Home » Archived » BIRT » Example for drill down feature
Example for drill down feature [message #729507] Mon, 26 September 2011 07:17 Go to next message
Is there any ready example for drill through feature?
Say I have a chart which shows continent wise sale. If I click on a continent say Europe it should show the earlier chart which shows continent wise sale as well as in the same page some where around or below it country wise sale in the continent Europe.
I have gone through this link:
http://birtworld.blogspot.com/2008/05/birt-drill-through.html
Anurag
[Updated on: Mon, 26 September 2011 11:26] by Moderator
Re: Example for drill down feature [message #729629 is a reply to message #729507] Mon, 26 September 2011 12:39 Go to previous messageGo to next message
Here is an older example but it should still work.
http://www.eclipse.org/birt/phoenix/examples/reports/birt2.1/drill/index.php
Jason
On 9/26/2011 7:17 AM, Anurag wrote:
> Is there any ready example for drill down feature?
> Anurag
Re: Example for drill down feature [message #729926 is a reply to message #729629] Tue, 27 September 2011 05:55 Go to previous messageGo to next message
Thank you for reply, Jason. I am going through it.
Anurag
Re: Example for drill down feature [message #895730 is a reply to message #729507] Sun, 15 July 2012 08:44 Go to previous messageGo to next message
No jason, this is not that. I also wanted such a functionality where hyperlinks open not on a new window or same window replacing the contents of the previous window but below or on the right of the original chart. I have found no solution for this till now. Do you know of any..?
Re: Example for drill down feature [message #896037 is a reply to message #895730] Mon, 16 July 2012 22:48 Go to previous message
You may be able to use client side script to do this. Take a look at
this chart example that shows a table below the chart when the user
mouses over:
http://birtworld.blogspot.com/2009/12/calling-client-side-javascript-from.html
Jason
> of any..?
Previous Topic:Only one column in crosstab
Next Topic:Support for Multiple Excel worksheets
Current Time: Sat Jul 26 17:30:07 EDT 2025
Powered by FUDForum. Page generated in 0.05148 seconds
