):
List<Parent> parents = ps.getAllParents(); //load parents
for( Parent parent : parents ) {
IndependentEntity ie = is.selectOrCreate( -1L ); //selects an independent entity or returns a new (transient)
for( Child child : parent.getChildren() ) {
child.getEntityRelation();
is.merge( ie );
If there (at minimum) two parents this code will fail with a duplicate key exception at flush/commit time.
Note, the code above not change anything on the Child/EntityRelation objects.
It seems that this only happens if another Entity will persisted/updated in the same transaction.
Log:
FEINER: client acquired: 1953950842
FEINER: TX binding to tx mgr, status=STATUS_ACTIVE
FEINER: acquire unit of work: 731871570
FEINER: begin unit of work flush
FEINER: end unit of work flush
AM FEINSTEN: Execute query ReadAllQuery(name="findAllParents" referenceClass=Parent sql="SELECT ID FROM PARENT ORDER BY ID ASC")
AM FEINSTEN: Connection acquired from connection pool [read].
AM FEINSTEN: reconnecting to external connection pool
FEIN: SELECT ID FROM PARENT ORDER BY ID ASC
AM FEINSTEN: Connection released to connection pool [read].
AM FEINSTEN: Execute query ReadObjectQuery(name="readObject" referenceClass=IndependentEntity sql="SELECT ID FROM INDEPENDENTENTITY WHERE (ID = ?)")
FEIN: SELECT ID FROM INDEPENDENTENTITY WHERE (ID = ?)
bind => [-1]
AM FEINSTEN: Execute query ReadAllQuery(name="children" referenceClass=Child sql="SELECT CHILDNAME, entityrelation_id, parent_id FROM Parent_CHILDREN WHERE (parent_id = ?)")
FEIN: SELECT CHILDNAME, entityrelation_id, parent_id FROM Parent_CHILDREN WHERE (parent_id = ?)
bind => [1]
AM FEINSTEN: Execute query ReadObjectQuery(name="entityRelation" referenceClass=EntityRelation )
FEIN: SELECT ID, RELATIONNAME, RELATIONTYPE FROM ENTITYRELATION WHERE (ID = ?)
bind => [1]
bind => [2]
bind => [3]
AM FEINSTEN: Register the object org.test.entity.EntityRelation@46cd0462
AM FEINSTEN: Register the object org.test.entity.EntityRelation@ec94549f
AM FEINSTEN: Register the object org.test.entity.EntityRelation@4ecb5266
AM FEINSTEN: Merge clone with references org.test.entity.IndependentEntity@560fc912
FEINER: TX beginTransaction, status=STATUS_ACTIVE
AM FEINSTEN: Connection acquired from connection pool [default].
AM FEINSTEN: Execute query DataModifyQuery(name="SEQUENCE" sql="UPDATE SEQUENCE SET SEQ_COUNT = SEQ_COUNT + #PREALLOC_SIZE WHERE SEQ_NAME = #SEQ_NAME")
FEIN: UPDATE SEQUENCE SET SEQ_COUNT = SEQ_COUNT + ? WHERE SEQ_NAME = ?
bind => [50, SEQ_GEN]
AM FEINSTEN: Execute query ValueReadQuery(name="SEQUENCE" sql="SELECT SEQ_COUNT FROM SEQUENCE WHERE SEQ_NAME = #SEQ_NAME")
FEIN: SELECT SEQ_COUNT FROM SEQUENCE WHERE SEQ_NAME = ?
bind => [SEQ_GEN]
AM FEINSTEN: local sequencing preallocation for SEQ_GEN: objects: 50 , first: 51, last: 100
AM FEINSTEN: assign sequence to the object (51 -> org.test.entity.IndependentEntity@2659e8e2)
AM FEINSTEN: Execute query InsertObjectQuery(org.test.entity.IndependentEntity@2659e8e2)
FEIN: INSERT INTO INDEPENDENTENTITY (ID) VALUES (?)
bind => [51]
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Parent@1)
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Child@46cd0709)
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Child@4ecb550d)
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Child@ec945746)
FEINER: resume unit of work
bind => [-1]
bind => [2]
AM FEINSTEN: Execute query ReadObjectQuery(name="entityRelation" referenceClass=EntityRelation )rge IndependentEntity ...
AM FEINSTEN: Merge clone with references org.test.entity.IndependentEntity@1703c2db
AM FEINSTEN: assign sequence to the object (52 -> org.test.entity.IndependentEntity@77edc3aa)
AM FEINSTEN: Execute query DoesExistQuery(referenceClass=EntityRelation )
AM FEINSTEN: Execute query InsertObjectQuery(org.test.entity.IndependentEntity@77edc3aa)
bind => [52]
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Parent@2)
AM FEINSTEN: Execute query WriteObjectQuery(org.test.entity.EntityRelation@46cd0462)
FEIN: INSERT INTO ENTITYRELATION (ID, RELATIONNAME, RELATIONTYPE) VALUES (?, ?, ?)
bind => [2, relation2, INTEGER_T]
FEIN: SELECT 1
WARNUNG: Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.2.0.v20110202-r8913): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: org.postgresql.util.PSQLException: FEHLER: doppelter Schlüsselwert verletzt Unique-Constraint »entityrelation_pkey«
Error Code: 0
Call: INSERT INTO ENTITYRELATION (ID, RELATIONNAME, RELATIONTYPE) VALUES (?, ?, ?)
