Home » Archived » M2M (model-to-model transformation) » [QVTO] Calling transformation programmatically
[QVTO] Calling transformation programmatically [message #101663] Thu, 12 March 2009 11:53 Go to next message
Hi all,
I encountered a strange bug, I think. My setting:
I created an Eclipse plugin providing a qvto file and containing an action which starts a transformation:
public void run() {
URI uri = URI.createPlatformPluginURI(Activator.PLUGIN_ID + "/qvto/transformation.qvto", true);
QvtoTransformationHelper helper = new QvtoTransformationHelper(transformationSpecification);
TransfExecutionResult result = transformationHelper.executeTransformation(getInModels(), Collections.<String, Object> emptyMap(), null);
saveOutModels(result);
The strange thing is that it totally works if I start a runtime workbench and perform the action _for the first time_. The out models are saved as expected.
But if I perform the action again, it does not work any more! The following exception raises. If I restart the runtime workbench, however, it works again for one time!
org.eclipse.core.runtime.CoreException: Failed to parse transformation 'deployed://myplugin/qvto/transformation.qvto', 1 error(s) found.
at org.eclipse.m2m.qvt.oml.runtime.util.QvtoTransformationHelpe r.executeTransformation(QvtoTransformationHelper.java:192)
at myplugin.util.TransformationLauncher.transform(Transformatio nLauncher.java:64)
Any ideas??
By the way, the validator below does not work at all and claims that the resource does not exist, because it only checks the workspace for the given uri.
QvtoTransformationValidator.validateQvtoScript(uri, null, null)
Cheers
Patrick
Re: [QVTO] Calling transformation programmatically [message #101676 is a reply to message #101663] Thu, 12 March 2009 11:57 Go to previous messageGo to next message
Oups, variables were named wrong:
public void run() {
QvtoTransformationHelper helper = new QvtoTransformationHelper(uri);
TransfExecutionResult result = helper.executeTransformation(getInModels(), Collections.<String, Object> emptyMap(), null);
On 12-03-2009 16:53, Patrick Könemann wrote:
> Hi all,
> public void run() {
> at
> at
> Any ideas??
> given uri.
> Cheers
> Patrick
Re: [QVTO] Calling transformation programmatically [message #101713 is a reply to message #101676] Thu, 12 March 2009 17:40 Go to previous messageGo to next message
Hi Patrick,
I can't reproduce problem you mentioned. Could you please attach script
by which the bug is reproduced.
As for deployed modules validation with QvtoTransformationValidator -
it's definitely a bug. I've filed it as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268441.
Sergey
> public void run() {
> emptyMap(), null);
>> Hi all,
>> public void run() {
>> at
>> at
>> Any ideas??
>> given uri.
>> Cheers
>> Patrick
Re: [QVTO] Calling transformation programmatically [message #101760 is a reply to message #101713] Fri, 13 March 2009 05:29 Go to previous messageGo to next message
--------------070504010606000306060201
Hi Sergey,
thanks for the reply.
What I did not mention before: I use a blackbox library for some more complex operations, which seems to be the cause of the exception. After the first (successful) transformation, it contains compilation errors?!?
Thus I can perform the transformation exactly once.
Example project attached (running on Eclipse 3.5M5):
- import existing projects into workspace -> select TransformationOnce.zip
- launch runtime workbench
- select in the menu bar: Transformation Menu -> Start transformation
- check the console output in the main workbench (successful transformation)
- Start the transformation again
- check the console output again: CoreException
Any help appreciated.
Cheers
Patrick
On 12-03-2009 22:40, Sergey Boyko wrote:
> Hi Patrick,
> Regards,
> Sergey
> Patrick K
Re: [QVTO] Calling transformation programmatically [message #101796 is a reply to message #101760] Fri, 13 March 2009 15:37 Go to previous messageGo to next message
Hi Patrick,
Thank you very much for the example project! For me it reproduces bug
even for the first launch.
The problem is that deployed module cannot resolve black-box imports. So
another bug has been submitted
https://bugs.eclipse.org/bugs/show_bug.cgi?id=268596
Both mentioned bugs will be fixed shortly and be available in the next
I-build.
Sergey
> Hi Sergey,
> transformation)
> Cheers
> Patrick
>> Hi Patrick,
>> Regards,
>> Sergey
>>> public void run() {
>>>> Hi all,
>>>> public void run() {
>>>> however,
>>>> at
>>>> at
>>>> Any ideas??
>>>> the
>>>> given uri.
