Home » Eclipse Projects » Remote Application Platform (RAP) » Rap and Hibernate
Rap and Hibernate [message #72743] Fri, 01 February 2008 17:20 Go to next message
Hi;
I am using hibernate with Rap. But I dont know that Where I can put
hibernate.cfg.xml file
Re: Rap and Hibernate [message #72814 is a reply to message #72743] Sat, 02 February 2008 05:23 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
maybe the following thread contains some useful information regarding
your question:
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg01595.ht
ml
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Cenk Dundar [mailto:cenkdundar@yahoo.com]
Bereitgestellt: Freitag, 1. Februar 2008 23:20
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Rap and Hibernate
Betreff: Rap and Hibernate
Hi;
Re: Rap and Hibernate [message #72836 is a reply to message #72814] Sat, 02 February 2008 19:57 Go to previous messageGo to next message
I deploy my application on tomcat. But I dont know where I can put the
hibernate.cfg.xml or how I can define the hibernate.cfg.xml file. I could nt
understand that you sended link. May you give me a example. ?
Thank you very much
"Frank Appel" <fappel@innoopract.com>, haber iletisinde sunlari
yazdi:003a01c86585$ac3db4c0$0b0a0a0a@Abulafila...
> your question:
> ml
> Ciao
> Frank
> -----Urspr
Re: Rap and Hibernate [message #72888 is a reply to message #72836] Mon, 04 February 2008 03:02 Go to previous message
Well, you could provide your Configuration in the same plugin where the
hibernate-jar resides.
Or much better, you define a Fragment to this plugin, which holds the
Configuration-File. As the host, you define your hibernate-plugin.
Actually, there is no difference in using hibernate in rap to using
hibernate in any other eclipse-plugin-project. If you canŽt get it to
work, come again and IŽll provide an example.
Martin
Previous Topic:Static Objects
Next Topic:large menues
Current Time: Sun Aug 31 13:32:14 EDT 2025
Powered by FUDForum. Page generated in 0.05453 seconds
