Home » Archived » BIRT » BIRT 3.7 Report design(BIRT 2.6.2 report design not work in BIRT 3.7)
BIRT 3.7 Report design [message #727586] Wed, 21 September 2011 11:17 Go to next message
Deployed birtviewer (BIRT 3.7) successfully. I am a newbie to BIRT. The report designs were created in BIRT 2.6. Using this report design, I am able to generate a report in 2.6 ,but in 3.7 I get Get an error "Duplicate Aggregation Name : COUNT". Does anyone have idea what might be the reason for this???
-- Thanks
Re: BIRT 3.7 Report design [message #727660 is a reply to message #727586] Wed, 21 September 2011 14:53 Go to previous messageGo to next message
Do you get this in the BIRT Viewer 3.7, what about the designer? Can
you post the report?
Jason
> -- Thanks
Re: BIRT 3.7 Report design [message #727682 is a reply to message #727660] Wed, 21 September 2011 15:58 Go to previous messageGo to next message
No Message Body
Re: BIRT 3.7 Report design [message #728248 is a reply to message #727660] Thu, 22 September 2011 15:25 Go to previous messageGo to next message
Jason,
Thanks for your reply. Iam attaching my report and I will upload my report design too.
Kavitha
Re: BIRT 3.7 Report design [message #728674 is a reply to message #728248] Fri, 23 September 2011 11:54 Go to previous messageGo to next message
Do you get this same error in the 3.7 designer preview?
Jason
On 9/22/2011 3:25 PM, Kavitha wrote:
> Jason,
> Kavitha
Re: BIRT 3.7 Report design [message #728700 is a reply to message #728674] Fri, 23 September 2011 13:19 Go to previous messageGo to next message
This is the report preview error. More or less the same error
The following items have errors:
Table (id = 1633):
- Can not load the report query: 1633. Errors occurred when generating the report document for the report element with ID 1,633. (Element ID:1633)
Error.ReportQueryLoadingError2 ( 16 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: Can not load the report query: 1633. Errors occurred when generating the report document for the report element with ID 1,633. (Element ID:1633)
at org.eclipse.birt.report.engine.data.dte.DataPresentationEngine.doExecuteQuery(DataPresentationEngine.java:160)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:265)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1897)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.executeQuery(ReportItemExecutor.java:412)
at org.eclipse.birt.report.engine.internal.document.v4.TableItemExecutor.doExecute(TableItemExecutor.java:72)
at org.eclipse.birt.report.engine.internal.document.v4.ReportItemExecutor.execute(ReportItemExecutor.java:294)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.prepareChildExecutor(ContainerExecutor.java:226)
at org.eclipse.birt.report.engine.internal.document.v4.ContainerExecutor.hasNextChild(ContainerExecutor.java:110)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.hasNextChild(WrappedReportItemExecutor.java:86)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.execute(HTMLAbstractLM.java:463)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.execute(HTMLAbstractLM.java:476)
at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.intializeHeaderContent(HTMLListingBandLM.java:98)
at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM.initialize(HTMLListingBandLM.java:50)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.initialize(HTMLTableBandLM.java:44)
at org.eclipse.birt.report.engine.layout.html.HTMLLayoutManagerFactory.createLayoutManager(HTMLLayoutManagerFactory.java:40)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.createLayoutManager(HTMLReportLayoutEngine.java:138)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:68)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.layoutChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLGroupLM.layoutChildren(HTMLGroupLM.java:117)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.layout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layoutChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackingLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:681)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at org.eclipse.birt.report.service.ReportEngineService.renderReport(ReportEngineService.java:1547)
at org.eclipse.birt.report.service.BirtViewerReportService.getPage(BirtViewerReportService.java:204)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.doExecution(AbstractGetPageActionHandler.java:238)
at org.eclipse.birt.report.service.actionhandler.AbstractGetPageActionHandler.__execute(AbstractGetPageActionHandler.java:105)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPage(BirtDocumentProcessor.java:87)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:418)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:230)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:685)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:451)
Re: BIRT 3.7 Report design [message #728726 is a reply to message #728700] Fri, 23 September 2011 14:51 Go to previous messageGo to next message
Kavitha,
Can you open a bugzilla entry for this?
Jason
> Table (id = 1633): - Can not load the report query: 1633. Errors
> ID 1,633. (Element ID:1633) Error.ReportQueryLoadingError2 ( 16 time(s) )
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: BIRT 3.7 Report design [message #728733 is a reply to message #728726] Fri, 23 September 2011 15:44 Go to previous messageGo to next message
Jason,
Thanks for your reply. I opened a Bugzilla entry for this issue (Bug 358770).
Kavitha
Re: BIRT 3.7 Report design [message #733733 is a reply to message #728733] Wed, 05 October 2011 10:37 Go to previous messageGo to next message
Hi Jason,
After specifying the JDBC drivers correctly in the report designer, I was able to preview the report in the report designer successfully. But when I try to generate the report through the birt viewer URL, we are getting the same problem as mentioned above. Any ideas ??
Kavitha
Re: BIRT 3.7 Report design [message #733748 is a reply to message #733733] Wed, 05 October 2011 10:52 Go to previous messageGo to next message
Where do you have the driver in the deployed viewer?
Jason
On 10/5/2011 10:37 AM, Kavitha wrote:
> Hi Jason,
> Kavitha
Re: BIRT 3.7 Report design [message #733750 is a reply to message #733748] Wed, 05 October 2011 10:58 Go to previous messageGo to next message
The driver is placed in the WEB_INF/lib and I included this in the class path.
Kavitha
Re: BIRT 3.7 Report design [message #733751 is a reply to message #733750] Wed, 05 October 2011 10:59 Go to previous messageGo to next message
Sorry, the driver is placed in
WEB-INF/lib
Re: BIRT 3.7 Report design [message #733779 is a reply to message #733751] Wed, 05 October 2011 11:30 Go to previous messageGo to next message
Is it only in the WEB-INF/lib? That should work. Verify that you do
not have it elsewhere in the web viewers classpath.
Jason
> WEB-INF/lib
Re: BIRT 3.7 Report design [message #734944 is a reply to message #733779] Mon, 10 October 2011 09:44 Go to previous messageGo to next message
Jason,
When I remove GROUP_COUNT that has the aggregate function RUNNINGCOUNT in the report design, I dont get the above error. I am able to generate the report with all the data.
Kavitha
Re: BIRT 3.7 Report design [message #734975 is a reply to message #734944] Mon, 10 October 2011 10:40 Go to previous message
Did you update the bug?
Jason
On 10/10/2011 9:44 AM, Kavitha wrote:
> Jason,
> Kavitha
Previous Topic:new chart type : rectangle chart
Next Topic:Web tool platform
Current Time: Fri Jul 25 11:16:36 EDT 2025
Powered by FUDForum. Page generated in 0.04899 seconds
