Home » Language IDEs » Java Development Tools (JDT) » TODO not showing up as tasks
TODO not showing up as tasks [message #723348] Thu, 08 September 2011 07:43 Go to next message
I think I've done everything as suggested.
1. TODO is a defined tag under Compiler->Task Tags
2. Under the tasks view, I have tried Show All, defined a custom configuration for TODO, etc.
3. Ensured project is built
4. Ensured there are no "build path errors"
BTW, I can see tasks in CSS and XSL files, but not from Java/Javascript files.
Thanks in advance!
Re: TODO not showing up as tasks [message #723647 is a reply to message #723348] Fri, 09 September 2011 00:05 Go to previous messageGo to next message
Did you make sure that the TODO tag is also defined in the project properties rather than just the workspace preferences. I cannot find any other reason.
Re: TODO not showing up as tasks [message #723667 is a reply to message #723647] Fri, 09 September 2011 02:14 Go to previous messageGo to next message
I don't have any project specific settings. It uses the workspace settings.
Re: TODO not showing up as tasks [message #724846 is a reply to message #723348] Tue, 13 September 2011 06:40 Go to previous messageGo to next message
You mean you can't see it in both, Java and Javascript or just in one of
them?
Dani
> Thanks in advance!
Re: TODO not showing up as tasks [message #725151 is a reply to message #724846] Wed, 14 September 2011 01:50 Go to previous messageGo to next message
I can't see it in both.
Re: TODO not showing up as tasks [message #725186 is a reply to message #725151] Wed, 14 September 2011 02:54 Go to previous messageGo to next message
Strange. Are you sure that the file where you add the TODO is on the
Java build path?
Dani
Re: TODO not showing up as tasks [message #725220 is a reply to message #725186] Wed, 14 September 2011 05:32 Go to previous messageGo to next message
Yes. I use an external ANT build file to build. Does that make a difference?
Re: TODO not showing up as tasks [message #725299 is a reply to message #725220] Wed, 14 September 2011 09:17 Go to previous messageGo to next message
> difference?
Yes it does: the TODO markers are created by the Eclipse Java compiler.
If you don't run it, you won't get the TODO markers.
Dani
Re: TODO not showing up as tasks [message #725669 is a reply to message #725299] Thu, 15 September 2011 09:58 Go to previous messageGo to next message
I would think that Eclipse just needs to pre-process the files, not really compile them? Any way to do that?
Re: TODO not showing up as tasks [message #725942 is a reply to message #725669] Fri, 16 September 2011 03:42 Go to previous message
There is not option for the compiler to do this. You need to do it yourself.
Dani
Previous Topic:Should JDT compiler complain about unused methods here?
Next Topic:starting eclips
Current Time: Mon Jul 21 00:32:11 EDT 2025
Powered by FUDForum. Page generated in 0.06432 seconds
