Home » Modeling » M2T (model-to-text transformation) » [acceleo 3.1] editor doesn't see inheritance
[acceleo 3.1] editor doesn't see inheritance [message #725703] Thu, 15 September 2011 10:49 Go to next message
I have a class called MetaModel located in b.ecore. it extends Artifact located in a.ecore.
The acceleo editor code assist suggests the attributes from MetaModel class but not from Artifact. If I type one of these manually, then the editor shows an error marker.
Any idea what could be the problem?
Here is how my template looks like:
[module genmodelGen('/plugina/model/a.ecore','/pluginb/model/b.ecore','http://www.eclipse.org/emf/2002/Ecore')/]
[template public genmodelGenComponent(c : MetaModel)]
    modelPluginID="[c.id/]"
    modelName="[c.emfPackage/]"
[/template]
c.id is not recognized and is part of Artifact class. c.emfPackage is recognized and is part of MetaModel.
Max
Re: [acceleo 3.1] editor doesn't see inheritance [message #725999 is a reply to message #725703] Fri, 16 September 2011 07:35 Go to previous messageGo to next message
so I had to use oclAsType. Is there a way to avoid using this API?
[Updated on: Fri, 16 September 2011 08:13] by Moderator
Re: [acceleo 3.1] editor doesn't see inheritance [message #726796 is a reply to message #725999] Mon, 19 September 2011 11:17 Go to previous messageGo to next message
Hi Maxime,
What you are trying to do should work.
I have tried to recreate the conditions of your environment and it worked for me as you can see it in this screenshot:
https://lh6.googleusercontent.com/-sx3rmeM1n2M/TndcSk7kWLI/AAAAAAAAAfA/IiOygrPTYnI/s600/metamodels.png
Does your project have a dependency with the two projects containing the metamodels? Are you using the binary serialization? (right click on your project -> properties -> acceleo), if yes, try XMI. Do you have the latest version of Acceleo 3.1.1? Could you try with it. I'll investigate more to see what could be the source of the problem.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
[Updated on: Mon, 19 September 2011 11:18] by Moderator
Re: [acceleo 3.1] editor doesn't see inheritance [message #728398 is a reply to message #726796] Fri, 23 September 2011 04:13 Go to previous messageGo to next message
Hello Stéphane,
I'm facing exactly the same problem on my project developped under Eclipse 3.5.2 with Acceleo 3.0.1.
In the editor's content assist, impossible to see the inherited attributes and references.
I don't know how to solve it ! I should use oclAsType() everywhere ! Project dependencies seem to be OK.
Sébastien
Re: [acceleo 3.1] editor doesn't see inheritance [message #728540 is a reply to message #728398] Fri, 23 September 2011 09:04 Go to previous messageGo to next message
It is something that we improved for Acceleo 3.1.x so I'm not surprised if some problems appear in Acceleo 3.0.x
[Updated on: Fri, 23 September 2011 09:04] by Moderator
Re: [acceleo 3.1] editor doesn't see inheritance [message #729442 is a reply to message #728540] Mon, 26 September 2011 04:13 Go to previous messageGo to next message
Sébastien,
As Stéphane mentionned, there have been a great deal of improvements in Acceleo 3.1 towards the resolution of metamodel dependencies in the modules. Do you have a particular reason for staying on the 3.0 stream? The 3.1 stream supports the same platforms as 3.0 did (all the way back to Eclipse 3.4 : http://wiki.eclipse.org/Acceleo/Compatibility). You can try installing it through the update site http://download.eclipse.org/modeling/m2t/acceleo/updates/releases/3.1 on any supported platform (http://wiki.eclipse.org/Acceleo/Installation).
If you do need to remain on the 3.0 stream, I cannot help more than Stephane did; you'll have to resort to "oclAsType" everywhere Acceleo does not manage to infer the type. Maybe try to import all needed metamodels in the module header, but if that does not help, then you're stuck with casting.
Laurent Goubet
Obeo
Re: [acceleo 3.1] editor doesn't see inheritance [message #729485 is a reply to message #729442] Mon, 26 September 2011 05:54 Go to previous message
Hi Laurent and Stephane.
First, thanks for your replies.
No particular reasons for staying on the 3.0 stream. My main constraint is to use Eclipse 3.5.2 as target platform. When I installed my development platform, Acceleo 3.0.1 came with it ! Actually, I was not aware about the compliance between Acceleo 3.1.X and Eclipse 3.5.X. So, it's a great news for me !!!
Ok, update done to Acceleo 3.1.1. Behavior is better. My problem of cast is solved.
Thanks !
Sébastien
[Updated on: Mon, 26 September 2011 05:55] by Moderator
Previous Topic:[ACCELEO 3] Retrieving the class from a stereotype
Next Topic:Out of Order text generation
Current Time: Sat Jul 26 02:08:51 EDT 2025
Powered by FUDForum. Page generated in 0.08002 seconds
