Home » Eclipse Projects » Eclipse 4 » Command with parameters and DI ?
Command with parameters and DI ? [message #728308] Thu, 22 September 2011 19:26 Go to next message
Hi guys,
I'm trying to learn how to deal with Commands and E4. I'm using the E4 Contacts as example.
I've created this command:
  <commands xmi:id="_VNE7QOVpEeCBqrdVElCRVQ" elementId="teste.c" commandName="Teste">
    <parameters xmi:id="_1ec7cOVqEeCBqrdVElCRVQ" elementId="meu.par.id" name="meu.par" optional="false"/>
  </commands>
 <children xsi:type="menu:HandledMenuItem" xmi:id="_9Yw44OVlEeCBqrdVElCRVQ" elementId="teste" label="Change to Black" command="_VNE7QOVpEeCBqrdVElCRVQ">
          <parameters xmi:id="_wFhu8OVqEeCBqrdVElCRVQ" elementId="x1" name="meu.par.id" value="example"/>
 </children>
And this handler:
@Execute
	public void execute(
			@Named("meu.par.id") String themeId) {
		logger.log(LogService.LOG_DEBUG, "starting myhandler..." + themeId);
It works well...
But when I try to pass another parameter in the execute method (the same as in the Contacts example), it doesn't work. The execute method is not called:
@Execute
			@Named("meu.par.id") String themeId,
			IThemeEngine engine) {
Am I missing something?
thanks for any help...
Cristiano
Re: Command with parameters and DI ? [message #728386 is a reply to message #728308] Fri, 23 September 2011 03:22 Go to previous messageGo to next message
Your code looks good and because a IThemeEngine should be there all the
time it looks like a bug. Just to make sure can you try using simply
IEclipseContext which is even more guarenteed to be available or use
@Optional on the IThemeEngine.
If this is NOT working please file a bugzilla (you can CC me on the bug)
and post the bug-id here. Ideally we have a minimal example to reproduce.
Tom
Am 23.09.11 01:26, schrieb Cristiano avi:
> Hi guys,
> </commands>
> </children>
> And this handler:
> @Execute
> themeId);
> It works well...
> called:
> @Execute
> themeId);
> Cristiano
Re: Command with parameters and DI ? [message #728533 is a reply to message #728386] Fri, 23 September 2011 08:41 Go to previous messageGo to next message
Hi Tom,
well, if you say that IThemeEngine should be in context all time, so it seems to be a bug.
But I could make it work. What I have to do was to inject IThemeManager and get IThemeEngine from it instead. It works injecting as a field and as method parameter:
        @Inject
	IThemeManager mgr;
@Execute
	public void switchTheme(
		System.out.println("Escolhedo o tema: " + themeId);
		engine = manager.getEngineForDisplay(Display.getCurrent());
		engine.setTheme(themeId, true);
I will file a bugzilla...
cheers
Cristiano
[Updated on: Fri, 23 September 2011 08:41] by Moderator
Re: Command with parameters and DI ? [message #728541 is a reply to message #728533] Fri, 23 September 2011 08:42 Go to previous messageGo to next message
Hm ... maybe I'm wrong and IThemeEngine is not subject of injection.
Tom
Am 23.09.11 14:41, schrieb Cristiano avi:
> Hi Tom,
> HI Tom,
> seems to be a bug.
> @Inject
> IThemeManager mgr;
> @Execute
> cheers
> Cristiano
Re: Command with parameters and DI ? [message #728542 is a reply to message #728541] Fri, 23 September 2011 08:45 Go to previous messageGo to next message
Looks like IThemeEngine is not store in the root context so my
assumption was wrong.
Tom
Am 23.09.11 14:42, schrieb Tom Schindl:
> Tom
>> Hi Tom,
>> HI Tom,
>> seems to be a bug.
