Home » Eclipse Projects » Eclipse Platform » How transform VariableDeclarationStatement to ExpressionStatement using AST(Using AST Abstract Syntax Tree how Cast VariableDeclarationStatement into ExpressionStatement )
How transform VariableDeclarationStatement to ExpressionStatement using AST [message #727599] Wed, 21 September 2011 11:42 Go to next message
I have an object that is used in many methods, so I want to have its declaration on class scope and keep its current behavior, in other words I want to add a fixture.
Getting from this:
public String method1() {
    StringBuilder sb = new StringBuilder("test1");
    return sb.toString();
to that:
private StringBuilder sb;
	sb = new StringBuilder("test1"); //problem is to keep semicolumn;
Taking the example above the user will select StringBuilder to do the refactoring.
Doing so, for core.dom.AST the selection will be a VariableDeclarationStatement, inside this object there is a VariableDeclarationFragment wich is almost what I need, it brings "sb = new StringBuilder("test1")" whithout semicolumn, I need to concat a semicolumn to this object to replace the original VariableDeclarationStatement becoming in a ExpressionStatement.
Can anyone please help me?
thanks
Re: How transform VariableDeclarationStatement to ExpressionStatement using AST [message #728596 is a reply to message #727599] Fri, 23 September 2011 10:11 Go to previous messageGo to next message
I believe I´ve got close in the code below but the ClassInstanceCreation did not work.
	private void testAssignement2(ASTNode node) {
		// get AST block
		Block blkParent = (Block) node.getParent();
		// STATEMENT: MISSING = MISSING
		Assignment a = blkParent.getAST().newAssignment();
		a.setOperator(Assignment.Operator.ASSIGN);
		// STATEMENT: this.varName = MISSING
		FieldAccess fa = blkParent.getAST().newFieldAccess();
		fa.setExpression(blkParent.getAST().newThisExpression());
		fa.setName(blkParent.getAST().newSimpleName("varName"));
		a.setLeftHandSide(fa);
		// STATEMENT: new StringBuilder();
		ClassInstanceCreation cic = null;
		cic = blkParent.getAST().newClassInstanceCreation();
		//it does not work but many examples on net leed to it.
		cic.setName(blkParent.getAST().newSimpleName("StringBuilder"));
		// STATEMENT: this.varName = new MISSING()
		fa.setName(blkParent.getAST().newSimpleName(cic.toString()));
		a.setRightHandSide(fa);
		// ENCAPSULATE THE ASSIGNEMENT INSERTING A SEMICOLUMN
		// STATEMENT: this.varName = new MISSING();
		ExpressionStatement ess = blkParent.getAST().newExpressionStatement(a);
		setASTObject(ess);
Re: How transform VariableDeclarationStatement to ExpressionStatement using AST [message #729055 is a reply to message #728596] Sat, 24 September 2011 17:51 Go to previous message
Just in case someone needs the same thing, here is the answer.
The problem was in the ClassInstanceCreation I should use setType intead of setName.
		// get AST block
		cic.setType( blkParent.getAST().newSimpleType(blkParent.getAST().newSimpleName("StringBuilder") ));
		// STATEMENT: this.varName = new StringBuilder()
		a.setRightHandSide(cic);
		setASTObject(ess);
Previous Topic:Eclipse Layout Problem on Bidi OS
Next Topic:Eclipse IDE for Java EE Developers Helios for Linux PowerPC?
Current Time: Wed Jul 23 10:51:29 EDT 2025
Powered by FUDForum. Page generated in 0.07325 seconds
