Home » Eclipse Projects » Eclipse 4 » Exporting e4 app product - exit code 13
Exporting e4 app product - exit code 13 [message #659687] Tue, 15 March 2011 05:23 Go to next message
I am having trouble exporting my app as a product.
I am using the export wizard and it exports successfully but when I double click to open the exported app I get an error message that starts with "Java was started but returned exit code = 13"
Running the app within the workspace works fine (running the product inside the platform also works fine).
I am using the integration build eclipse-SDK-I20110312-1300-win32 as platform.
I appreciate your help!!
Re: Exporting e4 app product - exit code 13 [message #659709 is a reply to message #659687] Tue, 15 March 2011 06:11 Go to previous messageGo to next message
Look through the log file; it's usually found in .../workspace/.metadata/.log.
There are a few differences between the env provided by PDE and the actual runtime environment. PDE's training wheels are a great help when you're developing, but losing them is painful when finally putting together your product!
My guesses:
(1) you're missing necessary files (e.g., Application.e4xmi) in your build.properties, and so they are not being exported. This should be revealed in your .log.
(2) you haven't specified start levels for key bundles like org.eclipse.equinox.ds. Tom posted earlier to this forum with an essential stanza for your .product file.
You can also try the Eclipse IRC for faster turn-around.
Re: Exporting e4 app product - exit code 13 [message #659903 is a reply to message #659709] Tue, 15 March 2011 21:13 Go to previous messageGo to next message
Thank you for the guesses (1 was correct! ) and the tips!
Re: Exporting e4 app product - exit code 13 [message #728873 is a reply to message #659903] Sat, 24 September 2011 02:35 Go to previous messageGo to next message
how to export E4 project . I see some errors in running the exported product
Parvez Ahmad Hakim
Srinagar www.abobjects.com
!SESSION 2011-09-23 11:07:40.531 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_11
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.equinox.app 0 0 2011-09-23 11:07:50.609
!MESSAGE Product org.cord.client.dms.mainapp.e4.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-09-23 11:07:50.625
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:126)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Re: Exporting e4 app product - exit code 13 [message #729219 is a reply to message #728873] Sun, 25 September 2011 09:32 Go to previous message
I get below error. please help
Parvez Ahmad Hakim
!SESSION 2011-09-25 18:59:03.719 -----------------------------------------------
!ENTRY org.eclipse.equinox.app 0 0 2011-09-25 18:59:05.576
!MESSAGE Product kashmir.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-09-25 18:59:05.594
!STACK 1
Previous Topic:Seeking feedback on Google Summer of Code project idea
Next Topic:XWT not working in exports
Current Time: Fri Jul 18 11:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.03769 seconds
