SphereShapes HashCode implementation too general for MultiEditors [message #708151] |
Tue, 02 August 2011 10:09  |
Hi all,
I have a 3D-editor which displays SphereFigureShapes. These Shapes gets their color from a value stored in the editors input file.
That editor can be nested in an Multi3DEditor, where all the SphereShapes from the 3DEditors are shown. So they should have a different color, depending on the input-file of the particular 3DEditor.
The problem is, that every Shape has the same color. This is caused by the way the HashCode method is implemented in the org.eclipse.draw3d.shapes.SphereShape.class:
The SphereKey depends on the parameters precision and outline. Which are the same for every editor in my case.
public SphereKey(int i_precision, boolean i_outline)
Can you imagine a better implementation of the hashCode method above in order to solve my problem?
Is this something I should add to the gef3D issue tracker?
Kamil
[Updated on: Tue, 02 August 2011 10:29] by Moderator
Re: SphereShapes in MultiEditor [message #726681 is a reply to message #708151] |
Mon, 19 September 2011 05:11  |
Dear Kamil,
this seems to be a bug, so opening a new bug for that would be a good
idea. Actually, I have to check all these hashCode/equals methods, as
they might not behave according to the JDK specification.
At the moment, we are in the process of moving GEF3D to git. Once this
is done, I will try to find a solution.
Jens
FUDForum. Page generated in 0.09190 seconds
