Home » Eclipse Projects » EGit / JGit » "Git team provider configuration has gone missing."
"Git team provider configuration has gone missing." [message #725545] Thu, 15 September 2011 02:53 Go to next message
I get two stacktraces with Egit in my logs. Are these ones indicators for a bug or went something wrong in my workspace? In the former case, I'll try to provide more details if required to fix this.
Apart these exceptions, I didn't noticed any further problems.
Marcel
java.io.FileNotFoundException: /Users/Marcel/Workspaces/eclipse.org/.metadata/.plugins/org.eclipse.core.resources/.projects/org.eclipse.recommenders.server.rootfiles.feature/org.eclipse.egit.core/GitProjectData.properties (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:120)
at org.eclipse.egit.core.project.GitProjectData.load(GitProjectData.java:411)
at org.eclipse.egit.core.project.GitProjectData.get(GitProjectData.java:168)
at org.eclipse.egit.core.GitProvider.getData(GitProvider.java:78)
at org.eclipse.egit.core.project.RepositoryMapping.getMapping(RepositoryMapping.java:224)
at org.eclipse.egit.ui.Activator$ResourceRefreshJob.triggerRefresh(Activator.java:370)
at org.eclipse.egit.ui.Activator$2.windowActivated(Activator.java:235)
at org.eclipse.ui.internal.Workbench$14.run(Workbench.java:1002)
at org.eclipse.ui.internal.Workbench.fireWindowActivated(Workbench.java:1000)
at org.eclipse.ui.internal.WorkbenchWindow$28.shellActivated(WorkbenchWindow.java:3141)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:88)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4125)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1461)
at org.eclipse.swt.widgets.Shell.windowDidBecomeKey(Shell.java:2105)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5516)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:213)
at org.eclipse.swt.widgets.Widget.becomeKeyWindow(Widget.java:361)
at org.eclipse.swt.widgets.Shell.becomeKeyWindow(Shell.java:532)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5340)
at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
at org.eclipse.swt.internal.cocoa.NSWindow.close(NSWindow.java:54)
at org.eclipse.swt.widgets.Shell.destroyWidget(Shell.java:773)
at org.eclipse.swt.widgets.Widget.release(Widget.java:1309)
at org.eclipse.swt.widgets.Control.release(Control.java:2817)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:662)
at org.eclipse.jface.window.Window.close(Window.java:335)
at org.eclipse.jface.dialogs.Dialog.close(Dialog.java:979)
at org.eclipse.jface.dialogs.TrayDialog.close(TrayDialog.java:221)
at org.eclipse.jface.dialogs.Dialog.okPressed(Dialog.java:940)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:472)
at org.eclipse.egit.ui.internal.push.PushResultDialog.buttonPressed(PushResultDialog.java:84)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3971)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.egit.ui.internal.push.PushResultDialog$1$1.run(PushResultDialog.java:55)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3935)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3612)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.egit.ui.internal.actions.RepositoryActionHandler.getProjectsInRepositoryOfSelectedResources(RepositoryActionHandler.java:175)
at org.eclipse.egit.ui.internal.actions.RepositoryActionHandler.getProjectsInRepositoryOfSelectedResources(RepositoryActionHandler.java:157)
at org.eclipse.egit.ui.internal.actions.AddToIndexActionHandler.isEnabled(AddToIndexActionHandler.java:58)
at org.eclipse.egit.ui.internal.actions.RepositoryAction.isEnabled(RepositoryAction.java:125)
at org.eclipse.egit.ui.internal.actions.RepositoryAction.selectionChanged(RepositoryAction.java:102)
at org.eclipse.ui.internal.PluginAction.refreshEnablement(PluginAction.java:206)
at org.eclipse.ui.internal.PluginAction.selectionChanged(PluginAction.java:277)
at org.eclipse.ui.internal.ObjectActionContributor$1.run(ObjectActionContributor.java:157)
at org.eclipse.ui.internal.ObjectActionContributor.contributeObjectActions(ObjectActionContributor.java:160)
at org.eclipse.ui.internal.ObjectActionContributorManager.contributeObjectActions(ObjectActionContributorManager.java:97)
at org.eclipse.ui.internal.PopupMenuExtender.addObjectActions(PopupMenuExtender.java:262)
at org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(PopupMenuExtender.java:339)
at org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuManager.java:342)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:473)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:469)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:495)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:247)
at org.eclipse.swt.widgets.Menu.menuWillOpen(Menu.java:805)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:5522)
at org.eclipse.swt.internal.cocoa.NSMenu.popUpContextMenu(NSMenu.java:73)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:277)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4048)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3603)
Re: "Git team provider configuration has gone missing." [message #725648 is a reply to message #725545] Thu, 15 September 2011 08:51 Go to previous messageGo to next message
Looks like your workspace lost the file storing the information which projects are shared with EGit.
Try to share them again
- select the projects
- click "Team > Share Project... > Git"
- If the repository for your projects is still on your disk check the checkbox "Use or create repository in parent folder of project"
- The next page should list all projects with their respective repositories
- Select the ones you want to re-share and click "Finish"
Hope this fixes your problem
Re: "Git team provider configuration has gone missing." [message #725658 is a reply to message #725648] Thu, 15 September 2011 09:21 Go to previous message
disconnecting and then sharing the project again solved the issue. Error log is clean now. Thanks.
Previous Topic:Enabling hooks in EGit
Next Topic:Check Home Directory warning message
Current Time: Sat Jul 26 19:15:22 EDT 2025
Powered by FUDForum. Page generated in 0.05066 seconds
