Home » Modeling » EMF » Can't get XText to work! (Query 2)
Can't get XText to work! (Query 2) [message #728423] Fri, 23 September 2011 05:08 Go to next message
I'm trying to use query 2 on my model. I use Eclipse Helios Service Release 2.
I installed the following:
(Update site: Xtext All In One (Releases) - http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases/)
- Xbase 2.0.1
- Xtend2 SDK 2.0.1
- Xtext documentation 2.0.1
- Xtext examples 2.0.1
- Xtext runtime 2.0.1
- Xtext SDK 2.0.1
- Xtext UI 2.0.1
(Update site: EMF Query2 Update Site - https://hudson.eclipse.org/hudson/job/tycho-query2-nightly/lastSuccessfulBuild/artifact/targetPlatform/)
- EMF Query2 Core Feature 1.0.0.2
- EMF Query2 String Syntax Feature 1.0.0.2
When i am trying to create a query (filename.query).. I receive an error when opening the file:
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.emf.query2.stringsyntax.ui (1289).
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:121)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:338)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1197)
	at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
	at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:904)
	at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
	at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
	at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:267)
	at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:263)
	at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
	at org.eclipse.ui.internal.EditorManager.createPart(EditorManager.java:845)
	at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:609)
	at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
	at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
	at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2863)
	at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
	at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
	at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
	at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2682)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
	at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:365)
	at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:168)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
	at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:208)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
	at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:250)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:373)
	at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:526)
	at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
	at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:845)
	at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
	at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
	at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:843)
	at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1131)
	at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1235)
	at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
	at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
	at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.emf.query2.syntax.ui.internal.QueryActivator.start() of bundle org.eclipse.emf.query2.stringsyntax.ui.
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
	at org.eclipse.osgi.framework.util.SecureAction$21.run(SecureAction.java:423)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
	at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:106)
	... 78 more
Caused by: com.google.inject.CreationException: Guice creation errors:
1) No implementation for org.eclipse.jface.text.rules.ITokenScanner was bound.
  while locating org.eclipse.jface.text.rules.ITokenScanner
    for parameter 0 at org.eclipse.xtext.ui.editor.syntaxcoloring.PresentationRepairer.<init>(PresentationRepairer.java:22)
  at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
2) No implementation for org.eclipse.xtext.resource.IResourceDescriptions annotated with @com.google.inject.name.Named(value=org.eclipse.xtext.scoping.namespaces.DefaultGlobalScopeProvider.BUILDER_SCOPE) was bound.
  at org.eclipse.emf.query2.syntax.ui.AbstractQueryUiModule.configureIResourceDescriptionsBuilderScope(AbstractQueryUiModule.java:58)
2 errors
	at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:354)
	at com.google.inject.InjectorBuilder.initializeStatically(InjectorBuilder.java:152)
	at com.google.inject.InjectorBuilder.build(InjectorBuilder.java:105)
	at com.google.inject.Guice.createInjector(Guice.java:92)
	at com.google.inject.Guice.createInjector(Guice.java:69)
	at com.google.inject.Guice.createInjector(Guice.java:59)
	at org.eclipse.emf.query2.syntax.ui.internal.QueryActivator.start(QueryActivator.java:39)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
	... 86 more
Re: Can't get XText to work! (Query 2) [message #728438 is a reply to message #728423] Fri, 23 September 2011 05:39 Go to previous messageGo to next message
I installed Xtext 1.0.2 and now it seems to work..
Re: Can't get XText to work! (Query 2) [message #729467 is a reply to message #728423] Mon, 26 September 2011 05:25 Go to previous message
Hi Ricky,
Sorry was away for 4 days Smile.
Glad that you could work with Query2.
Let me know if you face any further problems.
cheers,
Saurav
Previous Topic:cross references & actual container
Next Topic:[CDO] Duplicate annotation using CDO Hibernate
Current Time: Sat Jul 26 20:06:35 EDT 2025
Powered by FUDForum. Page generated in 0.03533 seconds
