Home » Archived » BIRT » ods limitations?
ods limitations? [message #727157] |
Tue, 20 September 2011 10:42  |
is it possible, that the ods emitter is still beta? i tried some of my reports, and most of them produced an exception, like:
org.eclipse.birt.report.engine.emitter.ods.OdsEmitter needOutputInMasterPage
Warning: ODS page header and footer don't support html text.
the contenttype of the elements in the header of the masterpage is "auto"
org.eclipse.birt.report.engine.odf.AbstractOdfEmitter save
Schwerwiegend: Stream closed
java.io.IOException: Stream closed
at java.util.zip.ZipOutputStream.ensureOpen(ZipOutputStream.java:82)
at java.util.zip.ZipOutputStream.closeEntry(ZipOutputStream.java:231)
at org.eclipse.birt.report.engine.odf.pkg.Package.writeManifest(Package.java:188)
at org.eclipse.birt.report.engine.odf.pkg.Package.close(Package.java:120)
at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.save(AbstractOdfEmitter.java:166)
at org.eclipse.birt.report.engine.odf.AbstractOdfEmitter.end(AbstractOdfEmitter.java:143)
at org.eclipse.birt.report.engine.emitter.ods.OdsEmitter.end(OdsEmitter.java:552)
this one seems to appear for every report, but obviously i can ignore this(?), the few reports that are producing an output, also have this exception
Warning: ODS page header or footer only accept a table no more than 1 row and 3 columns.
my report has a table with one row and two columns as page header, so i don't understand why this warning appears
ODT emitter works well, no problems with that one. The ODS emitter is kind of a special one, isn't it? A simple report with a table of 5 colums just generates the first column and the footer, the rest of the content won't be generated. In ODT (or pdf, xls, doc, ... ) everything is ok, just ODS seems to be buggy. Can anyone acknowledge this behaviour, or tell me what i'm doing wrong here? Is it really necessary, to implement special commands, just for the output to ODS?
thx in advance,
hage
[Updated on: Tue, 20 September 2011 10:43] by Moderator
Re: ods limitations? [message #727193 is a reply to message #727157] |
Tue, 20 September 2011 11:09   |
Can you post the report or write a report with the sample db that
reproduces the issue? This may be a bug in the emitter. If we can
reproduce the issue we can fix it.
Jason
On 9/20/2011 10:42 AM, hage wrote:
> at
> at
> at
> at
> exception
> row and 3 columns.
> content won't be generated. In ODT (or pdf, ... ) everything is ok, just
> thx in advance,
> hage
Re: ods limitations? [message #728435 is a reply to message #727193] |
Fri, 23 September 2011 05:32   |
again, sorry for replying that late.
i generated a report (see attachment), that reproduces the behaviour i described before. in pdf output, everything is fine, in ods just the first column is generated. meanwhile i determined the cause for this:
if i remove the grid in the footer on the masterpage, all three columns are shown in the ods output. pdf output is not affected by that footer.
the log output with loglevel "WARNING" is this:
23.09.2011 11:24:10 org.eclipse.birt.report.engine.emitter.ods.OdsEmitter needOutputInMasterPage
WARNUNG: ODS page header or footer only accept a table no more than 1 row and 3 columns.
23.09.2011 11:24:10 org.eclipse.birt.report.engine.odf.AbstractOdfEmitter save
SCHWERWIEGEND: Stream closed
at java.util.zip.ZipOutputStream.ensureOpen(ZipOutputStream.java:70)
at java.util.zip.ZipOutputStream.closeEntry(ZipOutputStream.java:189)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitter.end(CompositeContentEmitter.java:65)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:182)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
(so, i don't think this is a bug in the emitter, sorry for my wrong assumption)
my user should be able to choose the output format by himself, so i need a solution that works for all formats, AND have the pagecount on every page, how can i achieve that?
(edit: with the footer removed, i still get this logoutput:
23.09.2011 11:25:47 org.eclipse.birt.report.engine.odf.AbstractOdfEmitter save
at
but a working output, seems like i can ignore this?)
thx in advance,
hage
[Updated on: Fri, 23 September 2011 05:33] by Moderator
Re: ods limitations? [message #728645 is a reply to message #728435] |
Fri, 23 September 2011 11:22   |
This does look like a bug to me. It would be good to log it. As a work
around can you set the visibility expression for the grid in the footer
to not display in ODS. I did it with your attached report and it
worked. I also cleared the footer and used the page n of m variable and
it worked as well.
Jason
> at
Re: ods limitations? [message #729436 is a reply to message #727157] |
Mon, 26 September 2011 03:52  |
ok, using that visibility function does it for me. page count in tables isn't that usefull at all, so my users should be able to live without that (that n of m function, without a grid, does not work here for ods).
thx for your help,
hage
Current Time: Wed Jul 23 00:01:02 EDT 2025
Powered by FUDForum. Page generated in 0.04503 seconds
