Home » Modeling » M2T (model-to-text transformation) » [Acceleo 3] Add Acceleo nature to Project
[Acceleo 3] Add Acceleo nature to Project [message #725587] Thu, 15 September 2011 05:44 Go to next message
Hi there,
i have a project that i need to add the Acceleo nature to, so mtl files will automatically be compiled.
I tried using the "convert to acceleo project" wizard, but it just did nothing.
Could someone give me a little hint on how to achieve that ?
Im on Indigo btw.
Thanks for any help Smile
[Updated on: Thu, 15 September 2011 05:45] by Moderator
Re: [Acceleo 3] Add Acceleo nature to Project [message #725589 is a reply to message #725587] Thu, 15 September 2011 05:49 Go to previous messageGo to next message
Natures associated with projects are specified in the .project file. You can try to add it manually :
<natures>
	<nature>org.eclipse.acceleo.ide.ui.acceleoNature</nature>
</natures>
Re: [Acceleo 3] Add Acceleo nature to Project [message #725600 is a reply to message #725589] Thu, 15 September 2011 06:21 Go to previous messageGo to next message
Thanks for the fast reply.
There is no .project file. It is a plugin-project and there is only build.properties, plugin.properties and plugin.xml.
[Updated on: Thu, 15 September 2011 06:22] by Moderator
Re: [Acceleo 3] Add Acceleo nature to Project [message #725602 is a reply to message #725600] Thu, 15 September 2011 06:28 Go to previous messageGo to next message
You need to browse these files via the Navigator view, the default Package Explorer hides these files.
Re: [Acceleo 3] Add Acceleo nature to Project [message #725610 is a reply to message #725602] Thu, 15 September 2011 06:56 Go to previous messageGo to next message
Oh my, thanks, really Smile
I added the nature and restarted eclipse. The "You need to add the Acceleo Nature to your Project" warning is gone now, but the emtl is still not generated ( i changed a few lines in the .mtl, started the plugin and called the method that calls the generation-> i got an io-exception "generate.emtl" not found).
Still, when i let the generate.mtl be compiled in my "normal acceleo-project" and copy it to the corresponding /bin location of my new project, everything works.
What is going wrong ^^?
[Updated on: Thu, 15 September 2011 07:01] by Moderator
Re: [Acceleo 3] Add Acceleo nature to Project [message #725641 is a reply to message #725610] Thu, 15 September 2011 08:01 Go to previous messageGo to next message
hi,
you need also to add the acceleo builder to your pligin :
<buildCommand>
<name>org.eclipse.acceleo.ide.ui.acceleoBuilder</name>
<arguments>
</arguments>
</buildCommand>
BTW, you should also create a bugzilla because modifying manually the
..project file is bad.
Le 15/09/2011 12:56, the_ch40s a écrit :
> Oh my, thanks, really :)
> still not generated ( i changed a few lines in the emtl, started the
Stéphane Bouchet, OBEO
Re: [Acceleo 3] Add Acceleo nature to Project [message #725749 is a reply to message #725641] Thu, 15 September 2011 12:36 Go to previous messageGo to next message
You say manual editing is bad, but what would be the correct way to add the acceleo nature to the project, since the "convert to acceleo project" wizard does not seem to do anything?
Anyways, thanks for your help, it works now Smile
Re: [Acceleo 3] Add Acceleo nature to Project [message #725932 is a reply to message #725749] Fri, 16 September 2011 04:17 Go to previous message
in Acceleo 3.1, it is "Configure > toggle acceleo nature", the "convert
to acceleo project" is used to convert acceleo2 project in acceleo3.
if it is not working, please open a bug on bugzilla :)
> Anyways, thanks for your help, it works now :)
Previous Topic:[Xpand] dynamic EXPAND statement
Next Topic:Registration problem of GCM package of MARTE Profile
Current Time: Sat Jul 19 01:33:53 EDT 2025
Powered by FUDForum. Page generated in 0.04944 seconds
