How to Connect to dynamic datasource using jdbc datasource [message #727359] |
Wed, 21 September 2011 00:52  |
Hi All,
can somebody help me?
how to connect to dynamic database in BIRT using JDBC connection?
i found that in scripted datasource example, the example using class as the datasource but i want the jdbc datasource but it's dynamic.
i will explain the condition :
let's say i have a parameter named "DBPARAM".
in the beforeOpen events in datasource we put script :
if DBPARAM = "beta" then
The datasource connect to "serverBeta"
else
The datasource connect to "serverAlpha"
can we do this programmatically or must be in designer or how should i do to accomplish that condition?
Re: How to Connect to dynamic datasource using jdbc datasource [message #727876 is a reply to message #727651] |
Thu, 22 September 2011 02:31   |
Thx Jason
is this true, if i use sqlserver :
if( params["DBPARAM"].value == "beta"){
this.setExtensionProperty("odaURL","jdbc:sqlserver://server1/northwind;");
}else{
and also how can i get information for the property like "odaURL" in the setExtensionProperty?
i mean i don't know if the parameter for the "password", "username", etc.
Jason Weathersby wrote on Wed, 21 September 2011 14:38You could always set the oda url like:
this.setExtensionProperty("odaURL","jdbc:mysql://localhost/mysql");
}else{
if the beforeOpen script of the data source. You could also use
connection profile and have one for alpha and one for beta.
Jason
On 9/21/2011 12:52 AM, cbr125x wrote:
> Hi All, can somebody help me?
> if DBPARAM = "beta" then The datasource connect to "serverBeta"
> else
Re: How to Connect to dynamic datasource using jdbc datasource [message #728159 is a reply to message #727876] |
Thu, 22 September 2011 11:58   |
That should work. Take a look at the xml view to see the property names:
<property
name="odaDriverClass">com.mysql.jdbc.Driver</property>
<property name="odaURL">jdbc:mysql://localhost/mydb</property>
<property name="odaUser">root</property>
<encrypted-property name="odaPassword"
encryptionID="base64">cm9vdA==</encrypted-property>
<property name="odaJndiName">jdbc/MyDataSource</property>
ie odaUser..
Jason
On 9/22/2011 2:31 AM, cbr125x wrote:
> Thx Jason
> is this true, if i use sqlserver : if( params["DBPARAM"].value == "beta"){
> }else{
> setExtensionProperty? i mean i don't know if the parameter for the
>> }else{
>> Jason
>> > else
FUDForum. Page generated in 0.11965 seconds