>>>> Cheers
>>>> Patrick
Re: [QVTO] Calling transformation programmatically [message #101808 is a reply to message #101796] Fri, 13 March 2009 17:37 Go to previous messageGo to next message
Hi Patric,
Some minor addition :) In the script I found the following
mapping MyElement::toSomething() : MyElement {
name = self.name;
result.toBlackboxed()
Expression 'name = self.name;' is not an assignment that's in fact
conditional expression resulted in boolean value. Assignment is realized
with ":=" lexeme.
Sergey.
Sergey Boyko wrote:
> Hi Patrick,
> I-build.
> Regards,
> Sergey
>> Hi Sergey,
>> errors?!?
>> transformation)
>> Cheers
>> Patrick
>>> Hi Patrick,
>>> Regards,
>>> Sergey
>>>> public void run() {
>>>>> Hi all,
>>>>> public void run() {
>>>>> however,
>>>>> at
>>>>> at
>>>>> Any ideas??
>>>>> that the
>>>>> given uri.
>>>>> Cheers
>>>>> Patrick
Re: [QVTO] Calling transformation programmatically [message #101879 is a reply to message #101808] Mon, 16 March 2009 06:44 Go to previous messageGo to next message
Hi Sergey,
you're right ;-)
in fact, I didn't even recognize this typo since I created the project just for you (and the newsgroup of course).
thanks for taking care of the bug
Patrick
On 13-03-2009 22:37, Sergey Boyko wrote:
> Hi Patric,
> name = self.name;
> with ":=" lexeme.
> Regards,
> Sergey.
> Sergey Boyko wrote:
>> Hi Patrick,
>> So another bug has been submitted
>> I-build.
>> Regards,
>> Sergey
>>> Hi Sergey,
>>> errors?!?
>>> transformation)
>>> Cheers
>>> Patrick
>>>> Hi Patrick,
>>>> Regards,
>>>> Sergey
>>>>> public void run() {
>>>>>> Hi all,
>>>>>> public void run() {
>>>>>> however,
>>>>>> transformation
>>>>>> at
>>>>>> at
>>>>>> Any ideas??
>>>>>> that the
>>>>>> given uri.
>>>>>> Cheers
>>>>>> Patrick
Re: [QVTO] Calling transformation programmatically [message #101947 is a reply to message #101676] Mon, 16 March 2009 10:01 Go to previous messageGo to next message
Dear developers,
this is not a bug, rather about a minor API change.
In order to start the transformation, the input must be of type List<EObject>:
public TransfExecutionResult executeTransformation(final List<EObject> inObjects, final Map<String, Object> inConfigProperties, ResourceSet metamodelResourceSet) throws CoreException {
So I explicitely need to convert my input from EList<MyElement> to List<EObject>, e.g. in getInModels() in the example below.
This cast would not be required if the type of the input parameter above is changed to: List<? extends EObject>
What do you think?
Best regards
Patrick
> public void run() {
> emptyMap(), null);
Re: [QVTO] Calling transformation programmatically [message #102257 is a reply to message #101947] Mon, 23 March 2009 19:44 Go to previous messageGo to next message
Hi Patrick,
Excuse me for the late answering. I missed the message in thread.
You're right, executeTransformation(..) declaration will be changed like
that. It's even not an API breaking change ;)
I'll apply changes soon.
Sergey
> Dear developers,
> List<EObject>:
> What do you think?
> Best regards
> Patrick
>> public void run() {
>> emptyMap(), null);
Re: [QVTO] Calling transformation programmatically [message #108674 is a reply to message #102257] Sat, 25 July 2009 07:31 Go to previous messageGo to next message
Originally posted by: liaoqiancheng.cjitec.com
Sergey Boyko 写道:
> Hi Patrick,
> Regards,
> Sergey
>> Dear developers,
>> List<EObject>:
>> What do you think?
>> Best regards
>> Patrick
>>> public void run() {
>>> emptyMap(), null);
Hi guys,
Thank you very much;-)
Especially for the example project!
Re: [QVTO] Calling transformation programmatically [message #725702 is a reply to message #108674] Thu, 15 September 2011 10:45 Go to previous messageGo to next message
hey where could i get the example project? i get "Failed to parse transformation "error and dont know how to solve this~~
Re: [QVTO] Calling transformation programmatically [message #725792 is a reply to message #725702] Thu, 15 September 2011 15:09 Go to previous messageGo to next message
Try New->Example...
Re: [QVTO] Calling transformation programmatically [message #726047 is a reply to message #725792] Fri, 16 September 2011 09:20 Go to previous message
Hey thank you for this~~ i wonder is there any example of calling qvt in java??
Previous Topic:ATL Development Tools
Next Topic:ATL launch error
Current Time: Tue Nov 04 18:09:47 EST 2025
Powered by FUDForum. Page generated in 0.05252 seconds
