Need help with XML Data source parametrized report [message #717339] |
Fri, 19 August 2011 23:04  |
I am trying something.
I need to parametrize this report so it can filter the Start and End Dates. I am unable to map the parameters.
How do I achieve run time parameter filtering for an XML datasource report?
Also how do I get data from a second XML file into the report ( for calculation) when I cannot create a join data set ( no data in common)? Please see attached pdf for calculation of the Utilization % column.
Dont worry about the graph.
Please also find attached the report and source XML files.
Please advise.
Re: Need help with XML Data source parametrized report [message #726855 is a reply to message #718620] |
Mon, 19 September 2011 13:55   |
Hi Jason,
Please take a look at the attached XML. How can I get the AggUtilPCT field as the Y-axis of the chart and unique dates on X-axis. In other words I want the same grouping as the detail report in the chart. I tried basing the chart on both the table and the final dataset...but I cant get the right values.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22" id="1">
<property name="author">Kumar Krishnan</property>
<property name="createdBy">Eclipse BIRT Designer Version 3.7.0.v20110602 Build <3.7.0.v20110607-1526></property>
<text-property name="title">New Report</text-property>
<property name="units">in</property>
<method name="initialize"><![CDATA[// INSTRUCTIONS:
// If you use one of the date parameters listed below you need to:
// - uncomment the two lines below that correspond to the parameter you're using
// - add the required parameters from the library
//NOTE: use this code when setting the date parameter to current date
//var d = new Date();
//var curr_date = d.getDate();
//var curr_month = d.getMonth();
//curr_month++;
//var curr_year = d.getFullYear();
//set the Start Date parameter
//params["strMilliFrom"].value = (params["pStartDate"].value).toString();
//if (params["strStartDate"].value == "1900-01-01" || params["strStartDate"].value == "01/01/1900")
// params["strStartDate"].value =(curr_month + "/" + curr_date + "/" + curr_year);
// params["pStartDate"].value = (params["strStartDate"].value).toString();
//set the End Date parameter
//params["strEndDate"].value = (params["pEndDate"].value).toString();
//if (params["strEndDate"].value == "1900-01-01" || params["strEndDate"].value == "01/01/1900")
// params["strEndDate"].value =(curr_month + "/" + curr_date + "/" + curr_year);
// params["pEndDate"].value = (params["strEndDate"].value).toString();
//set the Transaction Date parameter
//params["strTransactionDate"].value = (params["pTransactionDate"].value).toString();
//if (params["strTransactionDate"].value == "1900-01-01" || params["strTransactionDate"].value == "01/01/1900")
// params["strTransactionDate"].value =(curr_month + "/" + curr_date + "/" + curr_year);
// params["pTransactionDate"].value = (params["strTransactionDate"].value).toString();
//set the Run Date parameter
//params["strMilliFrom"].value = (params["prmStartDate"].value).toString();
//params["strMilliFrom"].value = params["strMilliFrom"].value * (24 * 60 * 60 * 1000)
//if (params["strDate"].value == "1900-01-01" || params["strDate"].value == "01/01/1900")
// params["strDate"].value =(curr_month + "/" + curr_date + "/" + curr_year);
// params["pDate"].value = (params["strDate"].value).toString();
]]></method>
<text-property name="displayName">Report Name</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<parameters>
<scalar-parameter name="prmStartDate" id="642">
<property name="hidden">false</property>
<text-property name="promptText">Start Date</text-property>
<property name="valueType">static</property>
<property name="isRequired">true</property>
<property name="dataType">date</property>
<property name="distinct">true</property>
<simple-property-list name="defaultValue">
<value type="constant">1970-01-15</value>
</simple-property-list>
<list-property name="selectionList"/>
<property name="paramType">simple</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Custom</property>
<property name="pattern">dd/MM/yyyy</property>
</structure>
</scalar-parameter>
<scalar-parameter name="prmEndDate" id="643">
<text-property name="promptText">End Date</text-property>
<value type="constant">1970-01-15 12:30:00</value>
</structure>
</scalar-parameter>
<scalar-parameter name="strMilliFrom" id="644">
<property name="hidden">true</property>
<property name="isRequired">false</property>
<property name="dataType">string</property>
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="strMilliTo" id="645">
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source extensionID="org.eclipse.datatools.enablement.oda.xml" name="UserUsage DataSource" id="7">
<method name="beforeOpen"><![CDATA[//filelist = this.getExtensionProperty("FILELIST");
