Home » Archived » BIRT » [SOLVED] Problem with OSGI platform (BIRT 3.7 on JBoss AS 6)
[SOLVED] Problem with OSGI platform (BIRT 3.7 on JBoss AS 6) [message #727422] Wed, 21 September 2011 05:15 Go to next message
I'm trying to use BIRT 3.7 in a web application that runs on JBoss AS 6. The report engine is invoked from a servlet which then presents a PDF to the user.
The problem is that it only works one time. The next time i try to render a report i get an exception on:
Platform.startup();
With the exception:
10:23:15,737 ERROR [STDERR] org.eclipse.birt.core.exception.BirtException: error.CannotStartupOSGIPlatform
10:23:15,738 ERROR [STDERR] 	at org.eclipse.birt.core.framework.Platform.startup(Platform.java:81)
[JBoss trace]
10:23:15,744 ERROR [STDERR] Caused by: org.eclipse.birt.core.framework.FrameworkException: Cant register the ExtensionRegistry classpath
10:23:15,745 ERROR [STDERR] 	at org.eclipse.birt.core.framework.jar.ServiceLauncher.startup(ServiceLauncher.java:99)
10:23:15,745 ERROR [STDERR] 	at org.eclipse.birt.core.framework.Platform.startup(Platform.java:75)
10:23:15,745 ERROR [STDERR] 	... 37 more
10:23:15,745 ERROR [STDERR] Caused by: org.eclipse.core.runtime.CoreException: Extension registry provider is already set.
10:23:15,746 ERROR [STDERR] 	at org.eclipse.core.internal.registry.RegistryProviderFactory.setDefault(RegistryProviderFactory.java:31)
10:23:15,746 ERROR [STDERR] 	at org.eclipse.core.runtime.RegistryFactory.setDefaultRegistryProvider(RegistryFactory.java:129)
10:23:15,746 ERROR [STDERR] 	at org.eclipse.birt.core.framework.jar.ServiceLauncher.startup(ServiceLauncher.java:84)
10:23:15,746 ERROR [STDERR] 	... 38 more
In order to get BIRT to run on JBoss i had to remove the jar-files:
org.eclipse.core.resources_3.7.100.v20110510-0712.jar
org.apache.xerces_2.9.0.v201101211617.jar
and i also get an exception during boot from the org.eclipse.osgi libraries:
11:13:06,217 WARN  [ClassLoaderManager] Unexpected error during load of:org.osgi.service.log.package-info: java.lang.ClassFormatError: Illegal class name "org/osgi/service/log/package-info" in class file org/osgi/service/log/package-info
	at java.lang.ClassLoader.defineClass1(Native Method) [:1.6.0_26]
	at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631) [:1.6.0_26]
	at java.lang.ClassLoader.defineClass(ClassLoader.java:615) [:1.6.0_26]
	at org.jboss.classloader.spi.base.BaseClassLoader.access$200(BaseClassLoader.java:52) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:650) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:609) [jboss-classloader.jar:2.2.0.GA]
	at java.security.AccessController.doPrivileged(Native Method) [:1.6.0_26]
	at org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:608) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:585) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseDelegateLoader.loadClass(BaseDelegateLoader.java:156) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.filter.FilteredDelegateLoader.doLoadClass(FilteredDelegateLoader.java:141) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.filter.FilteredDelegateLoader.loadClass(FilteredDelegateLoader.java:132) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.ClassLoadingTask$ThreadTask.run(ClassLoadingTask.java:461) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.ClassLoaderManager.nextTask(ClassLoaderManager.java:262) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.ClassLoaderManager.process(ClassLoaderManager.java:161) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:260) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:1152) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoader.loadClassFromDomain(BaseClassLoader.java:886) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoader.doLoadClass(BaseClassLoader.java:505) [jboss-classloader.jar:2.2.0.GA]
	at org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoader.java:450) [jboss-classloader.jar:2.2.0.GA]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247) [:1.6.0_26]
	at java.lang.Class.forName0(Native Method) [:1.6.0_26]
	at java.lang.Class.forName(Class.java:247) [:1.6.0_26]
Anyone have any idea of why this happens and how to solve it?
[Updated on: Thu, 22 September 2011 04:12] by Moderator
Re: Problem with OSGI platform (BIRT 3.7 on JBoss AS 6) [message #727652 is a reply to message #727422] Wed, 21 September 2011 14:45 Go to previous messageGo to next message
Erik,
You should only be starting the platform once and re-using it. Take a
look at the attached project. I assume you have the libs from the 3.7
runtime in your web-inf/lib directory and there is no web-inf/platform
directory in you application.
Jason
> the user.
> Platform.startup();
> With the exception:
> [JBoss trace]
> already set.
> libraries:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
  • Attachment: WebReport.zip
    (Size: 78.48KB, Downloaded 1764 times)
Re: Problem with OSGI platform (BIRT 3.7 on JBoss AS 6) [message #727913 is a reply to message #727652] Thu, 22 September 2011 04:11 Go to previous messageGo to next message
Thanks Jason, now it works properly!
The only problem is the exception from the osgi-jars, but i'm hoping JBoss loads the rest of the classes in the jar.
Re: Problem with OSGI platform (BIRT 3.7 on JBoss AS 6) [message #727929 is a reply to message #727913] Thu, 22 September 2011 05:01 Go to previous message
Just a quick comment to this problem. I was having similar symptoms but on Websphere. The OSGi service could not be started and the error message also contained
It was solved by changing the class loader order. See http://wiki.eclipse.org/BirtPOJO_Viewer_WebSphere_Deployment for more details
Previous Topic:Merging datasets
Next Topic:[SOLVED] How to configure Dataset using DE API
Current Time: Sat Jul 26 00:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.05382 seconds
