[SOLVED] Problem with OSGI platform (BIRT 3.7 on JBoss AS 6) [message #727422] |
Wed, 21 September 2011 05:15  |
I'm trying to use BIRT 3.7 in a web application that runs on JBoss AS 6. The report engine is invoked from a servlet which then presents a PDF to the user.
The problem is that it only works one time. The next time i try to render a report i get an exception on:
With the exception:
10:23:15,737 ERROR [STDERR] org.eclipse.birt.core.exception.BirtException: error.CannotStartupOSGIPlatform
10:23:15,738 ERROR [STDERR] at org.eclipse.birt.core.framework.Platform.startup(Platform.java:81)
[JBoss trace]
10:23:15,744 ERROR [STDERR] Caused by: org.eclipse.birt.core.framework.FrameworkException: Cant register the ExtensionRegistry classpath
10:23:15,745 ERROR [STDERR] at org.eclipse.birt.core.framework.jar.ServiceLauncher.startup(ServiceLauncher.java:99)
10:23:15,745 ERROR [STDERR] at org.eclipse.birt.core.framework.Platform.startup(Platform.java:75)
10:23:15,745 ERROR [STDERR] ... 37 more
10:23:15,745 ERROR [STDERR] Caused by: org.eclipse.core.runtime.CoreException: Extension registry provider is already set.
10:23:15,746 ERROR [STDERR] at org.eclipse.core.internal.registry.RegistryProviderFactory.setDefault(RegistryProviderFactory.java:31)
10:23:15,746 ERROR [STDERR] at org.eclipse.core.runtime.RegistryFactory.setDefaultRegistryProvider(RegistryFactory.java:129)
10:23:15,746 ERROR [STDERR] at org.eclipse.birt.core.framework.jar.ServiceLauncher.startup(ServiceLauncher.java:84)
10:23:15,746 ERROR [STDERR] ... 38 more
In order to get BIRT to run on JBoss i had to remove the jar-files:
org.eclipse.core.resources_3.7.100.v20110510-0712.jar
org.apache.xerces_2.9.0.v201101211617.jar
and i also get an exception during boot from the org.eclipse.osgi libraries:
11:13:06,217 WARN [ClassLoaderManager] Unexpected error during load of:org.osgi.service.log.package-info: java.lang.ClassFormatError: Illegal class name "org/osgi/service/log/package-info" in class file org/osgi/service/log/package-info
at java.lang.ClassLoader.defineClass1(Native Method) [:1.6.0_26]
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631) [:1.6.0_26]
at java.lang.ClassLoader.defineClass(ClassLoader.java:615) [:1.6.0_26]
at org.jboss.classloader.spi.base.BaseClassLoader.access$200(BaseClassLoader.java:52) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:650) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoader$2.run(BaseClassLoader.java:609) [jboss-classloader.jar:2.2.0.GA]
at java.security.AccessController.doPrivileged(Native Method) [:1.6.0_26]
at org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:608) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoader.loadClassLocally(BaseClassLoader.java:585) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseDelegateLoader.loadClass(BaseDelegateLoader.java:156) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.filter.FilteredDelegateLoader.doLoadClass(FilteredDelegateLoader.java:141) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.filter.FilteredDelegateLoader.loadClass(FilteredDelegateLoader.java:132) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.ClassLoadingTask$ThreadTask.run(ClassLoadingTask.java:461) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.ClassLoaderManager.nextTask(ClassLoaderManager.java:262) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.ClassLoaderManager.process(ClassLoaderManager.java:161) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:260) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoaderDomain.loadClass(BaseClassLoaderDomain.java:1152) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoader.loadClassFromDomain(BaseClassLoader.java:886) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoader.doLoadClass(BaseClassLoader.java:505) [jboss-classloader.jar:2.2.0.GA]
at org.jboss.classloader.spi.base.BaseClassLoader.loadClass(BaseClassLoader.java:450) [jboss-classloader.jar:2.2.0.GA]
at java.lang.ClassLoader.loadClass(ClassLoader.java:247) [:1.6.0_26]
at java.lang.Class.forName0(Native Method) [:1.6.0_26]
at java.lang.Class.forName(Class.java:247) [:1.6.0_26]
Anyone have any idea of why this happens and how to solve it?
[Updated on: Thu, 22 September 2011 04:12] by Moderator
Re: Problem with OSGI platform (BIRT 3.7 on JBoss AS 6) [message #727652 is a reply to message #727422] |
Wed, 21 September 2011 14:45   |
Erik,
You should only be starting the platform once and re-using it. Take a
look at the attached project. I assume you have the libs from the 3.7
runtime in your web-inf/lib directory and there is no web-inf/platform
directory in you application.
Jason
> the user.
> Platform.startup();
> With the exception:
> [JBoss trace]
> already set.
> libraries:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.05486 seconds