//filelisturl = filelist.substring(0,filelist.indexOf("=")+1);
//this.setExtensionProperty("FILELIST", filelisturl + params["prmStartDate"]);]]></method>
<property name="FILELIST">D:\My Documents\Kumar\Proj\Odesk\GlobalMaps -Efrat\1st Report\UserUsage2.xml</property>
</oda-data-source>
<oda-data-source extensionID="org.eclipse.datatools.enablement.oda.xml" name="LicenseServer Data Source" id="8">
<property name="FILELIST">D:\My Documents\Kumar\Proj\Odesk\GlobalMaps -Efrat\1st Report\LicenseServerInfo2.xml</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet" name="UserUsage Data Set" id="9">
<property name="nullsOrdering">nulls lowest</property>
<list-property name="computedColumns">
<structure>
<property name="name">StartTime_DATE</property>
<expression name="expression">var df = new Date( row["start_time"] *1000);
df.toGMTString();
df</expression>
<property name="dataType">date-time</property>
</structure>
<structure>
<property name="name">EndTime_Date</property>
<expression name="expression">var df = new Date( row["end_time"]*1000);
df.toGMTString();
df</expression>
</structure>
<structure>
<property name="name">Start_DATE</property>
<expression name="expression">row["StartTime_DATE"]</expression>
</structure>
<structure>
<property name="name">END_DATE</property>
<expression name="expression">row["EndTime_Date"]</expression>
</structure>
<structure>
<property name="name">Cnt_user</property>
<property name="dataType">integer</property>
<property name="aggregateFunction">COUNTDISTINCT</property>
<list-property name="arguments">
<structure>
<property name="name">Expression</property>
<expression name="value">row["user_name"]</expression>
</structure>
</list-property>
</structure>
<structure>
<property name="name">UsageHours</property>
<expression name="expression">(row["end_time"]-row["start_time"])/(60*60)</expression>
<property name="dataType">float</property>
<structure>
<expression name="value">(row["end_time"]-row["start_time"])/(60*60*1000)</expression>
</structure>
</list-property>
<expression name="filterExpr">row["start_time"]</expression>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">user_name</property>
<property name="analysis">attribute</property>
<property name="onColumnLayout">false</property>
<text-property name="heading">user_name</text-property>
<property name="analysisColumn">user_name</property>
</structure>
<structure>
<property name="columnName">hostname</property>
<text-property name="heading">hostname</text-property>
<property name="analysisColumn">hostname</property>
</structure>
<structure>
<property name="columnName">start_time</property>
<text-property name="heading">start_time</text-property>
<property name="analysisColumn">start_time</property>
</structure>
<structure>
<property name="columnName">end_time</property>
<text-property name="heading">end_time</text-property>
<property name="analysisColumn">end_time</property>
</structure>
<structure>
<property name="columnName">vendor</property>
<text-property name="heading">vendor</text-property>
<property name="analysisColumn">vendor</property>
</structure>
<structure>
<property name="columnName">server</property>
<text-property name="heading">server</text-property>
<property name="analysisColumn">server</property>
</structure>
<structure>
<property name="columnName">name</property>
<text-property name="heading">name</text-property>
<property name="analysisColumn">name</property>
</structure>
<structure>
<property name="columnName">product_name</property>
<text-property name="heading">product_name</text-property>
<property name="analysisColumn">product_name</property>
</structure>
<structure>
<property name="columnName">usagetime</property>
<text-property name="heading">usagetime</text-property>
<property name="analysisColumn">usagetime</property>
</structure>
<structure>
<property name="columnName">projectname</property>
<text-property name="heading">projectname</text-property>
<property name="analysisColumn">projectname</property>
</structure>
<structure>
<property name="columnName">groupname</property>
<text-property name="heading">groupname</text-property>
<property name="analysisColumn">groupname</property>
</structure>
<structure>
<property name="columnName">ip</property>
<text-property name="heading">ip</text-property>
<property name="analysisColumn">ip</property>
</structure>
</list-property>
<list-property name="filter"/>
