Home » Archived » Sapphire » Composite Creation(Composite to support Params with Expressions)
Composite Creation [message #726014] Fri, 16 September 2011 08:22 Go to next message
I was trying to create the Composite, but some Hints of the composite properties should use dynamic value a.k.a @{ParamName} similar to what we use in creation of Parts
e.g
I have composite called X and it is used in two paces one palace i need to pass the show.label="true" and in another place i want to make the show.label=false.
so in my
first reference A.X i do a include of the composite and in the params section i set a value ShowLabel=false
and in second reference,
first reference B.X i do a include of the composite and in the params section i set a value ShowLabel=true
So ideally when the composite is rendered it should parse @{ShowLabel} which i use in the Hints section show.label as show.label=@{ShowLabel}.
But this is not working, shall we do an enhancement to make it work like Parts references ?
If this not currently supported then I shall raise a enhancement for the same ?
If i have done something wrong to make it not work, please let me know what mistake i have done ?
~Kamesh
Re: Composite Creation [message #726069 is a reply to message #726014] Fri, 16 September 2011 09:53 Go to previous messageGo to next message
Parameter substitution is currently only supported in a few places. Go ahead and open bugs if you find places where it doesn't work that are important to your scenarios.
- Konstantin
Re: Composite Creation [message #726094 is a reply to message #726069] Fri, 16 September 2011 10:32 Go to previous message
I have created a bug 357949
Previous Topic:Suppressing Background Style of TabGroup
Next Topic:Using customCallbacks.xml
Current Time: Sat Jul 26 08:35:43 EDT 2025
Powered by FUDForum. Page generated in 0.03503 seconds
