Home » Archived » Sapphire » Handle to Project
Handle to Project [message #726051] Fri, 16 September 2011 09:24 Go to next message
I am writing a RelativePathService, I want to return all the Java source
paths that is available for the project as roots for searching the file
that will be assigned o the property having the RelativePathService.
Can anyone tell me how to do this ?
Also in the same scenario,
What is the best way to convert "/" to "." during serialization do we need
to do CustomXmlValueBinding ?
~ Kamesh
Re: Handle to Project [message #726068 is a reply to message #726051] Fri, 16 September 2011 09:51 Go to previous messageGo to next message
IProject proj = element.adapt( IProject.class );
IJavaProject jproj = JavaCore.create( proj );
for( IClasspathEntry entry : jproj.getRawClasspath() )
If you want the text box to show dots, but have slashes written to file, then you need to write a custom binding. If you'd rather see dots in the text box as well, but the problem is that the browse dialog is returning slashes, see RelativePathService.convertToRelative/convertToAbsolute API.
I am assuming that you aren't trying to do this to browse for Java types, as the framework has built-in support for that that is better than trying to use RelativePathService.
- Konstantin
Re: Handle to Project [message #726090 is a reply to message #726068] Fri, 16 September 2011 10:30 Go to previous messageGo to next message
Thanks Konstantin. No not java Types, Actually I am trying to browse for
Resource Bundles (*.properties) that is available in the classpath.
Also when I saw your reply for getting IProject , am now forced to ask me a
long standing query, how to do I access the model element inside the Service
classes or any other place ?
~Kamesh
~ Kamesh
"Konstantin Komissarchik" wrote in message
news:j4vjj9$v7l$1@news.eclipse.org...
- Konstantin
Re: Handle to Project [message #726104 is a reply to message #726090] Fri, 16 September 2011 11:12 Go to previous messageGo to next message
> how to do I access the model element inside the Service classes
IModelElement element = context( IModelElement.class );
Other places may have different API...
Re: Handle to Project [message #726105 is a reply to message #726090] Fri, 16 September 2011 11:14 Go to previous messageGo to next message
I found the way the Service class provides the adapt() method which can be
used to make it to adapt to IProject :)
So let me rephrase my question what is the general way to get model element
if I I have,
1. ModelElementType
2.ModelProperty
~ Kamesh
"Kamesh Sampath" wrote in message news:j4vld6$1p2$1@news.eclipse.org...
~Kamesh
~ Kamesh
- Konstantin
Re: Handle to Project [message #726107 is a reply to message #726105] Fri, 16 September 2011 11:18 Go to previous messageGo to next message
> if I I have,
> 1. ModelElementType
> 2. ModelProperty
If that's all you have, it isn't possible, but you can get access to IModelElement quite easily from a service. See my other response.
Re: Handle to Project [message #726207 is a reply to message #726105] Fri, 16 September 2011 15:20 Go to previous messageGo to next message
"IProject proj = element.adapt( IProject.class );
Based on the above logic I wrote the the logic to make the roots as follows,
ProjectRelativePathService
roots.add( new Path(iClasspathEntry.getPath() ).toPortableString() ));
and my model property definition
// *** ResourceBundle ***
@Type( base = Path.class )
@MustExist
@ValidFileSystemResourceType( FileSystemResourceType.FILE )
@Service( impl = ProjectRelativePathService.class )
@FileExtensions( expr = "properties" )
ValueProperty PROP_RESOURCE_BUNDLE = new ValueProperty( TYPE,
"ResourceBundle" );
Value<Path> getResourceBundle();
void setResourceBundle( String value );
void setResourceBundle( Path value );
When I run my editor, and click on the browse I see just text for the
classpath entries and no file or folders displayed, but it has files and
folders + filters for .properties file. Not sure what mistake am making.
