Home » Eclipse Projects » Rich Client Platform (RCP) » Export Product / GC Error(Internal Error: collecting garbage)
Export Product / GC Error [message #725625] Thu, 15 September 2011 07:25 Go to next message
Hi all,
I am using the eclipse export product wizard to export a rcp product, however, currently I do experience errors while exporting the product with indigo (Eclipse Modeling Tools, Version: Indigo Release, Build id: 20110615-0604).
While running the export, I do get the following error:
An internal error occurred during: "Export Product".
java.lang.OutOfMemoryError
An internal error occurred during: "Collecting garbage".
unable to create new native thread
So far I was able to export the product by manually using "Run Garbage Collector", which I do not really consider being a solution.
My eclipse.ini is currently set to:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502
-product
org.eclipse.epp.package.modeling.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
512m
-vmargs
-Dosgi.requiredJavaVersion=1.6
-Xms128m
-Xmx512m
Can anybody tell me how to fix this issue?
Re: Export Product / GC Error [message #726317 is a reply to message #725625] Sat, 17 September 2011 05:42 Go to previous messageGo to next message
Hi all,
so far it seems, that I could solve this issue by adding
-XX:+UseConcMarkSweepGC
to my eclipse.ini.
I do not know much about Java GC interal matters, however, I found a bug report related to Java 5 and tried the GC policy mentioned above instead of the default handler. Seems so as if this is still an issue in Java 6, since I think eclipse is just utilizing the GC here.
However, I was still unable to redirect the GC. Is eclipe.ini the wrong place to put GC log parameters?
Re: Export Product / GC Error [message #726738 is a reply to message #726317] Mon, 19 September 2011 07:56 Go to previous messageGo to next message
Just to complete this, obviously this issue was not related to eclipse.ini. After tweaking Java Control Panel settings, the log was not written before a system reboot...
Re: Export Product / GC Error [message #726749 is a reply to message #726738] Mon, 19 September 2011 08:40 Go to previous messageGo to next message
No Message Body
Re: Export Product / GC Error [message #726750 is a reply to message #726749] Mon, 19 September 2011 08:41 Go to previous message
hi i am getting this error on exporting to a product
Cannot complete the install because one or more required items could not be found.
Software being installed: RCP Application 1.0.0 (hello 1.0.0)
Missing requirement for filter properties ~= $0: RCP Application 1.0.0 (hello 1.0.0) requires 'hello_root.gtk.linux.x86 [1.0.0]' but it could not be found....
what is this gtk.linux.x86 , i am not able to figure out....pl help
Previous Topic:Bundle Security
Next Topic:RCP export into product
Current Time: Sat Nov 01 14:47:39 EDT 2025
Powered by FUDForum. Page generated in 0.03820 seconds
