Home » Archived » Buckminster » [solved] Trigger action for another component from cspex
[solved] Trigger action for another component from cspex [message #725174] Wed, 14 September 2011 03:04 Go to next message
I am trying to build an RCP with buckminster. Therefore I have my own "releng" feature project with a cspex file in it.
There exists another feature project "p2.updatesite" that creates - as the name suggests - an update site repository.
Now I want my custom action in releng to first trigger p2.updatesite -> site.p2 and use that resulting repository for its build process.
Where, and how would I trigger such a build? I see there are dependencies and prerequisites but I could not find out, how to put things together.
thanks for help
Christian
[Updated on: Wed, 14 September 2011 08:29] by Moderator
Re: Trigger action for another component from cspex [message #725283 is a reply to message #725174] Wed, 14 September 2011 08:29 Go to previous messageGo to next message
It's easy once you figure it out:
just add
            <prerequisites alias="repository">
                <attribute name="p2.updatesite" /><!-- feture ID -->
                <attribute name="site.p2" /><!-- action name -->
            </prerequisites>
to the action and it magically works.
Re: Trigger action for another component from cspex [message #725321 is a reply to message #725283] Wed, 14 September 2011 10:04 Go to previous messageGo to next message
> just add
> </prerequisites>
Actually, that snippet would attempt to trigger two actions, p2.updatesite
and site.p2, both in the current component.
What you are looking for is
<attribute name="site.p2" component="p2.updatesite" />
</prerequisites>
(optionally, if you have components of different type with the same id, i.e.
both a plugin and a feature named "p2.updatesite", you can add a third value
componentType="eclipse.feature" to the <attribute .../> to select the
correct one)
More information is available in the Bucky Book
(http://www.eclipse.org/downloads/download.php?file=/tools/buckminster/doc/BuckyBook.pdf),
chapter 6.
Re: Trigger action for another component from cspex [message #725900 is a reply to message #725321] Fri, 16 September 2011 02:41 Go to previous message
Carsten Reckord wrote on Wed, 14 September 2011 10:04
Thanks for clarifying things here. So the attribute name always refers to an action on the current component.
What about the properties file passed to the original action? Can it be replaced for the prerequisites?
What I want to do is build an p2 update site first, followed by an RCP. All by triggering one action.
While site.p2 should be built with target.os=* RCP needs some dedicated target.os
So I have 2 actions, 1 property and 2 different values it should hold. AFAIK ant properties are immutable. Is there some neat buckminster magic that can do the trick?
[Updated on: Fri, 16 September 2011 02:41] by Moderator
Previous Topic:Resolution Bug?
Next Topic:Create p2 site that shows all bundles
Current Time: Wed Jul 23 08:56:23 EDT 2025
Powered by FUDForum. Page generated in 0.04238 seconds
