Home » Archived » BIRT » Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout?
Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout? [message #728397] Fri, 23 September 2011 04:11 Go to next message
I have a really ugly query which takes around 3 minutes to complete. In the report designer it runs fine and displays results. However, on the server I see the 'Processing' message but this disappears after exactly 1 minute. I have looked in the logs on the server but can see nothing there.
It is almost certainly a timeout issue - but where? Does BIRT have a timeout on queries? Is it a web server timeout?
[Update]
I just tried it out in my local tomcat server and it returns after 45 seconds and displays the first page of 248. I can then page up and down and the response time is fast. Not sure why Websphere takes so much longer. In the preview window the request took 2-3 minutes but then displayed the whole result set.
[Updated on: Fri, 23 September 2011 05:11] by Moderator
Re: Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout? [message #728515 is a reply to message #728397] Fri, 23 September 2011 07:59 Go to previous messageGo to next message
Hello Paul,
Did you check the tomcat catalina.out for OutOfMemory errors?
Are both AppServers using the same memory settings (max memory and permgen)?
Re: Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout? [message #728538 is a reply to message #728515] Fri, 23 September 2011 08:59 Go to previous messageGo to next message
Hi Jeanbaptiste
Tomcat works fine for me - it's just Websphere which timesout. I could not see any error messages in the output files on WAS. I'm guessing it is a transport timeout as it is always exactly 60 seconds. I've tweaked all the settings I can find....
Re: Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout? [message #728653 is a reply to message #728538] Fri, 23 September 2011 11:33 Go to previous messageGo to next message
Paul,
You did not set a query timeout in the report did you?
In the viewer.properties file what is your session timeout set to?
Can you set the log level to FINEST and post the log?
Jason
On 9/23/2011 8:59 AM, Paul Ramsden wrote:
> Hi Jeanbaptiste
Re: Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout? [message #729861 is a reply to message #728653] Tue, 27 September 2011 02:42 Go to previous messageGo to next message
Jason,
thanks for your reply.
I had not (knowingly) set any timeouts anywhere. There is no timeout in viewer.properties. I set the log level to FINEST but only seem to get INFO messages in the log (mainly font registration entries).
I removed the application and deployed it again and the problem has gone away. I have no idea what is different this time. I guess we can forget this issue until it comes back Wink
Paul
Re: Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout? [message #729883 is a reply to message #729861] Tue, 27 September 2011 04:09 Go to previous messageGo to next message
Well, it's back again.
I updated a report and restarted the server. Here is the log (FINEST)
27.09.2011 10:05:41 null null
INFO: Found JDBC driverinfo extension: driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
INFO: Found JDBC driverinfo extension: driverClass=org.eclipse.birt.report.data.oda.hive.HiveDriver, connectionFactory=null
INFO: Found JDBC driverinfo extension: driverClass=org.eclipse.birt.report.data.oda.sampledb.Driver, connectionFactory=org.eclipse.birt.report.data.oda.sampledb.SampleDBJDBCConnectionFactory
INFO: Loaded JDBC driver class in class path: com.microsoft.sqlserver.jdbc.SQLServerDriver
27.09.2011 10:07:13 null null
INFO: load font config in wsjar:file:/D:/WebSphere70/AppServer/profiles/AppSrv/installedApps/Cell/BirtViewer_war.ear/WASBirtViewer.war/WEB-INF/lib/org.eclipse.birt.runtime_3.7.0.v20110615-1818.jar!/fontsConfig.xml cost 16ms
INFO: register fonts in /usr/share/fonts/zh_CN/TrueType cost:0ms
INFO: register fonts in C:/windows/fonts cost:47ms
INFO: register fonts in /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_5/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_CN.GB18030/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ar/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh.GBK/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/tt cost:0ms
INFO: register fonts in /usr/share/fonts/ko/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/truetype cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/hi_IN.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/OTF cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_15/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_13/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/ja/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in g:/WINNT/fonts cost:0ms
INFO: register fonts in g:/windows/fonts cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TTF cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/KOI8-R/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW.BIG5/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/th_TH/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/windows/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/euro_fonts/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_2/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/zh_TW/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/truetype cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ja/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ru.ansi-1251/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_HK.BIG5HK/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/share/fonts/default/TrueType cost:0ms
INFO: register fonts in f:/WINNT/fonts cost:0ms
INFO: register fonts in f:/windows/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_9/X11/fonts/TrueType cost:0ms
INFO: register fonts in d:/WINNT/fonts cost:0ms
INFO: register fonts in C:/WINNT/fonts cost:0ms
INFO: register fonts in d:/windows/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_7/X11/fonts/TrueType cost:0ms
INFO: load font config in wsjar:file:/D:/WebSphere70/AppServer/profiles/AppSrv/installedApps/Cell/BirtViewer_war.ear/WASBirtViewer.war/WEB-INF/lib/org.eclipse.birt.runtime_3.7.0.v20110615-1818.jar!/fontsConfig_win32.xml cost 0ms
INFO: load font config in wsjar:file:/D:/WebSphere70/AppServer/profiles/AppSrv/installedApps/Cell/BirtViewer_war.ear/WASBirtViewer.war/WEB-INF/lib/org.eclipse.birt.runtime_3.7.0.v20110615-1818.jar!/fontsConfig_pdf.xml cost 0ms
Not much to see!
Paul
[Updated on: Tue, 27 September 2011 04:11] by Moderator
Re: Websphere+Birt 3.7: Report generation aborts after 1 minute. Timeout? [message #730097 is a reply to message #729883] Tue, 27 September 2011 11:26 Go to previous message
Paul,
Does this happen with all long running reports or just the one?
Jason
> Not much to see!
> Paul
Previous Topic:How to Place Controls on pixel position
Next Topic:Chart scripting with report variables
Current Time: Wed Jul 23 04:04:05 EDT 2025
Powered by FUDForum. Page generated in 0.28583 seconds
