Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Data Binding Question
Data Binding Question [message #728200] Thu, 22 September 2011 13:55 Go to next message
Hi, I am trying to bind a text control to a String variable. Not sure I'm using the correct terms, but basically I want my String variable to update automatically when I change the text control and vice versa.
I'm using windowbuilder pro and I haven't found an example or tutorial that helps. What do I set as target, target property, model, and model property?
Thanks.
[Updated on: Thu, 22 September 2011 13:56] by Moderator
Re: Data Binding [message #728303 is a reply to message #728200] Thu, 22 September 2011 18:41 Go to previous messageGo to next message
Did you intend to ask this on the eclipse.windowbuilder forum/newsgroup?
> property?
> Thanks.
Re: Data Binding [message #728347 is a reply to message #728200] Fri, 23 September 2011 00:24 Go to previous message
Have you looked at WritableValue?
-Matthew
> property?
> Thanks.
Previous Topic:Seeing SWT warnings on lion with jruby
Next Topic:[closed]
Current Time: Sat Jul 26 18:57:24 EDT 2025
Powered by FUDForum. Page generated in 0.06777 seconds