<list-property name="parameters"/>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">user_name</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">hostname</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">start_time</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">end_time</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">vendor</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">server</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">name</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">product_name</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">usagetime</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">projectname</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">groupname</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">ip</property>
</structure>
<structure>
<property name="position">13</property>
</structure>
<structure>
<property name="position">14</property>
</structure>
<structure>
<property name="position">15</property>
</structure>
<structure>
<property name="position">16</property>
</structure>
<structure>
<property name="position">17</property>
</structure>
<structure>
<property name="position">18</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[//this.queryText = this.queryText + " and CAST(payments.payment_date AS DATE ) between '" + params["prmFromDate"].value +"' and '" + params["prmToDate"].value + "'";]]></method>
<property name="dataSource">UserUsage DataSource</property>
<structure>
<property name="nativeName">user_name</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">hostname</property>
</structure>
<structure>
<property name="nativeName">start_time</property>
</structure>
<structure>
<property name="nativeName">end_time</property>
</structure>
<structure>
<property name="nativeName">vendor</property>
</structure>
<structure>
<property name="nativeName">server</property>
</structure>
<structure>
<property name="nativeName">name</property>
</structure>
<structure>
<property name="nativeName">product_name</property>
</structure>
<structure>
<property name="nativeName">usagetime</property>
</structure>
<structure>
<property name="nativeName">projectname</property>
</structure>
<structure>
<property name="nativeName">groupname</property>
</structure>
<structure>
<property name="nativeName">ip</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[table0#-TNAME-#table0#:#[/ULM/PRODUCTS/PRODUCT]#:#{user_name;STRING;/@user_name},{hostname;STRING;/@hostname},{start_time;STRING;/@start_time},{end_time;STRING;/@end_time},{vendor;STRING;/@vendor},{server;STRING;/@server},{name;STRING;/@name},{product_name;STRING;/@product_name},{usagetime;STRING;/@usagetime},{projectname;STRING;/@projectname},{groupname;STRING;/@groupname},{ip;STRING;/@ip}]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>2.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:identifier>
<design:name>user_name</design:name>
<design:position>1</design:position>
</design:identifier>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>-1</design:precision>
<design:scale>-1</design:scale>
<design:nullability>Unknown</design:nullability>
</design:attributes>
<design:usageHints>
<design:label>user_name</design:label>
<design:formattingHints/>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:identifier>
<design:name>hostname</design:name>
<design:position>2</design:position>
<design:usageHints>
<design:label>hostname</design:label>
<design:attributes>
<design:identifier>
<design:name>start_time</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>start_time</design:label>
<design:attributes>
<design:identifier>
<design:name>end_time</design:name>
<design:position>4</design:position>
<design:usageHints>
<design:label>end_time</design:label>
<design:attributes>
<design:identifier>
<design:name>vendor</design:name>
<design:position>5</design:position>
<design:usageHints>
<design:label>vendor</design:label>
<design:attributes>
<design:identifier>
<design:name>server</design:name>
<design:position>6</design:position>
<design:usageHints>
<design:label>server</design:label>
<design:attributes>
<design:identifier>
<design:name>name</design:name>
<design:position>7</design:position>
<design:usageHints>
<design:label>name</design:label>
<design:attributes>
<design:identifier>
<design:name>product_name</design:name>
<design:position>8</design:position>
<design:usageHints>
<design:label>product_name</design:label>
<design:attributes>
<design:identifier>
<design:name>usagetime</design:name>
<design:position>9</design:position>
<design:usageHints>
<design:label>usagetime</design:label>
<design:attributes>
<design:identifier>
<design:name>projectname</design:name>
<design:position>10</design:position>
<design:usageHints>
<design:label>projectname</design:label>
<design:attributes>
<design:identifier>
<design:name>groupname</design:name>
<design:position>11</design:position>
<design:usageHints>
<design:label>groupname</design:label>
<design:attributes>
<design:identifier>
<design:name>ip</design:name>
<design:position>12</design:position>
<design:usageHints>
<design:label>ip</design:label>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
<list-property name="privateDriverProperties">