>> @Inject
>> IThemeManager mgr;
>> @Execute
>> cheers
>> Cristiano
Re: Command with parameters and DI ? [message #728632 is a reply to message #728542] Fri, 23 September 2011 11:05 Go to previous messageGo to next message
well, it seems that it was once in past, because the e4 Contacts sample(org.eclipse.e4.demo.contacts) at the cvs has this:
public class SwitchThemeHandler {
	@Execute
			@Named("contacts.commands.switchtheme.themeid") String themeId,
cheers
Cristiano
Re: Command with parameters and DI ? [message #741256 is a reply to message #728632] Wed, 19 October 2011 06:48 Go to previous messageGo to next message
I have the same Problem. I can't inject my own parameter:
My Handler
public class MyHandler {
	@Execute
	public void switchTheme(@Named("test.param.id")String param) {
		System.out.println(themeId);
My Command
<commands xmi:id="_xkR8sPo2EeCGFcYVaQwS9g" elementId="myCommandId" commandName="myCommand">
    <parameters xmi:id="_JsNMsPo8EeCGFcYVaQwS9g" elementId="test.param.id" name="test.param" optional="false"/>
  </commands>
<children xsi:type="menu:HandledMenuItem" xmi:id="_VIFMYPo3EeCGFcYVaQwS9g" label="Blue Theme" command="_xkR8sPo2EeCGFcYVaQwS9g">
          <parameters xmi:id="_XbYEsPo3EeCGFcYVaQwS9g" elementId="x1" name="test.param.id" value="example"/>
        </children>
But nothing was executed
EDIT :
okay i need some AddOns
  <addons xmi:id="_XGB3wPZlEd-XstlTZ6nTXg" elementId="org.eclipse.e4.core.commands.service" contributionURI="platform:/plugin/org.eclipse.e4.core.commands/org.eclipse.e4.core.commands.CommandServiceAddon"/>
  <addons xmi:id="_XGB3wPZlEd-XstlTZ6nTXh" elementId="org.eclipse.e4.ui.contexts.service" contributionURI="platform:/plugin/org.eclipse.e4.ui.services/org.eclipse.e4.ui.services.ContextServiceAddon"/>
  <addons xmi:id="_XGB3wPZlEd-XstlTZ6nTXi" elementId="org.eclipse.e4.ui.bindings.service" contributionURI="platform:/plugin/org.eclipse.e4.ui.bindings/org.eclipse.e4.ui.bindings.BindingServiceAddon"/>
  <addons xmi:id="_LK0NgPZmEd-XstlTZ6nTXj" elementId="org.eclipse.e4.ui.workbench.commands.model" contributionURI="platform:/plugin/org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.CommandProcessingAddon"/>
  <addons xmi:id="_LK0NgPZmEd-XstlTZ6nTXk" elementId="org.eclipse.e4.ui.workbench.contexts.model" contributionURI="platform:/plugin/org.eclipse.e4.ui.workbench/org.eclipse.e4.ui.internal.workbench.addons.ContextProcessingAddon"/>
  <addons xmi:id="_LK0NgPZmEd-XstlTZ6nTXl" elementId="org.eclipse.e4.ui.workbench.bindings.model" contributionURI="platform:/plugin/org.eclipse.e4.ui.workbench.swt/org.eclipse.e4.ui.workbench.swt.util.BindingProcessingAddon"/>
[Updated on: Thu, 20 October 2011 03:53] by Moderator
Re: Command with parameters and DI ? [message #880914 is a reply to message #741256] Sun, 03 June 2012 06:54 Go to previous messageGo to next message
You find an example for defining and using parameters in my tutorial: Eclipse 4 Tutorial - Parameters for commands.
Re: Command with parameters and DI ? [message #881399 is a reply to message #880914] Mon, 04 June 2012 09:34 Go to previous messageGo to next message
I'll just add you don't generally @Inject handlers. The context they're created in won't necessarily be the context they're executed in.
PW
Re: Command with parameters and DI ? [message #916004 is a reply to message #881399] Tue, 18 September 2012 07:46 Go to previous messageGo to next message
Dear E4 Developers,
can anyone explain why do we need to define a Command parameter in the model at all??
