Home » Archived » BIRT » Default Workspace Directory(Default Workspace Directory)
Default Workspace Directory [message #727581] Wed, 21 September 2011 11:05 Go to next message
I'm using Birt All In one. To be specific I'm using birt-rcp-report-designer-2_5_2. It works great, however at current the default workspace directory used when creating a new report is the same directory as the application. I'd like to potentially change this to be in the users documents folder.
It would seem my query is similar to the query in thread 118575 however I'm not sure of where to put the code. I presumed this was relevant but was unsure if this related to the Eclipse IDE for Java and Report Developers Package.
John
Re: Default Workspace Directory [message #727659 is a reply to message #727581] Wed, 21 September 2011 14:52 Go to previous messageGo to next message
John,
Look at the config.ini in the
eclipse\configuration directory. It may have a setting for this.
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse.pde.doc.user/guide/tools/launchers/configuration.htm
Jason
> Developers Package.
> John
Re: Default Workspace Directory [message #728437 is a reply to message #727659] Fri, 23 September 2011 05:35 Go to previous message
Thanks, That's exactly what I was after.
Previous Topic:Get Dataset value to fill Y-serie
Next Topic:[SOLVED] How to configure pie chart to group series
Current Time: Fri Jul 25 00:07:58 EDT 2025
Powered by FUDForum. Page generated in 0.05340 seconds