Query: WriteObjectQuery(org.test.entity.EntityRelation@46cd0462)
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.processExceptionForCommError(DatabaseAccessor.java:1420)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:796)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeNoSelect(DatabaseAccessor.java:864)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:583)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:526)
at org.eclipse.persistence.internal.sessions.AbstractSession.basicExecuteCall(AbstractSession.java:1729)
at org.eclipse.persistence.sessions.server.ClientSession.executeCall(ClientSession.java:234)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:207)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:193)
at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.insertObject(DatasourceCallQueryMechanism.java:342)
at org.eclipse.persistence.internal.queries.StatementQueryMechanism.insertObject(StatementQueryMechanism.java:162)
at org.eclipse.persistence.internal.queries.StatementQueryMechanism.insertObject(StatementQueryMechanism.java:177)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.insertObjectForWrite(DatabaseQueryMechanism.java:469)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCommit(InsertObjectQuery.java:80)
at org.eclipse.persistence.queries.InsertObjectQuery.executeCommitWithChangeSet(InsertObjectQuery.java:90)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.performUserDefinedWrite(DatabaseQueryMechanism.java:561)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.performUserDefinedInsert(DatabaseQueryMechanism.java:529)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.insertObjectForWrite(DatabaseQueryMechanism.java:399)
at org.eclipse.persistence.queries.WriteObjectQuery.executeCommitWithChangeSet(WriteObjectQuery.java:121)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.executeWriteWithChangeSet(DatabaseQueryMechanism.java:291)
at org.eclipse.persistence.queries.WriteObjectQuery.executeDatabaseQuery(WriteObjectQuery.java:58)
at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:808)
at org.eclipse.persistence.queries.DatabaseQuery.executeInUnitOfWork(DatabaseQuery.java:711)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWorkObjectLevelModifyQuery(ObjectLevelModifyQuery.java:108)
at org.eclipse.persistence.queries.ObjectLevelModifyQuery.executeInUnitOfWork(ObjectLevelModifyQuery.java:85)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2842)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1521)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1503)
at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1463)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.update(ObjectReferenceMapping.java:1111)
at org.eclipse.persistence.mappings.ObjectReferenceMapping.preUpdate(ObjectReferenceMapping.java:590)
at org.eclipse.persistence.descriptors.DescriptorQueryManager.preUpdate(DescriptorQueryManager.java:1095)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.updateObjectForWrite(DatabaseQueryMechanism.java:993)
at org.eclipse.persistence.queries.UpdateObjectQuery.executeCommit(UpdateObjectQuery.java:69)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.executeWrite(DatabaseQueryMechanism.java:236)
at org.eclipse.persistence.queries.WriteObjectQuery.executeDatabaseQuery(WriteObjectQuery.java:60)
at org.eclipse.persistence.mappings.AggregateCollectionMapping.objectUnchangedDuringUpdate(AggregateCollectionMapping.java:2024)
at org.eclipse.persistence.mappings.CollectionMapping.compareObjectsAndWrite(CollectionMapping.java:700)
at org.eclipse.persistence.mappings.AggregateCollectionMapping.postUpdate(AggregateCollectionMapping.java:2118)
at org.eclipse.persistence.descriptors.DescriptorQueryManager.postUpdate(DescriptorQueryManager.java:995)
at org.eclipse.persistence.internal.queries.DatabaseQueryMechanism.updateObjectForWriteWithChangeSet(DatabaseQueryMechanism.java:1175)
at org.eclipse.persistence.queries.UpdateObjectQuery.executeCommitWithChangeSet(UpdateObjectQuery.java:84)
at org.eclipse.persistence.internal.sessions.CommitManager.commitChangedObjectsForClassWithChangeSet(CommitManager.java:265)
at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsForClassWithChangeSet(CommitManager.java:190)
at org.eclipse.persistence.internal.sessions.CommitManager.commitAllObjectsWithChangeSet(CommitManager.java:136)
at org.eclipse.persistence.internal.sessions.AbstractSession.writeAllObjectsWithChangeSet(AbstractSession.java:3766)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabase(UnitOfWorkImpl.java:1404)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitToDatabase(RepeatableWriteUnitOfWork.java:616)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithPreBuiltChangeSet(UnitOfWorkImpl.java:1552)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.writeChanges(RepeatableWriteUnitOfWork.java:427)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.flush(EntityManagerImpl.java:744)
at com.sun.enterprise.container.common.impl.EntityManagerWrapper.flush(EntityManagerWrapper.java:418)
at org.test.service.IndependentEntityService.merge(IndependentEntityService.java:37)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1052)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1124)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5367)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:619)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:801)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:571)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:162)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:144)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:862)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:371)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5339)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5327)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:214)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandlerDelegate.invoke(EJBLocalObjectInvocationHandlerDelegate.java:88)
at $Proxy129.merge(Unknown Source)
at org.test.service.__EJB31_Generated__IndependentEntityService__Intf____Bean__.merge(Unknown Source)
at org.test.timer.Runner.run(Runner.java:51)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundTimeout(SystemInterceptorProxy.java:149)
at com.sun.ejb.containers.BaseContainer.callEJBTimeout(BaseContainer.java:4033)
at com.sun.ejb.containers.EJBTimerService.deliverTimeout(EJBTimerService.java:1835)
at com.sun.ejb.containers.EJBTimerService.access$100(EJBTimerService.java:108)
at com.sun.ejb.containers.EJBTimerService$TaskExpiredWork.run(EJBTimerService.java:2708)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.postgresql.util.PSQLException: FEHLER: doppelter Schlüsselwert verletzt Unique-Constraint »entityrelation_pkey«
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2103)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1836)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:512)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:388)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeUpdate(AbstractJdbc2Statement.java:334)
at com.sun.gjc.spi.base.PreparedStatementWrapper.executeUpdate(PreparedStatementWrapper.java:120)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeDirectNoSelect(DatabaseAccessor.java:789)
... 125 more
[Updated on: Tue, 27 September 2011 10:47] by Moderator
Re: @Embeddable with Entity relations [message #730990 is a reply to message #730903] |
Thu, 29 September 2011 12:32   |
I have tested it also with default Object equals/hashCode implementation, but the same duplicate-key exception was thrown.
