Home » Modeling » GMF (Graphical Modeling Framework) » On diagram window focus action
On diagram window focus action [message #728257] Thu, 22 September 2011 15:46 Go to next message
could some one help me a bit. I am trying to run some code, when my diagram view loses focus/ gains focus. In emf editor its quite easy you only need to edit partBroughtToTop or partDeactivated in the editor code. But i cant manage to do the same for gmf .diagram.
Anyone solved this?
Thanks in advance.
Jan
Re: On diagram window focus action [message #728455 is a reply to message #728257] Fri, 23 September 2011 05:43 Go to previous messageGo to next message
Some different ideas:
* From your generated Editor class, you can use
getGraphicalControl().addFocusListener().
* Add a listener on the EditorSite page ->
editor.getEditorSite().getPage().addPartListener(). In your
IPartListener, check that the part that sends the notification if your
editor.
However, you can still open a feature request against GMF-Runtime to
explain your use-case and suggest an improvement.
Mickael
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: On diagram window focus action [message #728578 is a reply to message #728455] Fri, 23 September 2011 09:53 Go to previous message
Thanks Mickael.
Will look into that.
Jan
Previous Topic:Cant delete diagram element
Next Topic:Help configuring the Taipan example in GMF tutorial
Current Time: Sun Jul 27 09:25:10 EDT 2025
Powered by FUDForum. Page generated in 0.03187 seconds