<ex-property>
<name>MAX_ROW</name>
<value>-1</value>
</ex-property>
<ex-property>
<name>XML_FILE</name>
</ex-property>
</list-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.datatools.enablement.oda.xml.dataSet" name="LicenseServer Data Set" id="10">
<structure>
<property name="columnName">version</property>
<text-property name="heading">version</text-property>
<property name="analysisColumn">version</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="columnName">total</property>
<text-property name="heading">total</text-property>
<property name="analysisColumn">total</property>
</structure>
<structure>
<property name="columnName">used</property>
<text-property name="heading">used</text-property>
<property name="analysisColumn">used</property>
</structure>
<structure>
<property name="columnName">borrowed</property>
<text-property name="heading">borrowed</text-property>
<property name="analysisColumn">borrowed</property>
</structure>
<structure>
<property name="columnName">available</property>
<text-property name="heading">available</text-property>
<property name="analysisColumn">available</property>
</structure>
<structure>
<property name="columnName">server_name</property>
<text-property name="heading">server_name</text-property>
<property name="analysisColumn">server_name</property>
</structure>
<structure>
<property name="columnName">expiration_date</property>
<text-property name="heading">expiration_date</text-property>
<property name="analysisColumn">expiration_date</property>
</structure>
<structure>
<property name="columnName">package_no</property>
<text-property name="heading">package_no</text-property>
<property name="analysisColumn">package_no</property>
</structure>
<structure>
<property name="columnName">forecolor</property>
<text-property name="heading">forecolor</text-property>
<property name="analysisColumn">forecolor</property>
</structure>
<structure>
<property name="columnName">hasp_key</property>
<property name="analysis">dimension</property>
<text-property name="heading">hasp_key</text-property>
<property name="analysisColumn">hasp_key</property>
</structure>
</list-property>
<structure>
<property name="name">version</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="name">total</property>
</structure>
<structure>
<property name="name">used</property>
</structure>
<structure>
<property name="name">borrowed</property>
</structure>
<structure>
<property name="name">available</property>
</structure>
<structure>
<property name="name">server_name</property>
</structure>
<structure>
<property name="name">expiration_date</property>
</structure>
<structure>
<property name="name">package_no</property>
</structure>
<structure>
<property name="name">forecolor</property>
</structure>
<structure>
<property name="name">hasp_key</property>
</structure>
</list-property>
</structure>
<property name="dataSource">LicenseServer Data Source</property>
<structure>
<property name="nativeName">version</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">total</property>
</structure>
<structure>
<property name="nativeName">used</property>
</structure>
<structure>
<property name="nativeName">borrowed</property>
Re: Need help with XML Data source parametrized report [message #727151 is a reply to message #726855] |
Tue, 20 September 2011 10:26   |
Can you attach the report? The post did not have the complete report?
Jason
On 9/19/2011 1:55 PM, KK wrote:
> Hi Jason,
> id="1">
> you're using
> //curr_month++;
> curr_year);
> curr_year);
> "/" + curr_year);
> * 60 * 1000)
> == "01/01/1900")
> curr_year);
> ]]></method>
> <parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> </oda-data-source>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> df.toGMTString();
> df</expression>
> </structure>
> <structure>
> df.toGMTString();
> df</expression>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> <expression
> <structure>
> <expression
> </structure>
> </list-property>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> "'";]]></method>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <xml-property
> encoding="UTF-8"?>
> <model:DesignValues
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:attributes>
> <design:identifier>
> <design:usageHints>
> <design:criteria/>
> <ex-property>
> <value>-1</value>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
Re: Need help with XML Data source parametrized report [message #727173 is a reply to message #727162] |
Tue, 20 September 2011 10:57  |
Are the xml data source files sensitive data? If not could you email
them to me at jasonweathersby at windstream dot net?
Jason
On 9/20/2011 10:46 AM, KK wrote:
> basically, I am trying to chart between grouped days (x-axis) and the
> Utilization% for each day as calculated in the table.
FUDForum. Page generated in 0.08596 seconds