I realized also, that the default Object toString() method use the hashCode() method internal, so the output in the log (assuming eclipelink use toString()) must not indicate that the objects are the same in the sense of identity.
Output when Object equals/hashCode is used:
AM FEINSTEN: Execute query InsertObjectQuery(org.test.entity.IndependentEntity@5593d23b)
bind => [52]
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Child@42b9f649)
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Child@5ad2ee0f)
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Child@248bf20b)
AM FEINSTEN: Execute query UpdateObjectQuery(org.test.entity.Child@4440096c)
AM FEINSTEN: Execute query WriteObjectQuery(org.test.entity.EntityRelation@5fbfc2eb)
bind => [1, relation1, STRING_T]
FEIN: SELECT 1
Error Code: 0
Query: WriteObjectQuery(org.test.entity.EntityRelation@5fbfc2eb)
Iam not sure but i think there should be no problem with the initial Parent->Child relation. The relation is already persisted and i use a new transaction/persistencecontext to lookup the parents.
That is the database content for the testcase:
select * from parent;
id
1
2
(2 rows)
select * from parent_children;
entityrelation_id | childname | parent_id
1 | child1 | 1
2 | child2 | 1
3 | child3 | 1
1 | child4 | 2
2 | child5 | 2
3 | child6 | 2
(6 rows)
select * from entityrelation;
id | relationname | relationtype
1 | relation1 | STRING_T
2 | relation2 | INTEGER_T
3 | relation3 | DATE_T
(3 rows)
select * from independententity;
id
(0 rows)
select * from sequence;
seq_name | seq_count
SEQ_GEN | 50
(1 row)
Greetings Luca
[Updated on: Thu, 29 September 2011 12:49] by Moderator
Re: @Embeddable with Entity relations [message #732244 is a reply to message #731272] |
Tue, 04 October 2011 06:11  |
Gordon Yorke wrote on Fri, 30 September 2011 15:37
It is possible it may be this issue:https://bugs.eclipse.org/bugs/show_bug.cgi?id=300108
I'm not sure if this is the same issue.
When i execute the test against the latest 2.4.0-SNAPSHOT a different exception will be thrown:
java.lang.IllegalStateException: During synchronization a new object was found through a relationship that was not marked cascade PERSIST: org.test.entity.EntityRelation@2d28762e.
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.discoverUnregisteredNewObjects(RepeatableWriteUnitOfWork.java:304)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.calculateChanges(UnitOfWorkImpl.java:702)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitToDatabaseWithChangeSet(UnitOfWorkImpl.java:1490)
at org.eclipse.persistence.internal.sessions.RepeatableWriteUnitOfWork.commitRootUnitOfWork(RepeatableWriteUnitOfWork.java:267)
at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.commitAndResume(UnitOfWorkImpl.java:1143)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commitInternal(EntityTransactionImpl.java:84)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:63)
at org.test.usecase.DuplicateKeyCaseTest.cleanUpDBInOwnTransaction(DuplicateKeyCaseTest.java:116)
at org.test.usecase.DuplicateKeyCaseTest.commitTransactionAndCleanUpDB(DuplicateKeyCaseTest.java:54)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:37)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:69)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:48)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
at org.junit.runners.ParentRunner.run(ParentRunner.java:292)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
This looks like another error (but it may related), it occours in a other place (in the transaction which is executed after the test for cleaning up the database). You can easily reproduce this by changing the eclipselink-version in test projects pom.xml.
Please note that the problem seems to be also non-deterministic.
Greetings Luca
Current Time: Wed Jul 23 05:29:46 EDT 2025
Powered by FUDForum. Page generated in 0.34487 seconds