Couldn't the method ParameterizedCommand.generateCommand simply look at what parameters the execute method in the corresponding handler has? The types can be determined via reflection.
This is for me a useless complexity layer that is making my life difficult - if there is a good reason for this I am grateful if any of you could explain it to me.
I probably misunderstood something.
Laura
Re: Command with parameters and DI ? [message #916009 is a reply to message #916004] Tue, 18 September 2012 07:57 Go to previous messageGo to next message
This way it would have to load all and every handler and remember
there's not always only one handler for a command!
And not all informations you find in the execute-Method are passed as
parameters. e.g. you can get the active shell injected, the current
perspective (in fact anything you get from the current active
IEclipseContext leave).
Tom
Am 18.09.12 13:46, schrieb Laura V:
> Dear E4 Developers,
> model at all??
> Thanks
> Laura
Re: Command with parameters and DI ? [message #916042 is a reply to message #916009] Tue, 18 September 2012 08:52 Go to previous messageGo to next message
Hi Tom
I see your point, thanks for explaining it to me
Laura
Re: Command with parameters and DI ? [message #923056 is a reply to message #916004] Tue, 25 September 2012 11:10 Go to previous messageGo to next message
They're also not quite the parameters you are thinking of.
Command parameters in the definition are for capturing fairly static parameters. Like MenuItem-A is the "Show In Command (view=package explorer)"
The method parameters in @Execute are about accessing the runtime state of the application, and so aren't considered in the command definition.
PW
Re: Command with parameters and DI ? [message #989221 is a reply to message #728308] Wed, 05 December 2012 04:44 Go to previous messageGo to next message
Hello all,
Can anybody explain the purpose of the Name and TypeId attributes of a Command Parameter ?
Re: Command with parameters and DI ? [message #989264 is a reply to message #989221] Wed, 05 December 2012 07:18 Go to previous messageGo to next message
Looking through source code for the creation of parameterized commands, I notice that parameters are always converted (implicitly with a cast or explicitly with a valueConverter) into a String. Does it mean I cannot pass an arbitrary object as a parameter to a command ?
My use case consists in invoking a handler in response to a user event (list item selection). The selected item is to be passed to the @execute method of my handler, which also takes other injected parameters (like the parent shell, MApplication, EPartService). The initial solution was to use a parameterized command, with the selected item as a parameter, but it doesn't work (class cast exception). Thus the above question about TypeId. But ParameterizedCommand.generateCommand() method reads that even with TypeId (which I suppose is linked to a ParameterType object that contains a ValueConverter to convert the value into a String), I cannot implement my use case this way. Am I right ?
[Updated on: Wed, 05 December 2012 07:36] by Moderator
Re: Command with parameters and DI ? [message #1499882 is a reply to message #989264] Fri, 05 December 2014 08:49 Go to previous message
The TypeId is the id of commandParameterType extension of org.eclipse.ui.commands extension point. It is there the ParameterValueConverter can be defined. Then you can refer to parameter value in the @Named in Handler by command's parameter id.
Some sample that is discussed here https://www.eclipse.org/forums/index.php/m/1013263/.
This draft sample dynamically creates the menu using DynamicMenuContribution. It uses the ParameterizedCommand.generateCommand to setWbCommand of such dynamically created HandledMenuItem.
Its possible to implement your usecase. See NHandler and .e4xmi. It prints String passed from model as Object. Uses IEclipseContext in AbstractParameterValueConverter subclass to store the parameter value for Object-String-Object conversion.
For bugzilla: As far as I understood, there is no way to change this value without changing the model if using HandledMenuItem. I don't see the need to limit its type to String in such use case. Maybe there should be some value evaluator or something.
[Updated on: Fri, 05 December 2014 20:04] by Moderator
Previous Topic:Include an XML Editor in my E4 application
Next Topic:Editor Shortcuts not working anymore in Luna
Current Time: Sun Jul 27 09:36:34 EDT 2025
Powered by FUDForum. Page generated in 0.05596 seconds
