Home » Language IDEs » C / C++ IDE (CDT) » Cannot build PVCS projects
Cannot build PVCS projects [message #71469] Tue, 27 May 2003 03:53 Go to next message
Originally posted by: bjorn.royson.ec.se
I opened a project from PVCS. I then tried to create a run configuration for
a .exe file in that project but projects opened from PVCS does not show in
the project browser. If I delete the project (no delete) and creates a C
project, I can create a build configuration but then I can't check out /in
the sources. Any ideas anyone?
Win2000, Eclipse 2.1, CDT 1.1
/Bj
Re: Cannot build PVCS projects [message #72659 is a reply to message #71469] Sun, 01 June 2003 20:20 Go to previous messageGo to next message
Björn Royson schrieb:
> Hi
After you checked out the project, try the "Convert to C/C++ Project"
Wizard. Maybe that will help, since it will create a .cdtproject file.
Re: Cannot build PVCS projects [message #72744 is a reply to message #72659] Tue, 03 June 2003 05:37 Go to previous message
That did the trick. I did not even know that such a wizard existed. I had to
customize the C perspective to find the option. It is enabled from now on.
Thank you from
/Bj
Previous Topic:Terminate the C++ program error
Next Topic:Error installing cdt 1.0.1 within eclipse 2.0.2 (win32)
Current Time: Fri Nov 07 04:30:52 EST 2025
Powered by FUDForum. Page generated in 0.03703 seconds
