Home » Archived » M2M (model-to-model transformation) » multiple pattern matching with resolveTemp
multiple pattern matching with resolveTemp [message #72625] Fri, 18 January 2008 09:57 Go to next message
Originally posted by: adilanwar10.yahoo.fr
Hi all,
first, i used a part of the AMW metamodel which the class WLink is declared
as abstract, and ClassConformityR, PropertyEqualityR are two classes which
inherit from WLink :
abstract class WLink {
reference child[0-*] order container : WLink oppositeOf parent;
reference parent : Wlink opposite child;
class ClassConformityR extends WLink{
class PropertyEqualityR extends WLink{
In my ATL transformation i create the matched rules above :
abstract rule ElementMatchingRule
from e1 : UML2!Element,e2 : UML2!Element(e1.match(e2))
to r : AMW!WLink
rule ClassConformityRule extends ElementMatchingRule{
from e1: UML2!Class, e2: UML2!Class(e1.match(e2))
to r : AMW!ClassConformityR}
rule PropertyEqualityRule extends ElementMatchingRule{
from e1: UML2!property, e2: UML2!Property(e1.match(e2))
to r : AMW!PropertyEqualityR (
parent <- thisModule.resolveTemp(e1.class,'r') )}
when i use the resolveTemp function i have an exception , how can i create
the reference parent to the ClassConformityR
Adil
GRAVE: ****** BEGIN Stack Trace
GRAVE: message: ERROR: could not find operation getNamedTargetFromSource on
Void having supertypes: [OclAny]
GRAVE: A.main() : ??#86 null
GRAVE: local variables = {self=UML2Corresp : ASMModule}
GRAVE: local stack = []
GRAVE: A.__exec__() : ??#98 null
Re:[ATL] multiple pattern matching with resolveTemp [message #72640 is a reply to message #72625] Fri, 18 January 2008 10:06 Go to previous messageGo to next message
sorry i miss [ATL],
"Adil Anwar" <adilanwar10@yahoo.fr> a
Re: [ATL] multiple pattern matching with resolveTemp [message #72718 is a reply to message #72640] Fri, 18 January 2008 11:48 Go to previous messageGo to next message
Originally posted by: mddfabro.ilog.fr
you should use tuples in the resolveTemp if it refers to rules that have
more than one input pattern.
Your resolveTemp should be similar to the code below:
Tuple {
e1 = e1.class,
e2 =
-- here you should put some condition to get the e2 element,
-- for instance:
UML2!Element.allInstances()->select ( e | e1.class.match(e))->first()
} ,'r') )}
Marcos.
Adil Anwar wrote:
> sorry i miss [ATL],
> "Adil Anwar" <adilanwar10@yahoo.fr> a écrit dans le message de news:
> fmqepe$7fj$1@build.eclipse.org...
>> Hi all,
>> declared as abstract, and ClassConformityR, PropertyEqualityR are two
>> classes which inherit from WLink :
>> to r : AMW!WLink
>> Thanks,
>> Adil
>> on Void having supertypes: [OclAny]
Re: [ATL] multiple pattern matching with resolveTemp [message #72807 is a reply to message #72718] Fri, 18 January 2008 13:10 Go to previous messageGo to next message
Thanks Marcos,
now, I was able to run my transformation without having an execption,
but i still have the same problem , no value was affected into variable
parent in my target model !!
is still this a problem with resolveTemp ??
Adil
> transformation
"Marcos Didonet Del Fabro" <mddfabro@ilog.fr> a
Re: [ATL] multiple pattern matching with resolveTemp [message #72821 is a reply to message #72807] Fri, 18 January 2008 13:31 Go to previous message
Hi Marcos,
the problem is resolved when i write this code in the do section.
do {
r.parent <- thisModule.resolveTemp(
Tuple{
e1= e1.class,
e2 = e2.class},'r');
thanks a lot
Adil
Previous Topic:[ATL] intermodel reference assignment not working...
Next Topic:[ATL] Converting XML to EMF/Ecore-based Language
Current Time: Wed Jul 23 20:30:21 EDT 2025
Powered by FUDForum. Page generated in 0.03839 seconds
