Home » Modeling » GMF (Graphical Modeling Framework) » XML generated by the gmf editor(XML generated by the gmf editor contains all the parameters for Node though its not present in the property window)
XML generated by the gmf editor [message #726657] Mon, 19 September 2011 03:31 Go to next message
Hi All,
XML generated by the gmf editor contains all the parameters for Node though its not present in the property window.
Please find the attached xml file and the image with this.
Can anyone help me regarding this ?
Vinay
Re: XML generated by the gmf editor [message #729847 is a reply to message #726657] Tue, 27 September 2011 01:42 Go to previous messageGo to next message
Hi Vinay,
you can control within the emf gen model which attribute shall be
visible or editable within the properies view. GMF uses the generated
..edit project results manifested as *ItemProvider. Please consider the
emf project help for further details.
Sven
Am 19.09.2011 09:31, schrieb vinny503:
> Hi All,
> Vinay
Re: XML generated by the gmf editor [message #729943 is a reply to message #726657] Tue, 27 September 2011 05:11 Go to previous message
Please read and improve the following documentation,
http://wiki.eclipse.org/Graphical_Modeling_Framework/FAQ#How_can_I_customize_the_properties_view.3F
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Previous Topic:Property window is not getting updated properly as per the node selection in GMF Editor
Next Topic:Copying GMF projects
Current Time: Sun Jul 20 20:25:39 EDT 2025
Powered by FUDForum. Page generated in 0.25566 seconds
