Home » Archived » BIRT » Dynamically add a marker line to a chart
Dynamically add a marker line to a chart [message #725746] Thu, 15 September 2011 12:29 Go to next message
I have a Chart with bar series. I would like place a vertical marker line on a point on the X axis to denote a cut-off point. Is there a way to do this in the chart script given that the cut-off point is not known until runtime. I can retrieve it from a global variable.
Re: Dynamically add a marker line to a chart [message #726125 is a reply to message #725746] Fri, 16 September 2011 12:03 Go to previous messageGo to next message
Here is an example that sets the location based on a parameter.
Jason
On 9/15/2011 12:29 PM, Mike Wulkan wrote:
Re: Dynamically add a marker line to a chart [message #726177 is a reply to message #726125] Fri, 16 September 2011 14:10 Go to previous messageGo to next message
Thanks for this Jason. One problem though. In my chart I have a bunch of series but only one data value per series. The marker I'd like to insert is between to series bars not between two groups of series. Is this possible?
Re: Dynamically add a marker line to a chart [message #726777 is a reply to message #726177] Mon, 19 September 2011 10:36 Go to previous messageGo to next message
Mike,
Can you take a screenshot of where the marker line is, and use paint to
show where you want it?
Jason
> possible?
Re: Dynamically add a marker line to a chart [message #727099 is a reply to message #726777] Tue, 20 September 2011 08:14 Go to previous messageGo to next message
index.php/fa/4007/0/
The green line is where the marker line comes out but the red line is where I want it. The problem is that all the bars are from different series and there is only one row so the x axis only has one point on it.
Re: Dynamically add a marker line to a chart [message #727170 is a reply to message #727099] Tue, 20 September 2011 10:52 Go to previous messageGo to next message
Mike,
Add the following beforeDrawMarkerLine script:
function beforeDrawMarkerLine( axis, markerLine, icsc )
importPackage(Packages.org.eclipse.birt.chart.model.component.impl);
importPackage(Packages.org.eclipse.birt.chart.model.data.impl);
importPackage(Packages.org.eclipse.birt.chart.model.attribute);
importPackage(Packages.org.eclipse.birt.chart.model.attribute.impl);
importPackage(Packages.org.eclipse.birt.chart.util);
markerLine.setValue(NumberDataElementImpl.create(0.5));
Re: Dynamically add a marker line to a chart [message #727479 is a reply to message #727170] Wed, 21 September 2011 08:15 Go to previous messageGo to next message
Hi Jason,
Doh! For some reason my mind was stuck on integral values... this was just too easy. Well actually it was too easy. In actual fact I don't want the marker line at the halfway point. I'd like to place it on the right edge of the 2nd bar (as shown by the arrow). I'm not sure how to calculate this offset and tie it to the number of bars. I tried multiples of 6 (number of bars) and multiples of 7 (number of edges). The image shown is 3*(1/7) but as you can see it places the marker a little too far to the right. Is there an easy formula I can use or do I just have to fudge it and hardcode a value that works?
index.php/fa/4016/0/
Re: Dynamically add a marker line to a chart [message #727633 is a reply to message #727479] Wed, 21 September 2011 13:54 Go to previous messageGo to next message
That is a bit more complicated. Look at the attached example.
Jason
On 9/21/2011 8:15 AM, Mike Wulkan wrote:
> Hi Jason,
Re: Dynamically add a marker line to a chart [message #728077 is a reply to message #727633] Thu, 22 September 2011 09:50 Go to previous messageGo to next message
Hi Jason,
I think this is getting closer but my chart is configured a little differently and the code you supplied doesn't appear to calculate the correct positions. I have included a sample chart with the configuration that I am using and the arrow points to where I would like the marker line to be positioned. The actual marker line is where the current code puts it.
index.php/fa/4033/0/
Re: Dynamically add a marker line to a chart [message #728216 is a reply to message #728077] Thu, 22 September 2011 14:12 Go to previous messageGo to next message
Can you lower the unit spacing (which is getting added per series).
See modified example.
Jason
On 9/22/2011 9:50 AM, Mike Wulkan wrote:
> Hi Jason,
  • Attachment: MikeW.zip
    (Size: 6.15KB, Downloaded 385 times)
Re: Dynamically add a marker line to a chart [message #728527 is a reply to message #728216] Fri, 23 September 2011 08:32 Go to previous messageGo to next message
Hi Jason,
This almost works. The example works but when I applied this code to my actual chart the line was still out (to the right). So I went back and forth a million times to try to figure out what the difference was. I finally figured it out that it was the legend. In my actual chart code I had different place holder names for each of the series which I subsequently modified in my beforeDrawLegendItem script. One of the place holder names was long (eg., "Brobdingnagian"). The chart formatted based on the width of the legend as it was specified in the designer. At runtime the width of the legend was actually smaller which threw out the calculations for the marker.
I have worked around this by changing the place holder names to something shorter since they don't actually display anyway, but for future reference, I was wondering if there was still a minor tweak to the code that would account for this?
Re: Dynamically add a marker line to a chart [message #728654 is a reply to message #728527] Fri, 23 September 2011 11:35 Go to previous message
Mike,
You can get the size of any the chart blocks (plot, legend, title etc)
but I am not certain how you would do the calculation.
Jason
On 9/23/2011 8:32 AM, Mike Wulkan wrote:
> Hi Jason,
Previous Topic:Which Version Of RAD and WAS supports BIRT 3.7 ?
Next Topic:Why aren't all the data set columns in the 'Available Column Bindings' list?
Current Time: Wed Jul 23 14:58:03 EDT 2025
Powered by FUDForum. Page generated in 0.05571 seconds