I also tried doing the following way but same result,
for ( IClasspathEntry iClasspathEntry : cpEntries ) {
if ( IClasspathEntry.CPE_SOURCE ==
iClasspathEntry.getEntryKind() ) {
IPath projectPath =
ResourcesPlugin.getWorkspace().getRoot().getLocation();
System.out.println( "Portable String" +
projectPath.append(
iClasspathEntry.getPath() ).toPortableString() );
File file = new File( projectPath.append(
roots.add( new Path( file.getAbsolutePath() ) );
Can you please clarify what mistake am making ??
~ Kamesh
"Kamesh Sampath" wrote in message news:j4vo4d$4js$1@news.eclipse.org...
if I I have,
1. ModelElementType
2.ModelProperty
~ Kamesh
~Kamesh
~ Kamesh
- Konstantin
Re: Handle to Project [message #726215 is a reply to message #726207] Fri, 16 September 2011 16:23 Go to previous messageGo to next message
You need to return absolute paths for roots. Unless your project setup is very unusual, iClasspathEntry.getPath() will not yield an absolute path. It will be something like "/proj/src". You need to locate that folder using IWorkspace API. Once you have the IFolder, call getLocation(). That will give you an absolute path that the API requires.
- Konstantin
Re: Handle to Project [message #726219 is a reply to message #726207] Fri, 16 September 2011 16:26 Go to previous messageGo to next message
Unless your project setup is very unusual, this will not produce absolute paths that are required for roots. More like "/proj/src". You will need to convert this path to an IFolder using IWorkspace API then call getLocation() on IFolder to produce an absolute path that's required.
- Konstantin
Re: Handle to Project [message #726220 is a reply to message #726207] Fri, 16 September 2011 16:26 Go to previous messageGo to next message
- Konstantin
Re: Handle to Project [message #726222 is a reply to message #726207] Fri, 16 September 2011 16:28 Go to previous messageGo to next message
- Konstantin
Re: Handle to Project [message #726309 is a reply to message #726219] Sat, 17 September 2011 03:40 Go to previous message
<HTML><HEAD></HEAD>
<BODY dir=ltr>
<DIV dir=ltr>
<DIV style="FONT-FAMILY: 'Calibri'; COLOR: #000000; FONT-SIZE: 12pt">
<DIV>I am not sure what is the reason -&nbsp; My project was WebProject, as you
said the ClasspathEntry was not returning the absolute path, hence I resorted
your suggestion of using Workspace API and did as follows,</DIV>
<DIV>&nbsp;</DIV>
<DIV>
</DIV>
<DIV>for ( IClasspathEntry iClasspathEntry : cpEntries ) {</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
if ( IClasspathEntry.CPE_SOURCE == iClasspathEntry.getEntryKind() ) {</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
IWorkspace workspace = ResourcesPlugin.getWorkspace();</DIV>
IWorkspaceRoot wroot = workspace.getRoot();</DIV>
IPath entryPath = wroot.getFolder( iClasspathEntry.getPath()
).getLocation();</DIV>
roots.add( new Path( entryPath.toPortableString() ) );</DIV>
}</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }</DIV>
<DIV>
</DIV>
<DIV>&nbsp;</DIV>
<DIV>After this I was able to get all my folders for browsing and filtered by my
@FilterExtensions.</DIV>
<DIV>&nbsp;</DIV>
<DIV>~ Kamesh</DIV>
<DIV>&nbsp;</DIV>
<DIV>"Konstantin Komissarchik"&nbsp; wrote in message
news:j50anj$ocm$1@news.eclipse.org... </DIV>
<DIV>&nbsp;</DIV>
<DIV>&gt; roots.add( new Path(iClasspathEntry.getPath() ).toPortableString()
));</DIV>
<DIV>&nbsp;</DIV>
<DIV>Unless your project setup is very unusual, this will not produce absolute
IFolder to produce an absolute path that's required.</DIV>
<DIV>&nbsp;</DIV>
<DIV>- Konstantin</DIV></DIV></DIV></BODY></HTML>
Previous Topic:Test Post
Next Topic:Switching XSD
Current Time: Sun Jul 27 02:07:55 EDT 2025
Powered by FUDForum. Page generated in 0.26711 seconds
