Home » Eclipse Projects » Eclipse 4 » unable to run the the css example (Got null pointer exception after launch the css example)
unable to run the the css example [message #728136] Thu, 22 September 2011 11:29 Go to next message
after import the example frpm cvs,launthe example got null pointer exception
at org.eclipse.e4.ui.css.core.impl.engine.CSSEngineImpl.<init>(CSSEngineImpl.java:45)
at org.eclipse.e4.ui.css.swt.engine.AbstractCSSSWTEngineImpl.<init>(AbstractCSSSWTEngineImpl.java:38)
which is the line
IExtensionPoint extPoint = registry.getExtensionPoint("org.eclipse.e4.u.css.core.elementProvider");
anybody knows how to fix this?
thanks.
Re: unable to run the the css example [message #728141 is a reply to message #728136] Thu, 22 September 2011 11:42 Go to previous message
by the way, my eclipse version is 4.1.0 build id I20110620-1631. i didn't import the org.eclipse.e4.ui.css.legacy project, as that one gives me lot of unresolved import errors.
Previous Topic:Perspective Switcher Bar in e4
Next Topic:E4 Eclipse product export wizard
Current Time: Sat Jul 26 21:12:33 EDT 2025
Powered by FUDForum. Page generated in 0.03796 seconds
